Doing some Google searches I see that some show as pink like mine yet others show as pure white.
Tbh considering how much I spent I would really prefer if it wasn’t so pink. If I get it exchanged any chance the replacement won’t be so pink? Was really hoping for a more neutral white.
That specific SW45 tint has a color temperature that ranges from 4260K to 4745K, so based on that alone you cannot have a pure neutral white as the words imply.
Wow pretty big range. I guess mine ended up on the low end of that
I’ll email going gear and ask if a replacement if possible. If not oh well. Still better than any other led I have had. I have a NW D40A on the way so guess I’ll see how the tints compare.
Would be nice if it had atleast 1 lower mode. It isn’t too usefull with just the high because it overheats really fast. Cant use it for more than a few min. Have to let it cool down.
I might try putting some aluminum foil or maybe some arctic silver to help with heat transfer.
Define 'overheats' - if you mean it gets hot in your hand, improving the heat transfer between the dropin and the body will make it get hot in your hand quicker. Which is good for the LEDs and the light output. The quicker the outside of the light gets hot, the cooler the LEDs will be running.
Color temp alone doesn't tell you much, look how the color temp changes as you move up-down on this chart...
p.s. Thanks for not allowing hotlinking, flashlightwiki! :angry:
That's only really possible if the outside doesn't get hot. I test little tube lights running at over 4 amps by dropping in a freshly charged battery, switching it on, and letting it run on high until the driver's low voltage protection kicks in an hour later. They still work afterwards.
Just keep in mind that at that temperature pure white in true sense of the word is not possible. You need to go to around 5500K for that but there are no real acceptable CRI for that on the market except XB-D 3C from IOS
You see purely white pictures of Nichia 219AT 4500k CRI92 Beamshots because the white balance in the camera is changeable. This LED is known for pinkish light and that is no reason for sending it back.
Yup you are right I think. My galaxy note 2’s camera sees it as pure white and doesn’t pick up any pink. Overall it’s still far better than the ugly green so it’s all good.
