If this really gets going I'd be in for 20, 9x9mm and that shape sounds very versatile to me. I could do Europe reshipping but I am afraid the dutch post is relatively expensive, and a Germany based member would make more sense.
edit: it looks like I can send it as a letter (max 20 grams, 3.2cm thick), it is 1.05 euro worldwide. But I guess that if nitro can send it as a letter too, it should not be too expensive to send it directly.
I went to USPS.com and selected the calculator and typed in my zip code 43452 and entered Zeremefico location (Greece) and entered Letter @ 0.0440925 = 20 Grams and it says $1.15 ??
I’ll ask around the Korean forums and see if other modders are interested.
Nitro, no offense intended but please make sure the shipping and packaging costs are actually used for shipping and packaging. Many of us received damaged or missing SinkPads because the sorting machines ripped the envelopes open. Also, if you could follow through your orders completely without disappearing for weeks, that would be great!
ill make sure it will go smoother, just to say i did not disappear for just that reason doing a GB is harder than just collecting funds and packing and shipping ect......(and i believe everyone got a refund/order re-shipped?)
but i still would like to have few RE-shippers for each country so that does not happen again and we all can pitch in for somewhat tracking to them ?
and for the US buyers it will be mailed in a Priority box so that way everyone has a tracking number UNLESS u want it shipped cheap ?
It would be interesting if someone could compare the resistance of these to the ones from FT. Relic noted that they might be a beryllium alternative and delivered low resistance with good performance. Post 52.
OAL, Wire Diameter, Base diameter, Top diameter, Temperature range before spring tension is lost, Compression rate, (how many pounds of force to compress the spring).
I would be in for 50 to 100 if the specs come out good. I don't want a spring that compresses easily or looses it's spring when soldered, as beryllium does sometimes.
If this is the size of the spring in this group buy it is mostly interesting for small EDC type lights, while beryllium springs makes a real difference at many amps. I'm still in for a few though, but only about 10. If the springs are bigger, say diameter 10mm, length 12mm, I will want more.
