Review: UV light shootout, seven lights tested
Thanks for the info 8steve88. Thanks for including all the info to allow one to replicate the test.
I've been Googling and have only found one definitive test that an average joe can replicate. It involves Canadian currency like Toysareforboys mentioned. Here is one example.
I don't have any Canadian currency here. When I was testing the emitter out on a US $5 bill, the 365nm emitter would not show the "05" that are scattered around on the left of the back side of the bill. The 395nm light revealed them clearly. Same with the embedded strip and other details. I don't know what that means though.
That is very similar (different wording and patterns obviously) to what I get with U.K. £10 and £20 notes, very little hidden detail with drop-ins other than the Kaidomain which gives strong details - 10, 20 and patterns.
We need someone to make a UV triple drop in with different LEDs for each of 3 LEDs. Then we could have one drop in to fit all of the different nm outputs. :slight_smile: We would have the best of all worlds. :wink:
OK, it arrived. I have a Xenopus Electronix High Flux 365nm UV LED Light.
It uses a Nichia 365 nm UV, it looks like a NCSUO33B LED in the specs…and uses an optic (No reflector), looks sort of Carlco-ish, but square? - About a 10º beam angle…it actually THROWS. :smiley: The LED itself says 365 nm and N1UV-R3, and XeLED…which is different than the specs list, but I don’t know if its just a labeling thing yet or not.
It can take two CR or RCR123’s or an 18650…I popped in RCR’s to see if it came on at least…which it did.
Holy CRAP its SO much better than my prior UV LED’s. Its rated at 450 mW at 365 nm according to the Nichia LED chart. The flashlight itself is rather generic looking, nothing special there…except the optics and so forth at the emitter end.
I haven’t had time to do much more than open the box, load in some cells and shine it around so far…but, so far at least, its a beast. Almost nothing visible, but it fluoresces stuff VERY strongly, and even with just that quick shine around, I think I found a water leak I didn’t know about, due to changes in paint that were completely invisible by regular light, but jumped out under the UV…typically the minerals that are left behind when the water evaporates.
:smiley:
So whatever its got in there, etc, works, and I like it.
I have been out on emergency work since ~ Monday, and need to get some shut eye though…so I’ll try to get some pics/tests later in the week.
That’s what it looks like at least.
:smiley:
And, yeah, that gasket popped out when I was putting the lens back on. (Fixed now)
The body tube screws down into the head with the head’s female threads actually going past the board, so the body tube threads down into the head deeper than the board.
Very nice, Teej! :bigsmile: Thanks for the photos!
Nice. Thanks for all the photos. I just googled the light. Is it really a budget light? Looked kind of pricey.
Well, budget is relative, as I shopped around, and for the specs, this was the cheapest. I use these things for work, so, I have an expense budget to stay within, and, I did, so, it is a budget light in that regard.
:smiley:
I also previously ordered some drop ins and other stuff, but it never put out what I needed, so, for the money, so far at least, this thing hit the sweet spot. For example, there were versions from other suppliers that were 3x as much.
Teej, what are the dimensions of the optic? It looks like a Nichia NIS033, available here: Optics Nichia Luxeon Ledengin K2 OSRAM DRAGON OSTAR BOOMERANG REFLECTOR LAIKA SEOUL CREE XLAMP TINA LISA CUTE FLARE ROCKET
It looks like the NCSU033B may fit on an XM-L star too (well, the thermal pad is the same 2.8mm wide and 4.2mm to supply pads, it’s just a bit wider at 7mm vs. 5mm pads). I want to make a light with this LED. :party:
How hot does the light get? Does it have modes too?
Oh, leds.de have the €mitter on PCB (ugly square) and the Ledil optic too:
http://www.leds.de/en/High-Power-LEDs/Nichia-High-Power-LEDs/Nichia-SMD-LED-UV-NCSU033B.html
http://www.leds.de/en/High-Power-LEDs/Lenses-and-optics/Ledil-lens-21-6x21-6mm-for-Nichia-NCSU033B.html
Congrats on the new light. Glad to hear it is meeting and exceeding your expectations. Nice report. Thank you Teej.
If you get a chance, please look at the back of $5 (USD) bill and tell me how the scattered "05"'s and anything else that pops out looks. I'm going to try to get a refund on the fake 365 emitters I got and need something valid to compare against.
