Did anyone else see that he attacked the charger with it still plugged into the mains, and turned ON
Then he put that pick through what is presumably Lithium batterys :Sp
I have had just the opposite experience, I have owned 2 Ridgid cordless drills for years, a 12V and a 18V. They both get heavy use and the batteries last about 1 year, when they start to go I drive over to a service center and exchange them. Never been questioned or had a problem doing it, put the old ones on the counter and they exchange them.
As adolescents we used to peer into the windows of local small business to see the Ridgid calenders on the walls. I always associated the brand “Ridgid” with what would then happen at that age. :bigsmile:
Back then, me too, but not from laughing.
That would explain a lot. If you notice in both videos, they each have a tough time breaking the tool. I have a high regard for the quality of the actual tool. They are very rugged and powerful. What I think happened is that perhaps initially there were some instances of poor cells (China) or poor charging circuits. Supposedly that has been corrected and the lifetime service agreement is in place to restore the confidence of customers.
I have quite a few of the Ryobi 18V NiCad tools. Once again the tools are of good quality, but the NiCad packs are soooooooo bad.
I think he is right, see above
Tell me how that works, I also have 12V tools (JobMax and Drill) with LSA. I got them at HomeDepot. Is the counter that you speak of at HD or some local Ridgid service center?
BTW, I like my Ridgid tools. However my EDC is the Milwakee 12V drill and driver combo. It is lighter (probably not as robust at the Ridgid) and came with a nice aluminum carry case.
You are suppose to get it done st8 through Ridgid, just google ridgid service center and try to find the nearest one to you. Some Home Depot will do it but it depends on the store managers. The policy is for them to direct you to Ridgid.
Go to https://www.ridgid.com/us/en/service-centers, fill in your location (you can use your zip code) chose "power tools" and hit search. I have 6 centers within 19 miles of my house.
Two years ago I got a Rigid shop vac to suck the water out of the basement every spring when it experiences minor flooding. Since then, I have used it for vehicles and a fair bit of general vacum duty. So far it has not malfunctioned, but now I’m paranoid that it’s going to burn out next time my basement gets water in it, and then I’ll have to make a video with my ancient ice axe as well.
FWIW, Ridgid tools are made by Emerson Electric. Emerson is one of those conglomerate companies with many brand names. Like InSinkErator disposers, ClosetMaid storage stuff, etc. Mostly they sell to industrial customers.
David Farr, the CEO, has gotten in hot water a few years ago for publicly complaining about the 0bama economy and the high cost of manufacturing in the US. They have been aggressively moving their manufacturing out of the US to China and other less expensive countries over the last few years.
I don't know what they have done with Ridgid Tools, but this might explain a decline in quality.
it sounds like they asked him for a receipt, and there was no tool smashing :~
i keep receipts for anything with a warranty, though some places are using some kind of thermal paper that only lasts a year or sometimes less before it goes blank
One technique that used to work if you lost your receipt, or warranty cost to send it half way around the world at your own expense and then wait 2 or 3 months discouraged you, was just go buy a new one, put the old one back in the box, and return it 2 weeks later. However many stores have got wise to that and now look at the serial number. In the case of a power tool, that means you’re relegated to taking the working guts out of the new one, putting the non-working guts back in, and then returning it, which could be quite an undertaking, especially if you bought a Hummer or Fighter Jet.
Because what if it still didn't work even with Japanese/Korean cells? Then who would they blame? Too much risk, much easier to blame the C-word on the wrapper.
I have measured the voltage of each of the 3 cells.
4.2
3.6
2.6
I am in the process of charging each individually while they are still in the pack. When they are all charged up, I will do a run test and see what happens. Maybe an imbalance occurred because of the charging circuit. But I think what actually happened is that those 2 cells failed. We shall see.
I have 20 IMR’s available from this thread.
I will probably just replace the China cells with 3 of those.
I took a L-ion pack into a Makita store last month while visiting one of my daughters just because. I told them I heard a rumor that they had a machine that could tell how many charging cycles the pack had been through before it failed. The answer was 6.
Turns out the pack draws power for the smart chip from just 1 cell and that is what killed the pack (Sony IMRs, IIRC). This pack was on a work light that I hardly ever swapped into rotation since it was one of the smaller half-size packs.
I never registered it - and it was a year out of warranty - but they gave me a new double size pack to replace it anyway.
