A thread only for new arrival and top seller flashlight and accessoriess in www.lightake.com
601/602 LED Flashlight Black
601 LED Flashlight
602 LED Flashlight
This two flashlight are very similar,you can see detial informations from our website .
601 LED flashlight $7.73
602 LED flashlight $7.92
Video on youtube :
601 LED flashlight http://www.youtube.com/watch?v=7PxGF2Soyw4
602 LED flashlight http://www.youtube.com/watch?v=m1SqQatpp9k
Suterfire G2 XPE R5 5-mode 120 lumen LED Flashlight
This is a very nice flashlight ,it is a new brand for everyone ,but also have a good quality .It's use XRE-R5 LED ,With 5-Mode 120-Lumen,Hi > Med > Lo > SOS > Strobe .Prowered by 1*18650 battery .ON/OFF power switch by pressing the end of the torch body.Perfect fit for home maintenance, outdoor activities, hiking, night fishing, camping, caving, hunting etc
URL for this product : http://www.lightake.com/detail.do/sku.29211
SKYRAY S-A1 Cree Q3 5-Mode 160-Lumen LED Flashlight
I think this flashlight is not so strange to everyone ,it use Cree Q3 LED ,has five mode Hi>med>lo>strobe>SOS,out put upto 160 lumens!
you can visit this page for more inforamations: http://www.lightake.com/detail.do/sku.30367
The SolarForce L2 Flashlight Body Tube with Extension Tube Black is a good price considering extension tube by itself seems to be over US$4!
You should consider selling in silver too
OK ,thanks for your advice ,I will follow your advice ,if you have any other good advice ,you also can tell me ,and we will do our best to meet your's need ,or if you have and pruduct requests ,you also can tell me ,i will notice the purchasing department to purchase it ,thanks again for your advice !
Best Regards,
Daniel
New arrival flashlight:
SmallSun ZY-C60 Cree Q3-WC 180-Lumen LED Flashlight Torch Black $8.26
SmallSun ZY-C60 Cree Q3-WC 180-Lumen LED Flashlight Torch Features
- Compact and portable handheld design
- SmallSun ZY-C60 Cree Q3-WC 180-Lumen LED Flashlight Torch
- Powered by 1*CR123A batteries (not included)
- Aluminum Smooth and SMO Reflector
- Durable Aluminum Alloy housing
- 180 lumens max (manufacturer rated)
- One mode reverse clicky
- ON/OFF power switch by pressing the end of the torch body
- Flashlight with built-in strap for carrying conveniently
- Perfect fit for home maintenance, outdoor activities, hiking, night fishing, camping, caving, hunting etc
URL for this flashlight : http://www.lightake.com/detail.do/sku.30524
Here is some more advice. I see your 5% discount coupon has expired. I would recommend that you always have an active discount for the members here any any other flashlight forum that you may visit regularly. I bought a few things with the last coupon and was going to buy some more things yesterday, but the coupon ran out, so I didn't buy anything, since I figured that there would be another coupon later.
Ok ,thanks for your advice ,I will consider it ,and relpy you as soon as possible!
AKOray K106 Cree Q5 5-Mode 160-Lumen LED Flashlight Gray
AKOray K106 Features
- Compact and portable design
- AKOray K106 Cree Q5 5-Mode 160-Lumen LED Flashlight
- Powered by 1*AA battery (not included)
- Maxium Lumens: Output up to 160 Lumens (manufacture rated)
- Glass lens and aluminum orange peel reflector cup
- P.D.C Voltage range: 0.7-4.5V DC
- 5-Mode: Hi > Med > Lo > Strobe > SOS
- Flashlight with built-in clip for carrying conveniently
URL for this prouct: http://www.lightake.com/detail.do/sku.27971
SAiK SA-207 Cree Q3-WC 130-Lumen LED Flashlight Torch $9.49
SAiK SA-207 Cree Q3-WC 130-Lumen LED Flashlight Torch Features
- Brand New SAiK SA-207 Cree Q3-WC 130-Lumen LED Flashlight Torch
- Powered by 2xAAA batteries (not included)
- Coated glass lens and plastic smooth reflector cup
- Constant current circuit, voltage range: 0.8~13.0V, 1.5V Max.
