If each LED is being pushed with only 0.75A, gives about 300 lumens, it can easily produce >5000 lumens at around 40W (someone please check my math)!
what do we want to illuminate today?
i am willing to wait for next generation emitters that will have more lm/w and more impressive outputs per chip but there are never too many lumens
More Lumens the better ! i do alot of night Geocaching, backcountry camping, canoeing, boating, biking, etc. and have a high diet of lumens per day. :bigsmile:
kralyevski: Bort: DenBarrettSAR:Now mod this to run 4 - 5 amps to each emitter on a massive copper plate hybrid with CPU liquid cooling with a remote battery pack, maybe a 1000 CCA (Cold Cranking Amp) Deep Cycle RV battery mounted in a back pack. Might make a good flooder. J)
now your talking, but getting maximum possible output would cost a lot of money, xm-l2 on sinkpad/noctigon, i wish companies would start making high Ah NiMH, but any battery that can put out the amps would get well over 20,000 lumens with CPU liquid cooling!
You could buy a Tesla and remove the fuse from the cigarette lighter : :bigsmile:
…and what exactly would you want to “illuminate” with that kind of flood power? Neighbour’s Backyard? and one more thing…what is wrong with ducttaping 18 convoys S2 “in paralell”… J) at least it will be slightly cheaper…
Saft has some 70+ amp NiMH D cells…
Bort:i wish companies would start making high Ah NiMH
can you provide some links?
Nope, got a data sheet from a local battery shop a while back. Can’t find it. I think the Imidion D cells do 40-50 amps…
I wonder if anyone is going to get this light and make a review of it?
These multi-emitter lights are getting out of hand! When will to many be too much? One of us needs to go a head and build a 100 emitter light. :bigsmile: I’m happy with my 12 emitter lights.
Ken
Wow, could this be brighter than the X60?
It has the potential. I’m up to 6980 lumens with my X60vn at the 2:00 minute point while running on 20R’s. Tom basically has that matched with his his 7 led TRJ18. So I’m sure this 18 LED monstrosity has the chance to do even more if somebody could find the right driver for it.
ryansoh3:Wow, could this be brighter than the X60?
The only driver I can think of is the hyperboost. That’s the driver I have in my 12*XM-L2 Courui and my Trustfire AK-90. Its running at about 123 watts right now and its been holding up very well considering the designer does not recommend running above 100 watts.
Ken
Your X60 is dedomed too isn't it? I'd love to see what a light like this can do, but I don't want to throw another 100-200 dollars into it.
ok you guys, found the ultimate deal on this light!
whos gonna do the review??
The Chinese should go back to E.E. classes and design some new drivers. Let’s not mess around and start at a measly 10 amps, and go from there. I want to see 18 gauge wire glow like an incandescent.
They’re Chinese lumens, so half of 12 is 6 = 6,000! It’d beat the X60, but with next-mode memory and the 18-inches of girth, you’d have to be at least 1/2 insane to invest in it.
correct me if i’m wrong. these are the specs,
Flashlights
TAIL-CAP CURRENT 2800 mA
BATTERY FORM FACTOR 26650 / 32650
REQUIRED BATTERY COUNT 3 / 5
doing simple maths,
2800mA, max 5 Batteries,
total Power consumption = 2.8A * (5*3.7V)
= 51.8W
Per LED is taking about 51.8W/18
= 2.87W
translate back to per battery is around 0.77A at 3.7V per LED consumption
Underdriven compared to a C8 with 2.8A per LED driver… haha
= 51.8W
You will be lucky to get 70 lumens/watt OTF, so maybe 3600 lumens total…
sptham30:total Power consumption = 2.8A * (5*3.7V)
= 51.8WYou will be lucky to get 70 lumens/watt OTF, so maybe 3600 lumens total…
Luckily Match posted quite an intensive data on this XML T6 LED.
assuming my calculations are correct with 0.77A at 3.7V, his test results are around 303.5 lumens for that current and voltage input.
texaspyro: sptham30:total Power consumption = 2.8A * (5*3.7V) = 51.8W
Luckily Match posted quite an intensive data on this XML T6 LED. assuming my calculations are correct with 0.77A at 3.7V, his test results are around 303.5 lumens for that current and voltage input. “Test on LEDs”:Results: Testing XM-L, MC-E, SST-50, and XP-G emitters **Updated**
I don't think you're accounting for losses in the reflector and lens.
sptham30: texaspyro: sptham30:total Power consumption = 2.8A * (5*3.7V) = 51.8W
Luckily Match posted quite an intensive data on this XML T6 LED. assuming my calculations are correct with 0.77A at 3.7V, his test results are around 303.5 lumens for that current and voltage input. Test on LEDs
I don’t think you’re accounting for losses in the reflector and lens.
yeap… i didnt do that… just assuming for ideal case? :bigsmile:
