Test/Review of Qlite Rev.A 7135*8 Multiple Modes Circuit Board 3.04A
44 posts / 0 new
HKJ
HKJ's picture
Last seen: 4 days 22 hours ago
DSC_3691 DSC_3693
DSC_3692 DSC_3694
Driver is from Intl-outdoor.com
Official specifications:
  • Input voltage: 2.8V - 4.5V
  • Current: 3.04A
  • Constant current
  • PCB diameter: 17mm
  • PCB thickness: 1.6mm
  • Components height: 4.7mm
  • Memory function (sets in after 2 seconds)
  • No high pitch noises
  • No visible flicker on any mode
  • Reverse polarity protection
  • Gold plated spring
  • Gold plated contacts
  • Copper leads with tinned ends already soldered
  • Low voltage protection: At 2.9-3V the light will switch to an emergency low mode. At 2.8V the light will flash 9 times to announce imminent cut-off.
  • Strobe mode is 10Hz
  • Beacon cycle is 2Hz blink for 1 second, 4 seconds light off
Group of modes:
1st Star : 2% - 25% - 100% (Default)
2nd Star : 5% - 30% - 100% - Strobe - Beacon
3rd Star : 15% - 100%
4th Star : 5mA - 2% - 25% - 100%
Group selection is done with solder bridges, 1st star has a bridge on the circuit board and never need a solder bridge.
DSC_4513
This driver exist in many versions, with the same hardware and different program in the processor (Atmel Tiny13A). These programs control the pwm frequency, the modes and the function of the stars. For the stars only 2, 3 and 4 are used, the first is only part of the design and is not really used. It also means that it is never necessary to add a solder blob or cut the trace connecting it to the ring.
The driver can also have more or less 7135 chips, this defines the (maximum) led current.
Measurements
Tested with: Cree XM-L2 led.
Diameter 17mm
Max. height: 4.7m
Modes no star: low, medium, high
Modes 2st star: low, medium, high, strobe, beacon
Modes 3st star: low, high
Modes 4st star: moonlight, low, medium, high
The mode set selection is done with solder bridges on the driver.
The driver has memory, the actual mode is stored when the light is off for a short time.
A short off/on will select next mode. The light must be off a few seconds to not select next mode when turned on.
Driver is a linear regulator.
Strobe 8.9 Hz, duty cycle 40%
Beacon, pulse width 34ms, repetition rate 4.8 sec
Pwm is 16.5 kHz
The driver flashes a number of times when the voltage is down to 2.80 volt, then it turns the led off.
The four modes banks had the same high mode, but medium and low varies between them.
As usual pulsing current (i.e. pwm) makes it difficult to calculate power and efficiency. In any modes except high I am calculating with a fixed led voltage, but due to the high pwm frequency it is not very precise.
Due to the high pwm frequency the power and efficiency calculations has large errors in the lower modes
High 1st star
Qlite%20Rev.A%207135x8%20HL
High mode works exactly as expected from a linear driver, efficiency goes up, when voltage goes down, until the driver goes out of regulation at 3.6 volt.
At 3.05 volt the driver reduces the led brightness and just above 2.8 volt the led is turned off.
Qlite%20Rev.A%207135x8%20HLDriver
Qlite%20Rev.A%207135x8%20HLLed
The green curve shows the average voltage across the led, below 3.05 volt it is reduced by the pwm.
Qlite%20Rev.A%207135x8%20high
The driver does not disable pwm at high.
Medium 1st star
Qlite%20Rev.A%207135x8%20HL%20medium
Due to the fast pwm, the driver does not turn fully on. This makes the driver drop out of regulation at a fairly high voltage.
Qlite%20Rev.A%207135x8%20HL%20mediumDriver
Qlite%20Rev.A%207135x8%20HL%20mediumLed
Qlite%20Rev.A%207135x8%20medium
Due to the high pwm frequency, the curve it not square, but rounded.
Low 1st star
Qlite%20Rev.A%207135x8%20HL%20low
In low mode the light is never in regulation.
Qlite%20Rev.A%207135x8%20HL%20lowDriver
Qlite%20Rev.A%207135x8%20HL%20lowLed
Qlite%20Rev.A%207135x8%20low
In low the pwm does not even turn fully on.
High 2st star
Qlite%20Rev.A%207135x8%20HL%202
Qlite%20Rev.A%207135x8%20HL%202Driver
Qlite%20Rev.A%207135x8%20HL%202Led
Qlite%20Rev.A%207135x8%202%20high
Medium 2st star
Qlite%20Rev.A%207135x8%20HL%202%20medium
Qlite%20Rev.A%207135x8%20HL%202%20mediumDriver
Qlite%20Rev.A%207135x8%20HL%202%20mediumLed
Qlite%20Rev.A%207135x8%202%20medium
Low 2st star
Qlite%20Rev.A%207135x8%20HL%202%20low
Qlite%20Rev.A%207135x8%20HL%202%20lowDriver
Qlite%20Rev.A%207135x8%20HL%202%20lowLed
Qlite%20Rev.A%207135x8%202%20low
Strobe 2st star
Qlite%20Rev.A%207135x8%202%20strobe
Strobe is 8.9 Hz with 40% duty cycle.
Beacon 2st star
Qlite%20Rev.A%207135x8%202%20beacon
Beacon uses puls width 34ms with dual flashes and a repetition rate of 4.8 sec.
High 3st star
Qlite%20Rev.A%207135x8%20HL%203
Qlite%20Rev.A%207135x8%20HL%203Driver
Qlite%20Rev.A%207135x8%20HL%203Led
Qlite%20Rev.A%207135x8%203%20high
Low 3st star
Qlite%20Rev.A%207135x8%20HL%203%20low
Qlite%20Rev.A%207135x8%20HL%203%20lowDriver
Qlite%20Rev.A%207135x8%20HL%203%20lowLed
Qlite%20Rev.A%207135x8%203%20low
High 4st star
Qlite%20Rev.A%207135x8%20HL%204
Qlite%20Rev.A%207135x8%20HL%204Driver
Qlite%20Rev.A%207135x8%20HL%204Led
Qlite%20Rev.A%207135x8%204%20high
Medium 4st star
Qlite%20Rev.A%207135x8%20HL%204%20medium
Qlite%20Rev.A%207135x8%20HL%204%20mediumDriver
Qlite%20Rev.A%207135x8%20HL%204%20mediumLed
Qlite%20Rev.A%207135x8%204%20medium
Low 4st star
Qlite%20Rev.A%207135x8%20HL%204%20low
Qlite%20Rev.A%207135x8%20HL%204%20lowDriver
Qlite%20Rev.A%207135x8%20HL%204%20lowLed
Qlite%20Rev.A%207135x8%204%20low
Moonlight 4st star
In this mode the current consumption is too low for my "input current" range. As can be seen on the curve it has a resolution of 1mA.
Qlite%20Rev.A%207135x8%20HL%204%20moonlight
Qlite%20Rev.A%207135x8%20HL%204%20moonlightDriver
Qlite%20Rev.A%207135x8%20HL%204%20moonlightLed
Qlite%20Rev.A%207135x8%204%20moonlight
The moonlight mode is simply the pwm at it minimum setting.
Mode4moonlight
Here i have zoomed in on the signals. The MP (microprocessor) gives a two micro second pulse out, but the 7135 is about 2 us (micro seconds) to turn on. This will give a very short pulse to the led and is also very sensitive to tolerances in the driver.
I.e. a 7135 needing 1.8 us to turn on will work perfectly, but one needing 2.0 us will not show any light. The slow turn on looks like it may be because the output from the MP cannot supply enough current for a fast turn on.
Conclusion
Due to the linear regulation in this driver it does only work in a limited voltage range. It is simple construction, that is easy to modify like adding more 7135 (increase led current) or remove some 7135 chips (Decrease led current).
The tested version of this driver has a very high pwm frequency, this does increase the loss in the driver a little bit.
Notes
How do I test a led driver
List of all tested drivers
Edited by: HKJ on 01/18/2014 - 05:08
djozz
djozz's picture
Last seen: 50 min 49 sec ago
Thanks HKJ for testing this very popular driver, it is nice to have the data now to see how it behaves.
sesgum
sesgum's picture
Last seen: 11 hours 38 min ago
Thank you HKJ for the thorough review of this popular driver.
Bort
Bort's picture
Last seen: 1 hour 25 min ago
Thanks for testing this board, it provides me with useful data Smile
The Journal of Alternative Facts TM
"It is critical that there is a credible academic source for the growing and important discipline of alternative facts. This field of study will just keep winning, and we knew that all the best people would want to be on board. There is a real risk in the world today that people might be getting their information about science from actual scientists"
light junkie
light junkie's picture
Last seen: 6 days 2 hours ago
Thanks a ton ! And happy new year btw!
Lj
Lothar
Lothar's picture
Last seen: 3 days 20 hours ago
I always thought that NANJG drivers were "on-time" memory and required modification to be "off-time" memory?
Current Collection:
BLF: BLF-GT90, BLF-GT70 (CW Sliced), BLF GTmini, BLF-LT1;
BTU: Shocker (3 x SST-40 @ 8A)
Solarforce: L2P (XM-L2 U3 @ 4A), MPP-1 (XP-L HI @ 6A), MPP-3 (3 x XM-L2 U2 @ 12A), M6 (Nichia 319A @ 6A), M8 (XHP-50.2 @ 9A), 9x (9 x XM-L2 U2 @ 2A)
Coming Soon: Lumintop: BLF-GT4;
HKJ
HKJ's picture
This driver does remember selected mode.
kralyevski
kralyevski's picture
Last seen: 1 week 4 days ago
is this the same driver as: this
and does it mean that i can use it with unprotected cells because of 2.7v cutoff?
“the easiest way to become a MILLIONAIRE is: first you become a BILLIONAIRE than you start to be flashaholic”
DrJones
DrJones's picture
Last seen: 5 years 5 months ago
Yes, it has on-time memory.
HKJ
HKJ's picture
kralyevski wrote:
is this the same driver as: "this":http://www.fasttech.com/products/1612/10001683/1186301-8-amc7135-2-group... and does it mean that i can use it with unprotected cells because of 2.7v cutoff?
The driver is the same, the software in the driver is probably not the same. The low voltage cutoff is software based and it looks like the one you linked to starts blinking when the battery is low.
If you use cells that can be discharged to 2.5 volt you are fairly safe with unprotected cell on this type of driver, even if it is without any warning, you just has to turn off the light when it gets weak.
Bort
Bort's picture
Does the Nanjg 105C also turn the LED off when voltage is too low?
I know it has low voltage warning but i remember nothing about what happens after the warning
Also they look like the same driver, this one even has 105C written on it, are there any differences besides the 380mA chips instead of 350mA
Hikelite
Last seen: 6 months 3 weeks ago
Bort wrote:
Does the Nanjg 105C also turn the LED off when voltage is too low? I know it has low voltage warning but i remember nothing about what happens after the warning Also they look like the same driver, this one even has 105C written on it, are there any differences besides the 380mA chips instead of 350mA
Nope it does not turn off. There's also the whine present on lower modes (that also depends on hearing condition which gets altered with age, I do not mean sound pressure but frequency range).
HKJ
HKJ's picture
They are the same driver, except for the program in the microcontroller.
comfychair
comfychair's picture
ALL the 105Cs are the same hardware, only physical differences being the number & current rating of the 7135s. Everything else - how it handles the low battery situation, modes, PWM frequency (which is what causes some of them to squeal, and others not), what the stars do (or if the stars are used at all), ALL of that is down to the firmware version loaded on the MCU. All of it can be changed with different FW.
JanBLF
Last seen: 5 years 10 months ago
Just for reference the Qlite in Intl Outdoors ALXM module steps down to low mode. I have mine configured default low-med-high.
My runtime graph is here:
http://budgetlightforum.com/node/27449
Fritz t. Cat
Fritz t. Cat's picture
Last seen: 2 years 10 months ago
Thanks for the review. I am about to attempt to install one. Looks like I will be happy with the driver. Think I will choose the 4th star.
Flashlight designers should look at lighthouses and pottery.
这些谁设计的手电筒应该看灯塔,以及在陶器。
MRTdiver
MRTdiver's picture
Last seen: 6 years 9 months ago
not sure when reading your review...  Does this have PWM on High?
