I will take at least two of these if you do another run.
Yeah, mark me down for a couple XML and a couple XPG if you do these again.
Thanks!
I have put the solder paste stencil up on OSHPARK.COM as a shared project. Download the .BRD file and send it to OSHSTENCILS.COM You will probably have to order two to meet their minimum order. When ordering, specify their minimum sized border (0.75”). Note that I have changed the MTG center pad from the original solid block. Also removed the solder mask from the solder overflow tabs.
just ordered 2, ~$10 shipped
thanks for doing this
just arrived
very easy, very fast, very nice, thanks!
I’m new to oshpark. I found your shared project, but why download the .BRD file? Why not just hit the order button? What am I missing here?
This pattern is just for making solder paste stencils, which OSHPARK does not do. You download the .BRD file and send it to oSHSTENCILS.COM to get the stencils made. The stencil is used to manually apply solder paste to LED MCPCB’s (stars).
You could have OSHPARK make a board from this pattern, but it would not be of much use.
Good thing I didn’t hit the order button :bigsmile:
So glad to have stumbled across this. Now I know how I can get stencils for the triple xml build, yahoo!
Just successfully re-flowed my first LED. Put an XML2 and a new driver into my old Regalight EDC AA size light. Much better. :bigsmile:
Thanks. Which is a good brand of solder paste for this?
I used this solder paste from Fasttech.
It’s apparently a low melting temp solder. Mine melted somewhere around 250f. I wasn’t paying close attention to the exact temp, because I thought it would be closer to 360f.
I used this AOYUE 866 All in 1 SMD/SMT Hot Air Rework & Soldering Station with Pre-heater.
I did have the thermocouple on the MCPCB as it was warming up on the preheater, but I saw the solder melt a lot sooner than I expected.
I’ll do a few more to get a more exact melting point. :bigsmile:
Edit- I just did another one and kept a closer watch on the temperature. The solder liquified and the LED floated into alignment between 300-310F.
My sample of that mechanic solder paste from fasttech melts at about 180-190°C (356-374°F) as expected for Sn63 / Pb37.
Nice to know they’re there and waiting, I have 1 sheet I haven’t used yet, but who knows when I’ll mess up and kill off my stencils. Easy enough to order new ones this way, Thanks TP.
These have made modding an easy task instead of a daunting project!
It freezes fine in the bottle? I tried to Google it but got lots of results about Russia and freezing saeawater, some stuff about freezing flux in plasma, and ‘setting’ solder but nothing about freezing a bottle of flux.
Looks like I need to test the calibration on my nifty new hot air station’s thermal sensor. Or maybe I just didn’t have a good enough contact with the MCPCB. I’ll put a dab of heatsink grease on the sensor and try again.
We were wondering where this project came from as we’ve seen this stencil come through our order queue about 20 times, and now we know what it’s for!
Thanks for all your support LED fans, for those that don’t know, OSH Stencils has 3mil and 5mil stencils now, so if you need a little more paste for this application be sure to select the thicker material.
Cheers!
-B
Ha.
How did you track us down?
I hope it wasn’t due to the BLF SRK stencil
Welcome OSH Stencils!I think its awesome that you found us. I really like the forward thinking support that you are providing. Members have created a work around to find projects on OSH that are of a common interest by linking them to a thread here on BLF. This was done because of an inability to search for projects on OSH. Is there a possibility of some day getting a search function on the sight? With so many projects there it is daunting and time consuming to look through them all to find what you are looking for and I wonder how many potential orders have been lost due to impatience in searching. At any rate, thanks again and welcome.
