Bolly BL-801 Cree P3-8B 150-Lumen Yellow LED Flashlight Black
Bolly BL-801 Cree P3-8B 150-Lumen Yellow LED Flashlight Features
- Brand new and high quality LED flashlight
- Compact and portable design
- Bolly BL-801 Cree P3-8B 150-Lumen Yellow LED Flashlight
- Powered by 1x18650 battery (not included)
- Coated glass lens and textured Aluminum orange peel reflector cup
- Durable Aluminum Alloy housing
- ON/OFF power switch by pressing the end of the torch body
- One mode reverse clicky
- Bolly BL-801 LED Flashlight with built-in strap for carrying conveniently
- Perfect fit for home maintenance, outdoor activities, hiking, night fishing, camping, caving, hunting etc
URL for this flashlight: http://www.lightake.com/detail.do/sku.30783
901 Cree Q3-WC 3-Mode 130-Lumen Convex Lens Zooming LED Flashlight
901 Cree Q3-WC 3-Mode 130-Lumen Convex Lens Zooming LED Flashlight Features - Brand new and high quality LED flashlight - Compact and portable design - 901 Cree Q3-WC 3-Mode 130-Lumen Convex Lens Zooming LED Flashlight - Powered by 1x18650 battery (not included) - Coated glass lens and Plastic Smooth/SMO reflector cup - Durable Aluminum Alloy housing - ON/OFF power switch by pressing the end of the torch body - 3-Mode: Hi > Lo > Strobe - Features: Twisty head turn right can be square beam of light; Twisty head turn left can be circular beam of light - 901 LED Flashlight with built-in clip for carrying conveniently - Perfect fit for home maintenance, outdoor activities, hiking, night fishing, camping, caving, hunting etc
URL for this flashlight: http://www.lightake.com/detail.do/sku.30786
MrLite LT1 CREE 7090 XR-E R2 9-Mode 230 Lumens LED Flashlight Features
Brand New MrLite LT1 CREE 7090 XR-E R2 9-Mode 230 Lumens LED Flashlight
Pocket size, portable for everyday carry.
Precision optical system, latest orange peel reflector
Mil-Spec type III hard anodized finish, impact resistant
Made from aluminum alloy, really strong
Water proof to IPX-3 standard
IC control
Maintain constant brightness
Variable output mode:
2 modes with 9 types output
Normal mode: lowlight, normal light, high light, strobe, and stand-by
Professional mode: slim light, lowlight, normal light, high light, super light, strobe, low light SOS, high light SOS, and stand-by
Ergonomics design for comfortable handling
Toughened ultra-clear glass lens with anti-reflective coating
Replaceable and rechargeable lithium polymer battery
Low heat emit
MrLite LT1 CREE 7090 XR-E R2 9-Mode 230 Lumens LED Flashlight Specifications
Color: Black
Dimension: head diameter 29 mm, tail diameter 29 mm, and length 112 mm
Lumens & runtime:
Level1: 230 lumens, 2 hours
Level2: 180 lumens, 2.5 hours
Level3: 160 lumens, 4 hours
Level4: 90 lumens, 9 hours
Level5: 40 lumens, 26 hours
Material: aircraft aluminum alloy T6061
Weight: 118.5.0g (exclude battery)
Water proof to IPX-8 standard
Battery: 1 x 18650 (not included)
LED power consumption: 3W
Reflector: OP
Switch: Reverse switch
MrLite LT1 CREE 7090 XR-E R2 9-Mode 230 Lumens LED Flashlight Package Included
1 x MrLite LT1 CREE 7090 XR-E R2 9-Mode 230 Lumens LED Flashlight
1 x Nylon holster
1 x Lanyard
1 x User's manual
UltraFire WF-501B Cree MC-E 800 Lumens LED Flashlight Features
- UltraFire WF-501B Cree MC-E 800 Lumens LED Flashlight
- Powered by 1*18650 battery (not included)
- Maxium Lumens: Output up to 800 Lumens (manufacture rated)
- Glass lens and aluminum orange peel reflector cup
- Constant current circuit, voltage range: 3.0V-4.2V
- Come with Cable Pressure Switch for UltraFire WF-501B
- UltraFire WF-501B LED Flashlight with built-in strap for carrying conveniently
UltraFire WF-501B Cree MC-E 800 Lumens LED Flashlight Package Included
1 x UltraFire WF-501B Cree MC-E 800 Lumens LED Flashlight
1 x Cable Pressure Switch for UltraFire WF-501B
More Ultrafire Flashlight: http://www.lightake.com/products.do/category.176
Romisen RC-27 Cree Q3-WC 3-Mode 100-Lumen LED Flashlight Torch Features
- Brand New Romisen RC-27 Cree Q3-WC 3-Mode 100-Lumen LED Flashlight Torch
- Compact and portable handheld design
- Powered by 2xAAA batteries (not included)
- Coated glass lens and Plastic Smooth/SMO Reflector
- Constant current circuit, voltage range: 3.0~8.0V, 8.0V Max.
- 3 modes: Hi > Mid > Fast Strobe
- Romisen RC-27 LED Flashlight with built-in strap for carrying conveniently
Romisen RC-F7 LED Flashlight Features
- Brand New Romisen RC-F7 Cree Q2 90 Lumens LED Flashlight
- Powered by 1xAAA battery (not included)
- Romisen RC-F7 LED Flashlight with built-in strap for carrying conveniently
Your history of posts and the way that you have read the posts of others makes it more likely that I will order from your organisation. Please make it clear to your competitors that there is a right way and a wrong way to advertise. Seems to me that you have chosen the right way. Keep up the good work.
Product Features
- Super bright flashlight torch
- Powered by 1*3.7V “2400” 18650 battery (included)
- Come with an AC charger and charge dock
- 5-mode switch: Hi >Lo >Mid >Strobe >SOS
- Durable aluminum textured reflector
- Flashlight with built-in stripe for carrying conveniently
Specifications
Lumen: 200-lumen (manufacturer rated)
LED Emitter: Cree Q5 LED
Lens diameter: 44.5mm
Length: 148.4mm
Net weight: 169.5g
Weight (including the packing): 483.0g
Components: 1* Flashlight Torch, 1* 18650 Battery, 1* AC Charger, and 1* Charger Dock
Thanks for you like it ,now there won't have a coupon more than 5% discount ,and next week ,we plan have a promotion only for one flashlight ,and maybe get a 10% discount for this products,which products we still didn't determind ,can you recomment me a flashlight to have a promotion,and this product also have a max amount ,maybe only offer 5pcs for this product can get this discount !
Ok ,i will consider it ,we will have a meeting on monday ,only one product will be promotioned ,and i will make a discussion with our manger ,then determind which flashlight will have a promotion , how many discount will be gaven ,thanks for your advice ,Don !
I just looked at the video of the TrustFire Z1 and it looks very cool since I don't have on like that yet. It would be even cooler if the bottom was magnetic.
