Filing the base of the T08 reflector did increase the lux by 8%. I’m only getting 151kcd before. After the filing, its 163kcd. I would just leave the micro dust particle as it is for now. I can’t risk another damaged reflector.
Try to wash it with water+some liquid soap (do not touch it with anything,just let the water flow).After that rinse it with pure alcohol and dry it with hairdryer(dry it from outside!).Oven would be probably better(no moving air-less dust).I tried this few days ago.I had one reflector with a lot of dust,and even some grease-like spots.It worked much better than I thought,reflector is now almost like new.
Just finished washing the reflector with warm water and hand soap solution. The result is a good as new reflector after drying it in front of the fan. Thanx for the tip led4power!
As led4power said, wash it with water will do. I just bought a ball blower like this . Not sure if it is strong enough to blow away the dust and particles on the reflector, never tried yet.
…but since I have washed it quite many times already my T08 reflector is damaged and scratches are everywhere now, perhaps it doesn’t do 190~200kcd anymore. :bigsmile:
Total newbie here, though tinkering with electronics for many years.
I just bought 2 of these (no name) for $40 US delivered.
I may be naive, but I just want to use these as a housing
and put in a new driver, springs, etc.
V10+ 2.7~4.5V XML-T6 4-Group 1/3/4-Mode + 1~100
Ramping LED Driver Board 5000mA / overheat protection (55-60℃)
FastTech’s test results: 4/23/2013: 4450mA @ 4.2V
I hope to get about 1200 lms.
I hope to use with EBL 2600ma cells. Paid around $2 each new. Normally close to 3.
Comment on these cells from Amazon.
This review is from: EBL® 4 Pack 18650 3.7V 2600mAh Rechargeable li-ion Battery
These batteries supply my Itaste VTR vape stick. Each battery lasts for over a week before the scale says it has even moved from the full charge.
This leads me to believe the capacity is there and the ability to supply at least 3A per cell.
1 more question.
Anyone suggest a nice holster for this light?
I can’t comment on the batteries, but the ‘V10’ driver is rubbish. Quite a few people got them when they came out, myself included, & they fell way below their rated output, & had a ‘clunky’ UI.
Look into the FET based drivers that have been developed here by BLF members. You can throw one together yourself from parts, or get one ready to go at Mountain Electronics
40$ per piece or for both?
2$ battery is with a high chance junk.
V10 is definitely junk and not made for eswitches
You need a driver for a momentary switch. There are lot of customs programmed drivers available, nanjg, nanjg with stacked chips or like above suggested aFET driver….
For ME they are a poor choice though there was one combination 4*7135/FET driver that looked interesting.
I prefer a regulated driver @ no more than 4.5A. 12*7135 might work well.
This will allow me to not have to modify the heat sink too much, keep light output more constant,
and still get around 1200 lumens which is enough for me.
I’m not trying to make a superlight, just a reliable, economical one with excellent throw.
If it matches my EAW8 I’ll be happy.
I think I’ll wait until the lights arrive in a month or so and see what needs to be done
before I make any changes and shoot off my mouth here.
It will only be regulated as long as the battery voltage stays above the LED's forward voltage required to do that current level. 4.5A needs around 3.7-3.8 volts. Starting from only 4.2v no-load that's not a lot of runtime before it starts dimming.
About the UCL Lenses, I think you have a misunderstand with it.
UCL means Ultra clear lens, it usually made by resin instead of glass.
It is a new material for lenses.
Actually, Lenses made by UCL is more lighter than glass, and it is not easy be crashed.
As the impact resistance of UCL lenses is better.
The transmission of light of UCL is equally to glass lenses. (not true: 97 vs 99%)
Damm, this adds up fast, but considering I just bought my girlfriend a new Honda I guess I’m allowed my simple pleasures.
I actually wrote the response below to FmC much earlier today, then had to take a friend to the doctor before clicking save.
Actually EBL is a very reputable company with their AA/AAA NiMh cells outperforming generation 1-3 Eneloops for capacity. (not the XXX)
Cycles rechargeable. . . . not enough data yet.
The reason I got the 18650’s so cheap is that the seller (Aibocn) messed up the shipment and when I called them on it they shipped me a new order for free, letting me keep the partial order.
I can get various Sony, LG, Samsung, Efest, MNKE 25-2600mah 18650’s in the $4-5 ea range
ex: Samsung ICR 18650-26F 2600mah $2.84, ICR cells which should take more charges,
or buy the Acer laptop batteries described in a thread elsewhere here and recover the individual Samsung 2600mah cells for ~ $2 ea.
Considering the cost benefit ratio of a $2.80 EBL, at full retail, in 8 packs, or Samsung ICR 26F @$2.84 2600mah vs a $6.84 3100mah Efest cell (remember I only need 1.5A continuous) I’ll take the cheaper and carry a spare cell.
All above are unprotected cells and I know the dangers, and always check, and match my cells using a Nitecore D4, fluke DVM and Dale discharge resistors feeding my PC’s serial port so I can see what’s going on.
Forgot this is a parallel battery setup, not series with higher voltage.
