My charger head arrived so i’m good with Banggood.
My charger head also recently showed up.
I got the replacement Roche F6 from banggood today, not good news
Anyone know how to tighten or at least remove the switch so I can swap it with my other one? How about swapping the driver, anyone opened it up yet?
-Jamie M.
My Charger head still have not arrived.
(Its been OVER 2 weeks now and still have not recieved it.)
Can anyone from BANGGOOD explain this ? …or should i write them off as a bad retailer and Black-list them for my future purchases ?
Do you think it’s the reflector rattling in my video (check two posts up)? It sure feels like it’s the switch but damn right, could be the reflector!! Weird that only ONE of mine does that!
I’ll try harder to get the bezel off.
-Jamie M.
Whoa damn! Put me down for one. I’ll get you to ship it to someone willing to swap it into my (defective) Roche F6!!! Just let me know when they are ready.
And if anyone reading this (in the USA or Canada) is willing to swap the driver on the F6 for me let me know
-Jamie M.
Jamie M. Dr Jones already tried to fit another driver and found it was too tight, not enough room. That is the reason he’s designing another driver.
EDit - …and we have soldering irons here in the UK!
I also had a rattling flashlight (additionally to the missing charger head). The rattling doesn’t stem from the switch, but rather from the glass (or maybe it’s plexi-glass) not thightly enough pressing onto the reflector (as toysareforboys suggested already). You can unscrew the silver part on top, it’s not glued and has a thread to re-screw it again. I used a bench-vise to clamp only the silver part and unscrew it that way. Once the top comes off, you’ll get the glass, an o-Ring and the reflector. I put the extra O-ring that comes with it on top of the reflector (because at least my replacement O-Ring is thicker than the one originally used, the replacement one is supposed to be used for the body-thread) and reassembled the flashlight, and now the rattling is gone. Haven’t documented the process, but it’s been my first time I had to tamper with a flashlight, so it’s very straightforward.
Also, at least judging from the video, you need to press the button for a second or two till the light starts up, those rapid presses you did won’t do anything even for working flahlights.
When I shot the new video I couldn’t remember at the time what was wrong with the original one they sent me. The first one they sent me only works in momentary mode and you’re correct in that you didn’t see it come on in the video because I clicked it too fast
-Jamie M.
I got one of these Roche F6 but just quick question. When they say it is a XM-L2…what is the bin? T6? or U2?
Still a newbie.
I just bought Roche F6 from Banggood and get it from post office.
In their site, they put :
Package included:
1 x Roche F6 CREE XM-L2 LED Flashlight
1 x attack head
Is it anybody received the attack head ? And also I don’t received the strap for this Roche.
Thanks.
Toys for boys ..Use a set of pliers on the ss bezel to get it loose .ifyou nick the ss just hit it with sand paper and then finer and finer and then buff it back to a shine . I broke out the pliers quickly and could have probably gotten mine with lesser means . The usual jar openers / non slip rug rubber wasn't working so I brought out the bigger gun My guess is a couple tuff rubber bands and channel locks . They have little rubber covers for them too if the rubber bands fail you.
There is no attack head they are trying to say you can order it with the charging head or without .. your option ...Why they add the pictures of stuff that doesn't come with this light is beyond me .
Wake up here banggood you are simply confusing people .
It's a nice light albeit somewhat finicky .
It comes with a clip and thats all . no extra tailpeieces or strap etc . just the light
Welcome to the growing group of us who recieved the light with missing parts.
So what did you get with your F6?
charging head (if ordered)
clip
strap
attack head/tailpiece (as described in text on Banggood) or maybe glass breaking head/tailpiece (as shown in pics on Banggood)
xtra o-ring
And thx for a great forum just joined from Sweden!
Thanks for giving me the confidence to go at it I used channel lock pliers with a thick rubber band and was finally able to get the bezel off! Didn’t leave any marks at all.
I moved the o-ring that was already inside the light from under the glass to on top of the glass and success, no more rattle!
Thanks again
-Jamie M.
The only thing I got from this F6 order without Charging Head Price is Only Flashlight…
They didn’t said that + Charging Head is also + Attack head.
They written it in their site that the package is + Attack Head…
I just realized i never recieved any “attack head” either, if there is somthing that supposed to screw into the threaded base there was nothing in my package… was i missing another part including the missing charger head ?
Update for my F6 driver:
Boards arrived, I populated one (should have made a photo; will do when I flash a new firmware next time) and wrote a firmware for it, based on mokkadrv, but highly configurable, and making use of 2 status LEDs:
By default it has 3 modes, L,M,H (number of modes and brightness levels can be reconfigured).
When off: A short click switches to the last mode (high), a long press starts in the first mode (low), keep holding the button to get to the higher modes. A double-click starts strobe. So no memory - but that can be changed, see below.
When on, a short click switches off, a press&hold cycles through the modes in a L-M-H-M-L-M... fashion.
A very long press/hold activates the battery indicator; the red status LED blinks the number of full volts, the blue one the tenths of a volt, e.g. 3*red, 8*blue means 3.8V.
A 4*click (4 quick taps) let you change the current modes' brightness by then ramping up&down via press&hold, a short click sets that new level - temporarily, i.e. it does not survive a power loss. So you can adapt the levels to your current situation without changing your standard config; but it can be made permanent, see below.
A 6*click leads to lockout mode, the light can be reactivated by a 3*click.
An 8*click brings you to the configuration menu, where you can
- add or delete a mode
- configure whether a short click when off starts the light in the first mode (low), last mode (high; default) or memory.
- configure whether a long click when off starts in the first mode (low; default), last mode (high), memory or ramping.
- permanently save your current configuration, reload it, or restore the factory defaults.
18kHz PWM, step-down on low battery (3.0V), shutdown at 2.8V.
I have plans for a couple more features, and some of them before I'll release these (e.g. currently double-click and triple-click lead to strobe and can't be changed).
I also ordered some components (resistors, status LEDs etc) so I can send kits (board and components) later.
Although I know nothing about the driver part of these lights I am very interested in a dr jones driver upgrade for this already very nice light.
Looking forward to the finished product!
this is a long thread…could someone give me an executive lazy man’s summary?
i got….interesting product, good price, problems with product delivered, and now awesome drjones driver (almost) available
so, if i order one, what issues might it show up with? and is there a review posted here yet?
thanks!