- SAiK SA-207 LED Flashlight with built-in clip for carrying conveniently
URL for this flashlight : http://www.lightake.com/detail.do/sku.30602
Solar L2 Cree XP-G R5 5-Mode 320-Lumen LED Flashlight with Extension Tube Black (2x18650)
SolarForce L2 Cree XP-G R5 5-Mode 320-Lumen LED Flashlight Features
- Brand New SolarForce L2 Cree XP-G R5 5-Mode 320-Lumen LED Flashlight
- Powered by 2x18650 batteries (not included)
- Coated glass lens and aluminum smooth reflector cup
- Constant current circuit, voltage range: 4.2~8.4V, 8.4V Max.
- 5 modes: Hi > Mid > Lo > Strobe > SOS
- SolarForce L2 LED Flashlight with built-in strap for carrying conveniently
- Come with Extension Tube
SolarForce L2 Cree XP-G R5 5-Mode 320-Lumen LED Flashlight Specifications
Brand: SolarForce
Model: L2
Emitter Brand/Type: Cree
Emitter BIN: XP-G R5
Color BIN: White
Brightness: 320 lumens maximum brightness (manufacturer rated)
Lens diameter: 32.1mm
Length: 200.0mm
Weight (including the packing): 153.0g
Hi there Daniel,
Can you tell us when you post a new light, if the driver pill is glued in or easy to remove and upgrade?
I seem to have the mod bug, and knowing would help
Hi FlexakaMal,
I'm sorry ,I can't reply your question ,I only post there new arrival products ,thanks !
if you have a special need ,we also can help you find it !
Thanks very much !
Daniel
SmallSun ZY-016 SSC-P7 5-Mode 130-Lumen LED Flashlight Black (1x18650)
SmallSun ZY-016 LED Flashlight Features
- Brand new and high quality LED flashlight
- SmallSun ZY-016 SSC-P7 5-Mode 130-Lumen LED Flashlight
- Powered by 1x18650 batteries (not included)
- Toughened synthetic glass lens and textured coated plastic reflector cup
- 5 modes: Hi > Med > Lo > SOS > Strobe
- SmallSun ZY-016 LED Flashlight with built-in strap for carrying conveniently
SmallSun ZY-016 LED Flashlight Specifications
Color: Black
Brand/Model: SmallSun ZY-016
Lumen: 130 lumens
LED emitter: SSC-P7
Lens diameter: 44.6mm
Length: 150.0mm
Weight (including the packing): 159.0g
URL for this flashlight: http://www.lightake.com/detail.do/sku.29212
Small Sun M8 Cree MC-E 5-Mode 250-Lumen LED Flashlight Black (1x18650/2x16340)
SmallSun M8 Cree MC-E 5-Mode 250-Lumen LED Flashlight Features
- SmallSun M8 Cree MC-E 5-Mode 250-Lumen LED Flashlight
- Powered by 1x18650 or 2x16340 batteries (not included)
- Coated glass lens and textured Aluminum orange peel reflector cup
- SmallSun M8 LED Flashlight with built-in strap for carrying conveniently
SmallSun M8 Cree MC-E 5-Mode 250-Lumen LED Flashlight Specifications
Color: Black
Brand/Model: SmallSun M8
Lumen: 250 lumens
LED emitter: MC-E
Lens diameter: 44.5mm
Length: 146.0mm
Weight (including the packing): 75.0g
URL for this flahlight:
http://www.lightake.com/detail.do/sku.30683 (black)
http://www.lightake.com/detail.do/sku.30682 (gray)
Bolly BL-801 Cree P3-8B 150-Lumen Yellow LED Flashlight Black
Bolly BL-801 Cree P3-8B 150-Lumen Yellow LED Flashlight Features
- Bolly BL-801 Cree P3-8B 150-Lumen Yellow LED Flashlight
- Powered by 1x18650 battery (not included)
- Bolly BL-801 LED Flashlight with built-in strap for carrying conveniently
URL for this flashlight: http://www.lightake.com/detail.do/sku.30783
901 Cree Q3-WC 3-Mode 130-Lumen Convex Lens Zooming LED Flashlight
901 Cree Q3-WC 3-Mode 130-Lumen Convex Lens Zooming LED Flashlight Features
- 901 Cree Q3-WC 3-Mode 130-Lumen Convex Lens Zooming LED Flashlight
- Coated glass lens and Plastic Smooth/SMO reflector cup
- 3-Mode: Hi > Lo > Strobe
- Features: Twisty head turn right can be square beam of light; Twisty head turn left can be circular beam of light
- 901 LED Flashlight with built-in clip for carrying conveniently
URL for this flashlight: http://www.lightake.com/detail.do/sku.30786
MrLite LT1 CREE 7090 XR-E R2 9-Mode 230 Lumens LED Flashlight Black (1x18650)
MrLite LT1 CREE 7090 XR-E R2 9-Mode 230 Lumens LED Flashlight Features
Brand New MrLite LT1 CREE 7090 XR-E R2 9-Mode 230 Lumens LED Flashlight
Pocket size, portable for everyday carry.
