Received mine today, no charger head
Received mine with no charging head as well.
Got mine today, and no charger head either, even though the label on the plastic bag said "SKU104954 with charger head"
I like the design, quite compact and nice.
Heat transfer to the body is very good; there's no pill, the LED MCPCB sits on a shelf that's integral part of the body.
Measured 2.5A / 0.8A / 0.2A; quiescent current is only 1.3µA, quite nice.
I don't like th UI though: When off, a not too short press (about 1/3 s) is required to turn it on. When on, short presses switch through the modes (H/M/L), and a quite long press (a bit more than 1s) is required to turn it off. I haven't found strobe or SOS yet. There's a red indicator LED opposite to the switch for low battery indication. Also med and low have an ugly ~170Hz PWM.
Unfortunately there's not enough space in the head to put a NANJG105C there, so modding with a better UI will be difficult.
No room for DrJones driver, no buy.
Thanks. :)
Geez, I like this little light. I might end up designing a driver PCB for it.
Oh no! One of your drivers would make this light perfect, I was looking forward to fitting one.
Me too....
I'm thinking of getting another one. Unfortunately the coupon has expired... I really think I'm going to make a driver for it.
I’m thinking of getting another one. Unfortunately the coupon has expired… I really think I’m going to make a driver for it.
Yes Please!!!
Couple of things about this light, previously though no protected batteries would work but the Keeppower Panasonic 3100, 3400 and Xtar 2600 work, probably any battery with a Seiko protection circuit. Protected Banggood/Wallbuys/Fastteck Panasonic, Sanyo, and Samsung don’t work.
This is one of my favorite lights, the only thing I don’t like is the power button is too easy to push while carrying in a pocket. Was thinking about getting a stainless steel washer and gluing it around the power button for protection, any suggestions. Know I can unscrew the head a little to break contact but not really wanting to do that.
Interesting…my WB protected Panasonic batteries fit in F6
Same here.
I have protected 3400mAh panasonics recently bought from wallbuys and a set ordered a couple of months ago from fasttech. Both fit without any problem or trouble with tightening.
This thread is really making me want an Olight S20.
40 bucks, 2 day shipping and I know it’ll work. Added to cart
So i recieved this light i ordered today. Love the light, it has three modes, and very well built. but one problem is that i ordered it with the Charger head option, and never recieved the Charger head !
- Now im waiting for a response from them to send the missing part, or black-list Banggood off my future orders list.
Banggood really left a bad taste in my mouth. Look how many Roche f6’s they sold. I started this thread but never got one. Lol. 2 months now or something and no light . And they stiffed a bunch of others out of the charger head. They probably operate out of the back alleys of shenzen.
Finally received the light , originally ordered Nov. 27th,2013 . Ordered with a charger head , but as many others - charger head is missing .What is worse - the light does not work . Tried it with different Panasonics,Samsungs , LG - no go.At the beginning , maybe 7-8 times the light came “On ”, very low - similar to Zebralight 0.2 lm . Stayed “On” for a few seconds , and then turned off by itself. Now does not even turn “On” any more.Otherwise - it is a beautiful light , both protected and unprotected seem to fit fine. Any advice ?
Record a video and send it to their customer support.
May be It’s loose of Star Brass plate.make sure you will screw it fit with pcb driver.
and be careful short circuit between B+of battery and Star Brass plate.
Welcome to the “missing Charger Club”.
i reiceved mine and the Charger head was missing when i order the charger head. They send me emails telling me they now sent the charger head to wait for 15 - 25 days for it to arrive.
So alteast i know im not alone getting stiffed in this “deal” in the first place.
the light i recieved works fine, with both protected and unprotected. im guessing you recieved a bad light. contact them asap about the missing charger and the faulty light.
Try it with unprotected cells. You know the button has to be held down for a second or two to turn the light on. You probably know, just checking.
