It's not too bad, although the S3 is a bit harder since you have to work through the battery tube. To remove, start by loosening the bezel then work from the bottom, you will need something long and pointy so that you can grab onto the solder blobs on the edge of the pill. Be extra careful not to hit the 7135s, the added ones will bend or rip off if you put too much force on them. The pill will leave through the lens side, not the body. When you reinstall, thread enough so that the bezel is putting a decent amount of pressure on the whole assembly when tightened. You will need to hold the pill in place while you tighten the bezel. It shouldn't be a problem, but try not to twist the wires more than necessary.
[quote=nofearek9]
for mod did the light has another pill ? since the stock pill if for 16mm pcb led.
[/quote]
It is the stock pill that has been solder filled then sanded down. The triple MCPCB has another bare triple MCPCB flowed onto it for more thermal mass and to take up some of the extra space.
I noticed the bezel was very tight. Could not screw it off easily.
Actually I just managed to unscrew the bezel off. And I got the optics out easily. It seems not necessary to mess with the pill to swap the optics, right? Just remove the bezel, take out the old optics, and put the new one in. Are you talking about changing the emitters too?
Also I did notice the pill will rotate along with the optics when I tighten the bezel, but not a lot.
Thanks Richard!
I think I have a few grey hosts (like Sesgum's) that I will be able to use. There are more black hosts on the way that should be here next week. I will probably add some more either tonight or tomorrow, depending on how the builds go. I don't want to get too backed up and have people waiting too long, but it is a long weekend so I should be able to get everything finished.
Hi ; I was looking at your beam shots of the lights and really like the dry cw de-domed beam. Iām not familiar with that light, could you tell me what it is? Thanks
It is an early form of multi-XML light, high power high output.
Comparable to skyray king, which came a lot more popular after DRY.
If you like DRY, you should be able to get a skyray king and dedome the emitters. The trick is to start with xml2 1A. After dedoming, the tint is neutral white, without yellow or greenish.
I agree that it has a very unique beam pattern different from either reflectors or convex lens. The huge spot is like the flood mode of zoom like, but there are still spill in a even wider range.
That looks like a really cool light, thanks for sharing! Iām going to try to MTG2ify my C12 with led and driver from Richard. Should end up somewhere around 2400 lumens OTF, Iām hopinā.
I hope the questioner has some knowledge of flashlights and their ālingo.ā With only 1 post Iām not sure. If I were to mention a dedomed emitter to some friends they might just shake their heads at me and roll their eyes. I personally donāt have a clue what it is, but Iāve seen it used often. I think it has something to do with Yosemite.
Although a new poster I have been following the forumās for some time and I just became a member. I have to admit some of the lingo can get confusing. There is a lot of knowledge in this forum and I hope to learn a lot. I am familiar with de-domed emitters, and I am amazed at what can be done by the members of this forum.
It's nice. Unlike some throwers, it has enough spill that it should still be useful for walking without needing another light to illuminate the few feet in front of you. I should get mine this week.
Getting rough here too!Iām about 10 miles south of Hanover PA.Itās been snowing hard here since 8 this morning.I hope that the mail gets through, my triple that Richard built is supposed to be here.Hopefully I can use it tonight while I shovel.-Rick
