I would be really happy to have a 2-cell version of this driver.
Sounds great. Hoping you branch out to a 2S version.
Very nice! I am looking forward to this driver.
You should sell this driver through Mountain Electronics. I’ll buy several.
I want one! How much? PayPal ready! :heart_eyes:
Very cool.
Subscribed.
It’s a near perfect driver but since I’m not from USA and wonder how much does it cost to get one if you are willing to send it to my country.
…and the BLF custom driver parade marches on.
Pilotptk explained it and I’ll take his word for it. LEDs are also more efficient at lower currents and pwm is high current, high frequency. Low modes are simulations of low current output but with high Vf issues. 100 % of 1.5A is more efficient than 50% of 3A.
Definitely interested in a couple of these if you offer them for sale here.
Plus it’s less stressful on the LED
interesting.
Everything is the most awesome thing ever, sorry to have rained on anyone's parade.
I don’t want to fan any flames here but I don’t understand this statement. Can someone put it in layman’s terms for me?
20% with a 5A output driver using PWM will do 5 amps for 20% of the time, and 0 amps for 80% of the time. The Vf required to get 5 amps through a XML2 is 3.75-3.80A. Tailcap amps will be a measure the average current, around 1A.
But, a non-PWM constant 1 amp into the same LED only needs an output voltage of 3.05-3.10 volts.
How preliminary is this preliminary? 2 weeks off or 2 months?
Do you have an approximate price range?
Can you expand on how the user can change the modes? IE programmed through the switches or through hardware programmer like the Atmel chips?
BTW: SOOO COOOL! :-D Looking forward to seeing more of these. A lot more!
Yeah CC, That’s the efficiency part. The stress part is that just about any component will wear out more quickly from excessive switching and power usage beyond design parameters and pwm can do both. While we generally don’t worry too much about over taxing our poor LEDs, surviving abuse isn’t the same thing as not being abused and if this driver gets the job done without as much wear we get the power and run time together while not doing as much harm to the emitter or other components. Not a concern for everyone but certainly worth understanding.
Answers to questions:
-yes,I will send one to HKJ,and there will be probably giveaway(4-5 drivers) because I want some input and opinions.
-current can be increased or decreased by changing sense resistor,max. current is limited by max. power dissipation(heat) on power mosfet,and that depends a lot on led Vf,battery voltage,how good is thermal contact between driver and flashlight,but this driver is designed for single xp-g2,xm-l2 so 5A is more than enough because of high Vf
-theoretically it is possible to add "external" mosfet and stack sense resistor for 9-10A current,but this should be tested in reality(and you loose overtemp protection this way)
-as for 2S (8.4V) capability I'll see what can I do,I want to preserve low voltage warning/protection(I assume for MT-G?)
-no mode changes via switch(es)-I really don't like "menu" idea when you have only one button(equivalent is writing this text with only one button),and when you have side e-switch capability in firmware at the same time,there is a good possibility for chaos.
Keep it simple as possible was main guideline during both hardware and firmware part developing
There are 2 "stars" with 4 possible mode groups,enough for 95% of people,but if you want some different modes,I can do that(free of charge for simple mode changes).What will be those 4 mode groups depend on BLFers,the most wanted groups will be in production version
-as for turbo mode:Is not that simple to explain(turbo is not constant because of some hardware limitations),but something like this: ~140% when input voltage is 4.2V and that drops linearly to ~110% when input voltage is 2.8V-in practice this doesn't matter because max. possible current is smaller anyway as battery voltage drops
Some additional info:
-uC is PIC,not Amtel
-moonlight mode in this version isn't possible because of hardware limitations; 10mohm sense resistor and 5mA moonlight current mean 0.01*0.005=50uV sense voltage!
That's disadvantage of PWM-less constant current topology.Auto zero opamp would solve this,but prices of those are considerably higher.So maybe I'll offer moonlight version at higher price.
Runtime-efficiency explanation
It's a known fact that all leds have higher efficiency(lm/Watt) at lower forward currents.For example XM-L2 U2 has98.7lm/W@3A, 140.6lm/W@1A nad 170,7lm/w@0,15A (no data for low currents,but one can expect close to 180-200lm/W at very low currents).
In case of PWM based drivers,LED efficiency on all modes is the same and equal to efficiency at highest mode.This is because led current is always the same as on highest mode (3Amp for example),but PWM driver turn led on-off fast compared to eye response so we see "average brightenss".Multimeter also sees average current but if you check current with oscillocope you will see pulses of 3Amp current.
In case of PWM-less CC driver,I(t)=average current,there are no pulses,so LED efficiency depends on current-the lower the current,the higher efficiency.
You can see difference in LED efficiency for XM-L2 U2 at 3Amp max. mode in this table:
3Amp |
1Amp |
0,15Amp |
0,03Amp |
PWM CC driver LED efficiency |
98.7 |
98.7 |
98.7 |
98.7 |
PWM-less CC driver LED efficiency |
98.7 |
140.6 |
170.7 |
~190? |
The higher the "high" and lower the "low",the more extreme difference in efficiencies between those two types of drivers.
This means two things: you could get more brightness at same average current-same runtime,or you could reduce current to get equal PWM CC driver brightness-longer runtime.
For example: 1% low mode for PWM-less CC driver would be just as bright as 2% low mode PWM CC driver.That simply means current drain from battery is reduced by half->and that means two times longer runtime on low.
Regulation vs. time explanation
In case of PWM based drivers, Vf on lower modes is the same as on highest mode,voltage sag is the same on all flashlight parts as on highest mode!
Check HKJs graphs for 7135 based drivers,on lower modes,current is constant until battery voltage drops to ~3.4V,same as on high mode,no matter what mode you choose.
Voltage drops at springs,switch,wires remain the same on every mode.
In case of non PWM CC driver,on lower modes current will remain constant until battery voltage become lower than Vf of LED at that current,for example 3.0V@300mA. Also there will be less stress on battery,springs,led die etc.
My next plans are:
-order small quantity of pre-production (last and final revision,I hope so) versions of pcbs
-finish software part-polishing+add mode groups and switch styles that are useful for most of members
-assemble drivers and send some of them to HKJ,RMM,and organize giveaway for BLFers
-will see what after that
I think for MT-G2 is no low voltage warning needed, because of the 6V (or more) Vf! The lumens will drop dramatically when 3v per cell is reached.
