Test/Review of Tensai AA TR-6 2000mAh (White)
3 posts / 0 new
HKJ
HKJ's picture
Last seen: 2 days 28 min ago
DSC_3570
Official specifications:
  • Model: TR-6 (single cell) / 4TR-6 (4 pcs blister pack)
  • Manufacturer: TENSAI
  • Size: AA, LR6
  • Chemistry: NiMH (Nickel Metal hydride)
  • Nominal Voltage: 1.2V
  • Capacity: Minimum: 2000mAh, Typical: 2050mAh, When discharged at 0.2C to 1.0V at 20°C
  • Fast Charge: up to 1000mA
  • Service Life: >500 cycles
  • 90% charge after 6 months, 80% charge after 12 months.
  • Internal Resistance: Diameter (mm): 14.5
  • Height (mm): 50.5
  • Weight: 28g
Tensai%20AA%20TR-6%202000mAh%20(White)-info
Maximum temperature raise at different discharge currents: 1A:+1,9°C, 2A:+5,0°C, 3A:+8,0°C, 5A:+14,3°C, 7A:+19,4°C
These cells are LSD (Low self discharge, i.e. they can stay charged for a long time.
DSC_3568 DSC_3569
DSC_3571 DSC_3572
DSC_3573
DSC_3574
DSC_3575
Tensai%20AA%20TR-6%202000mAh%20(White)-Capacity
The cells can handle a lot of current, but there is small differences between the cells.
Being a NiMH cell the capacity differences between the two tested cells is only a minor problem.
Tensai%20AA%20TR-6%202000mAh%20(White)-CapacityTime
Tensai%20AA%20TR-6%202000mAh%20(White)-CapacityTimeHours
Tensai%20AA%20TR-6%202000mAh%20(White)-Energy
Tensai%20AA%20TR-6%202000mAh%20(White)-PowerLoadTime
Tensai%20AA%20TR-6%202000mAh%20(White)-CurrentTest
Tensai%20AA%20TR-6%202000mAh%20(White)-Charge
Conclusion
The cell has more than rated capacity and good performance.
Notes and links
The batteries was supplied by ENERDan for review.
Werner
Werner's picture
Last seen: 2 years 2 months ago
Thanks for the test.
Seems like good cells.
Compared to eneloops these have slightly lower voltage under load but overall more capacity and energy…
troisanh
Last seen: 10 months 6 days ago
thanks for the review, nice to see more alternatives.
