Wow. That looks real good. That may be the brightest stock xml aspheric beam I have ever seen. That reflector must be directing all the light that hits it within the area on the lens that the emitter image hits.
The light looks real good too. Congrats on the new light led4power.
Oh BABY, I got this MONSTER today! Flawless build quality, mind blowing bright, has last mode memory (so much better than the ones that are in the NEXT mode every time you turn it on). High, med, low, SOS, random quick strobe. Takes one or two 26650’s (comes with extension tube). Zoomable (smooth buttery stiff action). All threads (head, tail cap, extension tube) were perfectly clean and well lubed. Doesn’t even make a sound when screwing it all together OR even when you slide the head for zoom in/out!!!
They are sold NOWHERE else If you don’t live in China/Japan, you can’t buy from taobao
You can filter it through google translate and it makes it slightly more readable http://bit.ly/1na3dIX
If you get an asian girlfriend she might be able to help you pick out an item to buy and have it shipped to their family in China who will then re-ship it to you, or you can use an agent like I did ( http://yoybuy.com ).
Good luck man. I’m SUPER impressed with this light.
Looks similar to the tulip shaped head ones that you find on ebay sometimes (most of them that say 26650 lie but there are some out there, I got two), but with a reflector and less blue in the beam, nice. If they aren’t too expensive, maybe a group buy could work? Especially if they take an extension for 2x26650 and maybe….possible MTG2 fits?
Is the lens glass or plastic? If it’s glass unfortunately I think I might have to buy one!
Have you pulled it apart yet and taken any measurements of driver space etc? I wouldn’t mind putting an MT-G2 in one if there is room for an adequate driver.
I’m not sure if you need an account/be signed in for that link to work. If you pick “flashlight with extended barrel” that’s the flashlight with the extension tube, should be $30.25.