EDIT: I'll try to take a picture for you to compare against, but I don't know how well it will turn out.
I understand. :slight_smile: It lists for $350.00.
My bills were a bit beat up, but, they lit up pretty good…the pics look less bright than in person as my mouse pad was lighting too under the bills and the camera stopped down to compensate the florescent part to compensate, etc.
$5 with UV
$20 under UV
This is the first time I noticed the repeating USA printed along the stripe on the $20…I never saw it before.
:smiley:
Head on
Its square, 21.5 mm
About 14 mm tall
The parts
Better shots of inside the head/tail
I also tried it with two 18350 IMR, and they fit in (As the 18650 width would fit) but were a bit long, so the tail could not screw on all the way w/o incapacitating the tail clicky, etc…so the 18650 or 16340 IMR I have will be its load.
BTW, the pattern formed by those yellow “0”,s in the “20” is called the “EURion constellation”. It causes color copiers to refuse to copy anything that it appears on… like most modern world currencies. EURion constellation - Wikipedia
Wow, that is impressive! Thanks for the pics :slight_smile:
-Jamie M.
I don’t actually need to check currency, I do forensic investigations, but, the bills do provide at least a base line.
:smiley:
Got any UV lit crime scene photos you can share? :slight_smile:
-Jamie M.
No….that ain’t allowed.
:smiley:
If I see something that can’t be associated with a source, I might consider it…but the pics are stamped and p-shopping to remove that would be involved, etc…PITA.
:smiley:
lol, okies :slight_smile:
One of my ambulance driver friends used to send me pics of all the motorcycle accidents he responded to (in order to convince me to give up motorcycle riding), and he got in big doo doo for that too :frowning:
-Jamie M.
Yeah, its verboten. You really never know who might see it, and if for example if by some happenstance it involved a loved one of yours, etc…its traumatic to see something like that online.
Its like doctors discussing a case in the elevator with an unbeknownst family member of the patient along for the ride…its just not fair to the parties involved…they deserve privacy.
For perspective, the vast majority of my investigations lately involve solving environmental safety and health issues, say nabbing polluters more than bank robbers, etc.
I do a TON of investigations that actually just answer why water leaked into a building and if there’s mold, how to get rid of it, etc. I started a company just to do that on a consulting basis. I now am subcontracted as a consultant on the more traditional investigative work, so I keep busy with a variety of things. A lot of skills are very cross applicable,and I’ve been involved in one way or the other since the ’70’s…
Some things add together many facets, for example, I might measure the sound deadening at shooting ranges, and/or calibrate the range lighting for night shooting practice, so we know what scopes/sights need how many lux to shoot what…so I might be out at 3 am with a bunch of people shooting a few thousand rounds down range while I measure the lux on the targets and adjust the lighting while we chat on the radios to see who can do what with what lux, etc.
Or I might be sneaking remote control monitoring stations up/downwind or stream from suspected polluters and collecting evidence over many months to find patterns of releases to the environment that a single inspection would probably miss (Already missed typically…). One plant used a large truck to screen cameras’ views of a storm drain, and once in a while, the truck would cover the hole, they’d open it, do the illegal dumping, close the hole, and drive off again. If they knew you were onsite, they simply didn’t dump…and the fencing, etc, made it impossible to see what they were doing in there otherwise….
…So I set up monitoring stations up and down stream IN the sewers, to compare the water going into the plant with water coming out, and measure/collect the water quality every few minutes….and every night I’d sneak back and recover the samples, swap in fresh batteries for the sampling pumps, etc, and sneak back out undetected (the manholes were under their security surveillance we discovered, they had Jeep Cherokees with bar lights and spot lights patrolling the areas, to report back to base if “intruders” were around, etc.)
Nailed’m too.
:smiley:
Wow, Teej. None of my UV lights even remotely compare to that. Looks great. Thanks for posting those pictures. That totally answered what I needed to know. Thank you again.
Your work sounds interesting and challenging. With the broad spectrum of projects you work on, it sounds like you need to do research at the same time you're investigating sometimes. I'm sure it has some tedious aspects at times, but it definitely not cookie cutter type work.
