Call me stupid but how on earth do you get away doing what you do to drivers and they still work? I cannot for the life of me solder one extra chip on let alone 35 thousand of them complete with custom heat sinks. Next time you get your teleporting machine working beam me over. Nice work OL.
It’s very tedious and frustrating doing those chips and trying to add in the copper without shorting it to the pins was just a little over the top. I don’t think I will try that again.
Maybe you could have painted the edge of the copper facing the pins with varnish or polyurethane for a bit of protection?
Super nice OL.... And now I have to say... YEP... it finally got cold in Tyler!! ... Well... Chilly.
That black light with all the filing is another masterpiece. I had a German gent that worked for me at one time. He did a 5 year apprenticeship. 4 of that 5 years... his words were "I learned to use a file". They used files 6 & 8 hours a day. What he could do with a file was unbelievable.... What I see in your images...(and have sitting on my shelf) is highly comparable. What art that is! Absolutely amazing. You make MRs DNF and I struggle to keep up and we use lathes! Beautiful!
As always, Thanks for sharing your talent, time, knowledge and expertise! Dan.
The Black Mag (MT-G2) is finished. Photos in the OP.
What I did was to cut the copper so that it was not right on the edge of the chips, but I imagine a coating could work.
I’m still not happy but nice work. Can you show this poor ignorant sod how the battery holder works on the next one. Thanks.
shouldn’t you have used a thermal paste instead of FUJIK on the MTG 2 build as you are overdriving it to 6A to get better heat transfer ?
and have you zener moded the 16chip NANJG ?
+1
I use Arctic Alumina. I don’t use Fujik for stars or for most applications. Yes, I have the zener mod on any MT-G2 using the 7135 driver.
Yes, I will show the battery holder mod.
2 new OL masterpieces
Added a video on the battery holder just now, at the bottom of the OP.
Pure magic OL. I can well believe it took a day to build. Again I dip my hat to your creativity and abilities. Thanks.
We can ALWAYS count on OL!!! Many Thanks! Dan.
Well, not Always! The Polished light just died! It died a prolonged death, but it's now resting in the big flashlight graveyard, (better known as my dumpster).
The battery holder shorted out and 8 Eneloops gave 'er all they could, as in direct short. Not very pretty, but it was very smelly. It's all my fault. I know what I did wrong and it was something that I saw, but didn't remember to do before I tried out the light. The first time I put the holder in, it worked fine and it was bright as hell, with a really tight beam, but the second time, positive to ground ended up melting the holder and the switch before I could get it opened back up. I think the drivers survived and possibly the led, but the holder went bye bye, along with the switch and most likely, four Eneloops.
I then decided to just go with one 4x holder and make it a cut down. Bad luck continued and I managed to ruin the body for good, so it all went bye,bye. Many not very nice things were said, some of them I didn't know I remembered, because they were in different languages. Anyhow, the builds are done. 50% survival rate isn't too good.
You and I both are not doing too good with lights at the moment. After the PM I sent you the other day I’ve been gardening ever since. The place looks really nice outside at the moment.
Sorry to hear about the #2’s demise…
In the adventure sports world, they say “If you’re not flying (crashing), you’re not trying.” Hope you appreciate that we’re learning from your experiences.
Maglites are pretty roomy, I wonder if a 10-15A fuse could be incorporated into the battery carrier.
AAARRRGGH!
I’ve made a few springs glow myself and it royally sucks. Condolences.