Just want to confirm - there is no PWM on high.
נֵר־לְרַגְלִ֥י דְבָרֶ֑ךָ וְ֝אֹ֗ור לִנְתִיבָתִֽי   (Psa 119:105)
JackCY
JackCY's picture
Last seen: 6 years 4 months ago
Yes it has a PWM as you can see on the graphs because they did not program it in a way without PWM in the 100% mode. So it’s not 100% high but unnoticeable bit lower.
HKJ:
Why did the original Nanjg 105c had a drop at higher voltages and reprogrammed Qlite version did not?
Different measurement? 380mA somehow magically perform better? Or was better cooled?
Another, why do the photos of Nanjg105c and it’s measurement signal a 8*380mA instead of 8*350mA? It’s supposed to be 7135s with 35x not 38x and have 2800mA not roughly 3000mA as in the graph.
Bug somewhere?
HKJ
HKJ's picture
It does never turn the pwm completely off, but you will not be able to see it.
JackCY wrote:
HKJ: Why did the original Nanjg 105c had a drop at higher voltages and reprogrammed Qlite version did not? Different measurement? 380mA somehow magically perform better? Or was better cooled?
The magic is a high speed fan placed close to the driver, i.e. it is much better cooled.
JackCY wrote:
Another, why do the photos of Nanjg105c and it's measurement signal a 8*380mA instead of 8*350mA? It's supposed to be 7135s with 35x not 38x and have 2800mA not roughly 3000mA as in the graph. Bug somewhere?
I cannot answer for what 7135 chips are mounted on the drivers I get.Smile
JackCY
JackCY's picture
Ha!
Sure. I have a few but none 380mA versions and all my 350mA 7135s are marked 35x as in 35 and some random letter, M, P, T, or whatever. Where as on pics in shops I can see on the 380mA versions that they are marked 38x and 350mA versions are 35x. Although those spare 7135s on a reel seem to come from a different supply/manufacturer and are marked differently 7135 1234 etc.
So I think they sent you 380mA version with 3.04A instead of 2.80A Wink
unknown00101
It finally got “warm” enough to step back into the garage for some soldering.
I decided to try the 4th star moon set.
I’m getting: nothing – low – med – high.
Fresh charged KP 18650 2900mAh
XP-G2 on Noctigon
High – 3.00A
Med – .765A
Low – .05A
Nothing – .003A
No output in “moon.”
comfychair
unknown00101 wrote:
It finally got "warm" enough to step back into the garage for some soldering. I decided to try the 4th star moon set. I'm getting: nothing - low - med - high. Fresh charged KP 18650 2900mAh XP-G2 on Noctigon High - 3.00A Med - .765A Low - .05A Nothing - .003A No output in "moon."
Wouldn't happen to be de-domed, would it?
unknown00101
Everything is stock, dome is still on.
comfychair
I've only seen that with potentially not-100%-healthy LEDs, de-doming sometimes screws with the Vf especially at the very low end.
unknown00101
It may not be 100%. It’s a 1A that was transferred from aluminum to Noctigon. Oh well, no big deal. I’ll try moon with a different emitter I guess.
FlashPilot
FlashPilot's picture
Last seen: 7 hours 23 min ago
Bring back to reflow temp and push down on the emitter while its hot. Let cool and try again.
Fritz t. Cat
Maybe some component is leaky.
comfychair
If it puts the right voltage to the LED and the LED doesn't light up, it's not the driver.
Bort
Bort's picture
this may sound crazy, but is the room dark enough when you test moonlight?
Fritz t. Cat
Yes, it could be the led that is leaky or the garage.
unknown00101
Mildly lit room, but staring directly at the emitter and there’s not a hint of light… well that’s interesting. Still in the same room I checked again to be thorough and there is the tiniest, slightest bit of light coming out of the emitter, but it is flickering quite a bit.
Moving into a pitch black room, there is so little light that it doesn’t show up unless almost point blank.
And after turning it back off it’s gone again. Not even the slightest bit of light coming from the emitter in moon mode.
Hmm.
I’ll heat it up in an old skillet in the morning and apply some light pressure to the emitter.
