Yeah I actually had one without the stepping so I just drilled until I got to the right size, the steps should be known diameters so that should actually be easier. I think what helps is the cuts are gradual and the previous step acts as a centering hole for the next cut. They’re also perfectly round except for where the cutting edge is recessed so I’m sure that also helps avoid wandering compared to helical drills.
You mean the acrylic lens right? I’m still really impressed with mine so hopefully you will be too, no scratches yet either !
i wish mine will get here all ready its been over 4+ weeks from KD, if i go this route like Ouchyfoot did i will not use the rubber boot, ill have a little piece of aluminum machined to fit the hole ?
true luck there it took one of mine 41/2 weeks and still waiting on my other
judco switch 10 amps >)
how thick the button it
and how far it sticks out as shown on the right
Also im going to the harware store and im getting a stainless steel washer and im going to place it around the click switch to cover up the little hole showing
that im not there yet but by the looks of it i should have around 12-15mm of space, but im working on a driver i might use sorry no pics/info on that yet
EDIT: my copper slug will be 34mm wide and around the same long and will be machined at the end for the driver