OK, FET drive sounds like the way to go.
I’m going to wait, read this thread several times more, then make some decisions.
One other thing, this is an XM-L T6, not an XM-L2 light.
So now I wait. Thanks to all. I have now retired from the field.
AFAIK Bella has no current draw, driver info, etc. on this light.
I just took a chance. Hopefully it will make a good host.
Nationalism is an infantile disease. It is the measles of mankind.
That’s why I posted what I did. That way no disappointed members.
I did read the entire thread, but my memory is not what it used to be.
Fortunately other parts work better.
I plan to purchase two of these lenses myself as well for the two Big Head lights I have modded. From what Linus said about them, they do the trick despite the fact not being glass.
Thanks all.
If you’re curious here’s some of the emails I exchanged with Bella.
Please excuse the flowery language.
That is the culture of China but my Mandarin is not very good any more so I used English.
Price went to 36.99 + 1.25 shipping. I think she forgot to remove the shipping.
My original order did not include the shipping costs.
She also can’t add or more likely was very flustered as shown by her email below.
My final cost would be $27.30 per light, unknown driver, XML T6, acrylic AR lens.
For a host I would take them. For a light I want to do non aggressive mods there may be better choices.
If I can keep these stock except for springs, wiring, tail cap mod, centering ring, cleanup, AS thermal, driver, if needed (I want 4-5A), basically everything except changing the LED, heatsink and the series mod I’d be happier.
My soldering station got stolen in my last robbery and I don’t feel like buying another even IF I could find one here. A cheap soldering pencil will do the other work.
All opinions appreciated, especially from the experts . . . . . hmm, that’s all who have responded so far.
Thanks all. Never knew this could be so complex.
Rich S.
emails below cut and pasted and appear with newest at top.
2014-07-16 00:39:27
Hello Bella,
Jīntiān nǐ yǒu fàn? 今天你有饭?
Hurry and change your price.
I told some people about the light and they may be buying it.
It sounds like an honest mistake to me.
I lived in Shenzhen in 2007, near the north HK gate, and know how hard you have to work to earn money.
Much competition. Thank you for your kind offer to correct the mistake and I will probably accept it.
But your figures are wrong. You must have been in a hurry.
145+50=195(not 190)*1.1=214.5 RMB or 34.60 USD.
19.99 OR 21.24 if postage was charged to my credit card.
If postage was NOT charged to my credit card you need to fix your system.
I will have to check if the postage was charged or not and email you tomorrow.
I believe I will have to send you more than $13.
Postage charged 34.60-21.24=13.36 postage not charged 34.60-19.99=14.61.
For now I am going to sleep sweet dreams.
Do not worry . . . . . . all will be well.
Rich
Life Easy
2014-07-15 23:11:37
Dear Richard ,
Nice day!
Many thanks for your kindly reply.
As a small seller, we really need to pay more attention to avoid this situation.
Sincerely sorry to let bear of the news.
I edit the wrong price, As the cost of flashlight is RMB 145 instead of RMB 45.
The net weight of the flashlight is 500g. To Mexico the postage of item is RMB 10 per 100g.
SO the postage of each flashlight is 50RMB.
The commission charging of aliexpress is 10%… the exchange rate between RMB and us dollar is 1:6.2
So the total cost of the flashlight is: (145+50)+(145+50)*0.1= 190+19= 209/6.2=USD 33
Sincerely sorry for my stupid mistake. Please accepte my sincerely apology.
In order to show my sorry, I’d like to bear the half for you.
As you have pay for them price at USD 20 each one.
So I’d like to bear 33-20=13/2= USD 6.5
So each flashlight price at USD 26.5.
dear Richard, as a small seller, we will pay more attention to avoid this kind of mistake…
If you think the you still need them, hope we can get your forgive and send us more USD 13 for two piece of flashlights.
If you don’t need it at this price, I can understand you, after all , it’s my fault.
I can help you to cancel this order.
Please advice me…
Any other inquiry, please don’t be hesitate to contact me.
Sincerely sorry for any inconvenience cause by it.
Best regards
Bella
Rich S.
2014-07-15 11:07:02
Hello Bella,
Good day to you,
Thank you for correcting the shipping address.
UCL® is a trademark owned by a lens company and below is their site showing their acrylic lenses.
UCL® glass lenses transmit 99% of light.
UCL® Acrylic (resin) lenses transmit 97% and can melt with very hi power bulbs.
With the LED used in this flashlight a resin lens should work well.
I’m old fashioned sometimes. I prefer glass. But that is just my preference. I know resin works well.
No screen protectors wanted, but I thank you for the offer.
You are doing enough checking the flashlights.
I think I will be happy with these flashlights and am looking forward to receiving them.
Rich S.
Life Easy
2014-07-15 01:54:01
Dear Richard ,
Nice day!
Many thanks for your kindly purchasing and message.
I have advise your shipping address. please don’t worry it anymore.
I understand your worry about the returning.
As a realiable seller, we usually check every items before send them out. please give us more trust…
We can send two pcs of 7 inches screen protectors to you. if you need.
I’m of your good service all the time.
