who wants beryllium springs
I went to USPS.com and selected the calculator and typed in my zip code 43452 and entered Zeremefico location (Greece) and entered Letter @ 0.0440925 = 20 Grams and it says $1.15 ??
I’ll ask around the Korean forums and see if other modders are interested.
Nitro, no offense intended but please make sure the shipping and packaging costs are actually used for shipping and packaging. Many of us received damaged or missing SinkPads because the sorting machines ripped the envelopes open. Also, if you could follow through your orders completely without disappearing for weeks, that would be great!
ill make sure it will go smoother, just to say i did not disappear for just that reason doing a GB is harder than just collecting funds and packing and shipping ect......(and i believe everyone got a refund/order re-shipped?)
but i still would like to have few RE-shippers for each country so that does not happen again and we all can pitch in for somewhat tracking to them ?
and for the US buyers it will be mailed in a Priority box so that way everyone has a tracking number UNLESS u want it shipped cheap ?
I’d be in for 20-25, as long as shipping isn’t more than 1/4 the total cost
maybe Hikelite could order 200-300 and distribute them in Europe if he is up for that :slight_smile:
It would be interesting if someone could compare the resistance of these to the ones from FT. Relic noted that they might be a beryllium alternative and delivered low resistance with good performance. Post 52.
In for 20 please. Thanks for the effort on this Nitro!
another member from Michigan that's very close to me
All the specs on the springs please?
OAL, Wire Diameter, Base diameter, Top diameter, Temperature range before spring tension is lost, Compression rate, (how many pounds of force to compress the spring).
I would be in for 50 to 100 if the specs come out good. I don't want a spring that compresses easily or looses it's spring when soldered, as beryllium does sometimes.
More info here >>> http://www.leespring.com/product_spec.asp?springType=C&partnum=LBC028A01AAA
Thanks. Here's the specs.
Specification
Part Number
LBC 028A 01 AAA
Outside Diameter 0.216 in
Hole Diameter
Wire Diameter 0.028 in
Load At Solid Length 2.135 lb
Free Length 0.355 in
Rate 9.37 lb/in
Solid Length
Rod Diameter
Number of Coils
Total Coils 4.7
Finish PRE-COATED WITH SILVER
Material BECU
That equates to:
OD 5.5mm
Free Length 9.0mm
Wire Diameter 0.7mm
Appreciate the info. I will need to pass, too small for my needs.
Thanks
If any other Aussies want in on this I'll reship for us if needed.
If this is the size of the spring in this group buy it is mostly interesting for small EDC type lights, while beryllium springs makes a real difference at many amps. I'm still in for a few though, but only about 10. If the springs are bigger, say diameter 10mm, length 12mm, I will want more.
… and wire diameter of .9 - 1.0mm
I’ll take 10. Just let me know when this will happen.
I’m in for 20.
Thanks. Generous offer.
Thanks Mattaus this will help me out a lot
What's the alloy used for these springs, there are several beryllium copper alloys.
If they can do this, I'll take 20 for sure!
http://www.youtube.com/watch?v=BFyWPeou4Gc
