Opps....yeah must consider that. Does the O-ring sit in the same position as the Sky Ray 3xT6 or similar torch? So that you need to put pressure onto the O-ring for waterproofness. Can just unscrew the bezel a bit and shake it.
Well my TF X9 arrived today!!! Shipped on 7/18 came 7/21 from HONG KONG!! Fastest shipping Ive ever had come from China!! Here is the link of the ebay seller: Five stars for cyberport888!
The light came very safely packaged, small cardboard box. The X9 was bubble wrapped securely .Along with the light came a nice quality silver lanyard (exactly the same 4sevens gives) and instruction and warranty card. I did notice a very small abrasion on the bezel ( Possibly scratched during packaging) other than that the fit and finish is top notch. Looks alone you would think it cost $100 + but nope only $35.49 AU (Bought off Ebay AU). Threads were dry but that's a easy fix (Applied super lube). Reflector was free of any artifacts or finger prints as well with the glass lens.
After reading the instruction manual , voltage range printed said 4.2V-8.4V so i trusted their word but i got burnt ! I used 2x Solarforce 16340 both were measured at 3.9V (7.8V). Light turned on seemed fine, changed modes fine, until i took a tail cap reading.. 5.1 amps! I knew this was really high. I heard a buzzing sound so i turned off the light and took out the batteries. Next i put in a fresh 18650 flame, light turned on but would not change modes, only stayed on hi.
What do you think happened? I'm still learning so all the help is greatly appreciated.
After looking at manafont they state voltage range is up to 4.2V, I should have looked there first!
