I am always looking for great UV lights, as I do forensic inspections, and most are crappy.
I did have a tank but they are not durable enough, and I end up having to bang it to make it go on, etc….but the beam itself was not that bad.
What I’m looking for is some way of projecting as strong a 365 nm range beam as I can, as far as I can, so I can sweep large areas at a time.
Unfortunately, I have no clue as to what the specs mean in real life, in that I find I know just enough to know I don’t know enough to be able to predict actual field performance.
IE: I try for one with higher uW/cm2 etc, but one is found to be measured at the LED, another at 6” and another at 15” and so forth.
So now I don’t even know what the top dog would output as a bench mark, etc.
Teej, I think purely from output point of view you’d be better off using a portable fluorescent UV source. The efficiency of LEDs at this wavelength really pales in comparison.
That’s true, and, I used to use them, but, I can’t carry them around and the other equipment at the same time, they’re too bulky and the tubes break too easily.
But the OUTPUT is like night and day, and if I could get even close to their output with an LED it would be a miracle - but, I just want to find the best bet for a 365 nm UV LED at this point.
TANK007 PT30 5W 365 nm might be what you’re seeking if $$$ is not an issue.
I’ve no idea what they’re like, as it’s outside my budget, yet may be within yours.
I believe they have a few higher priced UV torches around the same brightness.
I tried out one of these emitters that I paid $28.99USD shipped for 5 emitters. I can't tell if it's the real thing as I have no measuring equipment and have very little experience with UV lights. I drove the emitter DD with 3AAA's. Here is what I observed:
The emitter did not put out much visible light, but what it does put out seems almost a neutral white compared to my other two UV lights that have 5mm emitters. One of the 2 is supposed to be 395nm and the other is unknown.
It fluoresces white objects ok. Colored objects that fluoresce well with the 395nm light, don't fluoresce much with this emitter. It fluoresces urine, but not a brilliantly as with my 395nm light.
GITD items fluoresce well.
I got best results in mule mode. Both a reflector with a plastic lens and a TIR optic reduced output except for in the hot spot.
Edit: After using the emitter more now I'm thinking this may not be 365nm emitter. Almost everything seems to fluoresce better with my 12 emitter 395nm light. Also, the visible portion of the beam almost seems a neutral white. Kind of a creamy tan tint.
Those bills are crazy Toysareforboys. I appreciate the offer, but I don't think these emitters are worth it. I'm going to complain to the vendor today.
When I looked at specs from the makers of higher power LEDs in that 365 nm range (The 365 is a LOT more expensive than the 395, esp as the watts go up, etc.)…
It seems to me that the situation is analogous to the tint situation for the Vis LED’s, in that the cooler tints are cheaper per lumen, and the longer wavelength UV are cheaper per watt per unit area emitted.
So a really strong 365 nm UV LED looks to cost closer to $150 for a real one…for just the LED, unless you are buying huge volumes, etc.
That means the ones for under $100 or the LED itself are probably either lower output and/or longer wavelength.
I had a Xenopus I got a few years ago that actually had great output, but, I use these things for work, and they get banged around a lot, and it needs to be replaced. I ordered another Xenopus UV to replace it, and I’ll let you know if it looks to be a good option in that 365 nm range.
I might be overpaying compared to a DIYS on this, but I don’t have the time to mess with it at the moment, and needs are current, etc.
If I was better versed in how to wire UV LEDs, etc, I might put in the research, but now, I can’t afford the time.
Yeah, I should have known better, but I was hopefull. I think you're right. If you want real 365nm, you have to pay the big dollars. Maybe, the vendor just made a mistake and send the wrong emitters. I have inquired, but have not received a reply yet.
Best of luck on your new acquisition Teej. Look forward to your report on it. Even if it isn't budget.
Actually since you said its visible output is white your led sounds like 365nm.
Do you see purple with your 395nm? How far each person can see into the edges of visible range can differ.
365nm leds are not as efficient as leds above 380nm. A 3W 365nm led puts out a lot less photons then a 3W higher wavelength UV LED. Compare LED Engin's High Power UV leds
700mA @ 3.9 V gives 550mW of 400nm light or 385nm.
700mA @ 3.9 V gives 200mW of 365nm light.
365nm is only 36% as efficient as 385nm here. This is for a quality name in high power UV leds, don't know how efficient chinese 365nm leds might be. Plus like with chinese lumens these may not even be "3W" to start with. Who knows what output to expect in the end.
Sort of need a known 365 and maybe 385 led to check how you see the visible output & compare to these chinese 3W leds.
Interesting info Helios-. Now I'm wishing I had not yet contacted the vendor. I will try to google this later, but are you aware of anything that would fluoresce better under 365nm light vs 395nm light?
With the 395nm light, I see a very slight purple tint. My even cheaper 5mm UV light emitts an more purple tint then the 395nm light.
I use my UV drop-ins to “power-up” GITD items and I’ve seen something that makes me think the 365nm drop-in that Kaidomain sold me (actually I was so impressed I bought another) is the real deal.
I bought some GITD red paint from Kilabitzzz , an ebay seller that has grown and now has a “brick and mortar” store as well. This paint is cream coloured when discharged, when the Solarforce or any of the others I have except Kaidomain’s 365nm shine on it remains cream with a bit of violet thrown in then when the light is off the GITD paint fluoresces. With the Kaidomain’s 365nm drop-in the GITD paint fluoresces immediately the beam touches it and the effect is brighter and lasts a bit longer. This goes for all the GITD stuff that I have including the powders and paints, they show colour immediately. It makes me think that it is nearer a true 365nm with less white light produced.
The Kaidomain drop-in also shows up detail on banknotes that the others don’t.
Thanks for the info 8steve88. Thanks for including all the info to allow one to replicate the test.
I've been Googling and have only found one definitive test that an average joe can replicate. It involves Canadian currency like Toysareforboys mentioned. Here is one example.
I don't have any Canadian currency here. When I was testing the emitter out on a US $5 bill, the 365nm emitter would not show the "05" that are scattered around on the left of the back side of the bill. The 395nm light revealed them clearly. Same with the embedded strip and other details. I don't know what that means though.
That is very similar (different wording and patterns obviously) to what I get with U.K. £10 and £20 notes, very little hidden detail with drop-ins other than the Kaidomain which gives strong details - 10, 20 and patterns.