Precision optical system, latest orange peel reflector
Mil-Spec type III hard anodized finish, impact resistant
Made from aluminum alloy, really strong
Water proof to IPX-3 standard
IC control
Maintain constant brightness
Variable output mode:
2 modes with 9 types output
Normal mode: lowlight, normal light, high light, strobe, and stand-by
Professional mode: slim light, lowlight, normal light, high light, super light, strobe, low light SOS, high light SOS, and stand-by
Ergonomics design for comfortable handling
Toughened ultra-clear glass lens with anti-reflective coating
Replaceable and rechargeable lithium polymer battery
Low heat emit
MrLite LT1 CREE 7090 XR-E R2 9-Mode 230 Lumens LED Flashlight Specifications
Color: Black
Dimension: head diameter 29 mm, tail diameter 29 mm, and length 112 mm
Lumens & runtime:
Level1: 230 lumens, 2 hours
Level2: 180 lumens, 2.5 hours
Level3: 160 lumens, 4 hours
Level4: 90 lumens, 9 hours
Level5: 40 lumens, 26 hours
Material: aircraft aluminum alloy T6061
Weight: 118.5.0g (exclude battery)
Water proof to IPX-8 standard
Battery: 1 x 18650 (not included)
LED power consumption: 3W
Reflector: OP
Switch: Reverse switch
MrLite LT1 CREE 7090 XR-E R2 9-Mode 230 Lumens LED Flashlight Package Included
1 x MrLite LT1 CREE 7090 XR-E R2 9-Mode 230 Lumens LED Flashlight
1 x Nylon holster
1 x Lanyard
1 x User's manual
UltraFire WF-501B Cree MC-E 800 Lumens LED Flashlight with Pressure Switch Black (1x18650)
UltraFire WF-501B Cree MC-E 800 Lumens LED Flashlight Features
- UltraFire WF-501B Cree MC-E 800 Lumens LED Flashlight
- Powered by 1*18650 battery (not included)
- Maxium Lumens: Output up to 800 Lumens (manufacture rated)
- Constant current circuit, voltage range: 3.0V-4.2V
- Come with Cable Pressure Switch for UltraFire WF-501B
- UltraFire WF-501B LED Flashlight with built-in strap for carrying conveniently
UltraFire WF-501B Cree MC-E 800 Lumens LED Flashlight Specifications
Brand/Model: UltraFire WF-501B
Emitter BIN: MC-E
Lumen: 800 lumens
Reflector: Orange peel reflector
Color: Black
Lens diameter: 30.0mm
Length: 135.7mm
Weight (including the packing): 122.0g
UltraFire WF-501B Cree MC-E 800 Lumens LED Flashlight Package Included
1 x UltraFire WF-501B Cree MC-E 800 Lumens LED Flashlight
1 x Cable Pressure Switch for UltraFire WF-501B
More Ultrafire Flashlight: http://www.lightake.com/products.do/category.176
Coupon on lightake FLASHLIGHT 5% discount
Only used for the flashlight products
