i just bought one……… cant wait
He ships very fast
careful the seller doesnt figure out the deal like the toshiba packs and bump the price.
bet they still have all they had when they bumped them up.
i would hit this if i didnt have a source of free packs to rob cells from.
Got my order today. So delivery was fast. Having a heck of a time opening up the pack that Dchomak purchased. I can see color of cells. Appears to be Samsungs.
The 12 pack is a genuine Toshibia OE pack. Was in factory sealed box (had tamper proof label that had to be cut to open box). I'm not familiar with the cells. Each cell is labeled "SF US18650GR" and "T 6B116MG15K". Each cell is at 3.75 volts. First pack I ever opened with all cells the same voltage.
EDIT: Based on this thread, it's a Sony. I haven't found any date codes on the cells.
8800Mah pack
So you can pretty easily assume it's a 2200Mah battery 4x 2200=8800
Wow, 12 cells for $12.99 is only $1.08 per cell. DBCstm mentioned that kind of price earlier. You say they all measured 3.75 volts. Are you sure you didn’t mean 2.75? If they were 3.75, I would have to think that pack has not been sitting on a shelf that long. I may have to order one of those now.
My second 6 cell pack came in and it too is great. And now for the second time, that deal has been re-listed, but still at the same price of $9.99. Still shows the same “only 3 available” even though many more than 3 sell.
EDIT: Here is the second new link
http://www.ebay.com/itm/New-Genuine-HP-6-cell-Battery-Series-VN06-CB87-NB800AA-/191052147627?pt=Laptop_Batteries&hash=item2c7b986bab
They sold 9 more under the 1st new link and 3 more already under the 2nd new link, all the while having only 3 available.
I really like this seller, I have ordered, and have already received 2 HP HD web cams. Most of their stuff is new, old stock HP parts and components.
Yeah, 3.75 volts. Near perfect voltage for storage. I was surprised by that too. I have the cells resting right now to see if any will drop in voltage. I will then start charging and check the capacity of a few.
Sony cell info I have gathered from this site (appear to be 2200mah, 2004?):
Sony lithium ion cells look at the first two digits in the second row.
8A = 2600mAh
G7= 2400mAh
G6, 6A, 6B= 2200mAh
G5= 2150mAh
G4= 1950mAh
The last 5 digits of that row tell the manufacturing date.
digit 1: year. Q=2008, R=2009, S=2010 and so on
digit 2: month. A=Jan, B=Feb, …J= Oct
digit 3+4: day
digit 5: electrode history
Thank you for the info Jaidmaster. If I'm counting right, these cells were made on July 15, 2005. Seems quite possible as I would expect these batteries to be from old discontinued laptops. How my pack kept a voltage of 3.75 is something I would really like to know.
It's going to be interesting to see how they perform. If past history repeats, I expect that they will perform close to like new.
3.75V is right in the recommended long term storage range, and should equate to somewhere around 40% of it’s full capacity. The capacity loss at that voltage is very low… I’m no expert, but do recall seeing a table on li-ion capacity loss over time, and it starts out like a few % for the first month and drops from there. Does not seem unusual to me, and probably have some pretty good cells. If it was not charged to 100% before being packaged, even better.
I think I have somewhere around 80 or so laptop pulls - it’s quite fun. And then finding the best ones for various purposes.
Good luck!
Man this is tempting. Buy one of these packs for using the cells in my ENB power bank and toss my well used laptop pulls! Question: what about this 9 cell pack for $12.99? Any thoughts on if this 9 cell pack will have similar capacity cells to the 6 cell one? I can't seem to find any capacity info for that 9 cell battery.
-Garry
The info I could find on this pack puts it at a 83Wh, 10.8V pack. This would indicate a 3x3 config, so probably 2600mah cells… 83/10.8 = 7690mah/3 = 2562mah cells…
Pack info from here:
Ah, thanks! This is tempting, but I just keep spending too much money. Hard to pass up though. Guess the issue with the 9 cell is that we don't know what cells are inside and we expect the Samsung 26F's 26C's in the 6 cell. Wonder what the chance is that the same Samsung cells are in the 6 cell.
DCH - how hard was it to disassemble that 6 cell battery pack?
-Garry
(EDIT Samsung model #)
I once got a lot of about 8 packs all the same part number and got Sony, Samsung, Sanyo and LG cells from them. Mostly LG and Samsung. One pack each of the Sanyo and Sony.
Edit: They were Dell PC764 6 cell packs…
I got it open easily enough using a 1” wood chisel, the sharp bevel edge inserts easily into the crack, the 1” width gives good leverage for a twist action to pry the seam apart. Not a problem took myabe 5-10 minutes and all the cells were out and separated.
Used a cut-off wheel on the dremel to touch the weld spots and get a smooth surface, kind of like surgery that was.
3 pairs, 2 were at 2.69V, 2 at 2.59V and 2 were at 2.42V. They all charged up well and are holding that 4.19V.
My Solarforce M8 pulls 6.77A through a pair of Samsung 20R’s (MT-G2)
It pulls 5.25A through the Sony UR18650FJ lap pull
These allow 5.75A, so they’re better than the Sony but less than the 20R. Nice compromise, 2600mAh is a good capacity. Happy happy happy!
Garry, my six pack is being a bear to open. It's like continuously welded/glued along the seams. I'm actually carefully biting off bits of the case using needle-nose pliers. I've opened up more than my fair share of packs and this one beats the bunch by far.
1” wood chisel? What a good idea DBCstm. I have a real nice set of wood chisels, but never thought to use them for that. I will try that tonight on the remainder of the pack. Thanks for the tip.
Thanks DBC! Those sound like some really good numbers for laptop cells! (And I caught my mistake calling these 26C's a 26F above - whoops.)
-Garry
LOL, You mean Sanyo UR18650FJ, don’t you?
Don’t worry, it happened to me too.
All those “S” companies, Sony, Sanyo, Samsung, it get’s so confusing!
Confused, but happy still. That’s not a bad way to be, actually
When I ordered 2 packs with the Sanyo 18500's and 2 packs of the (IIRC) Sony 18650's, they over-nighted it via Fedex.
