I am thinking of buying the TK-566, but I would like to see one more photo (comparison if possible) of how well it does on Cat Urine. I have a UV/white light head lamp that I used for night fishing, but it has so much Visible wavelength, it does not flouresce cat pee at all.
Does anyone with the TK-566 have a bad cat and a camera that will catch the result?
Thank you djozz!
I have been doing a lot of research on the 365nm lights, but I am curious how the TK-566 with the CREE chip compares to a “365nm” LED. I saw one that looks promising which costs only $18. It’s called “Peedar”, but I have read that cheaper uv “claiming” 365nm is In fact not. $60-$80 for the TK is pricey, but I want to track down this little booger’s Hot Spots and take care of them, even if it costs a lot.
Tiger Fusion, it’s worth mentioning that the original review in this thread was three years ago. I wouldn’t expect to get a response from the original poster.
Also, UV protection glasses help a lot when trying to see fluorescence. They typically don’t cost much; even the yellow party glasses I got at a dollar store work reasonably well.
I picked up a pair of those. They really, really cut out the blue and purple light. Probably some green, too. It cuts out so much, actually, that I have a harder time seeing UV fluorescence with them than I do with cheap yellow dollar-store glasses. Even under a UV light, everything looks orange. So, that was a bit disappointing. However, they might also be rather useful for a test I’ve been meaning to run for a few years… getting myself to be sleepy earlier by wearing blue-blocking glasses at night.
As for the CREE XR-E issue, I assumed that sellers were using "Stock Photos", however, the UV TK-566 in this UV Flashlight Shootout by "mfm" has the CREE XR-E logo.... I am still confused :-(
I have been looking at the Tank007 TK-566 UV Flashlight, but have questions about the LED's and did not want to order from Overseas this time.
I stumbled upon an unusual "Budget" flashlight with a strange name. It's called the "PEEDAR". Yes, it is marketed as a Pet Urine Detector and is rated at 365-370nm. Here is a photo from their site. (urineeradicationsystems.com )
I have not mastered the art of UV photography, but the next photo (from their site) shows the difference between the Peedar and my So Called UV headlamp, which must be approx 400nm.
I am impressed so far! As with decent 365nm flashlights, when shining on a non-fluorescent surface like a painted wall, it gives off a dim White light, not Purple like the headlamp. I got it on Amazon.com for $18.99, free 2 day shipping with free month trial of Amazon Prime. I think I bought the last one, 'cause they are not available right now, but the manufacturer stated that they will be supplying Amazon with more (that is, the USA Amazon, I believe they are available in other countries on Amazon)
Ok, so... Yes, it works best in the Dark.... Ok, pretty much Only in the Dark. It is not a Super Power Lamp that a Carpet Cleaner would use or a Forensic $300+ Flashlight, but for $19, I totally expected that. I Did find something on my Driver's License that I never knew was there (sorry no pics yet, but I will work on it). I would like to find some cheap Fluorescing Minerals like Calcite, Hardystonite, Willemite, etc to experiment with my kids (which fluoresce under 365nm ).
Minerals need various wavelengths to fluorescence, depending on which one it is. Many need considerably lower wavelenths than 365nm, so using a broad spectrum (and cheap!) UV-cfl tube works much better than a led.
Ahh, yes, that bit after the Tank007 logo. The OP was quite a while ago and Tank probably had surplus bodies so rather than produce a new run, they just used the surplus. The new TK566 bodies just has Tank007 printed on them
Sparkfun has just released a UV light sensor board for measuring the output of UV lights. It puts out an analog voltage. Runs off of 3-4.5V Sensitivity peaks at 365 nm, but is usable down to 400 nm or so. Output curve is fairly flat from 300 to 380 nm.
My KD drop in just arrived today so I've been checking it out and comparing it to my Inova X5 UV
general impressions of the KD: sloppy soldering, gets hot fast on 2 cells, output seems to drop erratically (possible host issue but possibly heat), really makes stuff glow in the hot spot but not so much on the spill.
I couldnt find anything that would only glow using one of these lights and not the other.
Neither of these lights make any part of Canada's new plastic bills glow but aparently thats how it should be.
All in all I think I prefer the floody light of the Inova most of the time. The price of the single mode Inova has come down decently too.
FYI a company called YellowJacket sells a rebranded Inova X5 UV that costs more and is not as good. They replaced 2 of the UV LEDs with white LEDs so my coworkers Yellowjacket wasnt able to pick out the UV dye traces my Inova could.
FWIW, I’m waiting on a KD drop-in. I ordered it plus a SF L2m host on the same day. The L2m showed up today, but the KD drop-in apparently hasn’t even been sent yet (it just recently changed state to “order pending-packing”).
After it arrives, I’m planning to drop by the bank for a set of fresh US currency, to test how it responds to my two UV lights.
That KD drop-in just showed up. So far, I can say it’s quite a bit brighter on 2x16340 than it is on 1x18650. Both visually, and by measurement.
The current seems to increase with voltage. I measured a few different batteries, and got:
0.1A at 3.6V = 0.36W
0.2A at 3.8V = 0.76W
0.36A at 4.16V = 1.49W
0.6A at 7.9V = 4.74W
At 4+ watts, I don’t even need to go into a dark room, or get close to the objects I’m trying to light up. And this is with the lens on; I haven’t even tried it with the bare emitter. However, I’m a little concerned about heat, because the drop-in doesn’t fit this SF L2m very well. Neither the pill nor the reflector make much if any contact with the body, and it seems that the heat is only transferred via the spring (which fits so tight that it shaved off a bit of metal while screwing the body together).
However, even at just ~0.36W, it still fluoresces things better than my cheapo 3xAAA ~375nm light. Before using this light, I never even noticed there was a big red/green-checkered “20” printed on a UK 20 pound bill. Also, things light up in color now instead of everything being bright green.
Hopefully I can get some beam shots up soon, but I’m kinda sick and trying to rest.
Hello all. I’ve been following this thread for a little while, and I was thinking about taking the plunge. I’m thinking of going the 365 nm route for a wide-range of things, from checking bills (more curiosity than anything else) to looking for bodily fluids (to gross me out when I stay in motels) to geocaching.
One route I see here involves buying the Ultrafire 1000 LM WF-502B and the Kaidomain dropin —did I get that right as far as the pairing? Another involves buying something like this, which I know nothing about other than Amazon reviews.
Since this purchase isn’t going to be for something I’ll use regularly (as compared to my “standard” flashlight collection) I’m not looking to go towards the higher end (certainly under $50). So… any thoughts? Am I wrong to stick to 365nm lights?
