After a few e-mails to CS ,“Flashlight Expert - Alysonhe” and Neal - it was agreed that my flashlight does not work and a replacement order for a new flashlight and the missing charger head was placed .That was on Feb,2nd,2014 . Suddenly - it all started all over again - “Processing” then in a couple of days - “Back ordered” .It has been like that for 2 weeks.Contacted Neal to work something out for a different flashlight - not very good offer on my first pick,still waiting to hear from him for the other couple of models.Since contacting Neal 2 days ago - status of order changed last night to “Processing” again. It looks like BG has problem supplying this light and it shouldn’t have been offered for sale, in first place . Sending e-mail to CS to ask for refund .
Mailed Banggood regarding missing parts. Got an answer real quick: Would I like resend? Yes, please! Today a couple of weeks later a parcel from China arrived. Now I can add to my flashlight an extra o-ring, clip, strap and glass breaking tail. Thanks Bangood now I’m good!
Maybe this has been covered elsewhere. I’m maybe interested in getting this ‘light’ but with the charger head only. What I really want is a tough and well made battery storage pack. Like the 4x18650 power packs with usb in and usb out, but not made of weak non-sealed plastic. I’d like it to be aluminium with o-ring and no space or money wasted for a flashlight.
The main things I want in it really are:
1.) aluminum ‘good’ construction; decent threads, can take protect or non protected 18650, O-ring seals).
2.) ‘good’ output; perhaps 1.5 amp output ability or so, ability to discharge to at least 3 volts
3.) ‘good’ input; any usb input plug is acceptable (prefer micro), but a decent charging routine
3a. CC/CV charging routine
3b. Actually charges the battery to 4.2 volts (or real close)
3c. I see a lot of stuff that ‘looks’ like this (sometimes with a cheap grade led in the end, don’t care for it but not a big deal), however they seem to have bad charging routines (terminate charge early, unstable charging routine is not CC/CV, or a both of those things and other problems as well).
If I understand correctly the roche F6 with charger head is a bit bulky (how much dose that actually weigh with only charger head?), but had a good charging routine and a good power output ability. Is this right?
Is there an option more well suited to what I’m trying to accomplish here?
2.) re edited : 4.1 even 4.05 volts would be ok
1.) re edited : Protected battery capability is not ‘necessary’
4.) Consistent is necessary, I don’t want a product with massive variation (one unit charges to 4.25 volts, the next charges to 3.9 volts, etc. a few of us will run these and we want the same stuff : )
Here are some pictures showing the weight of the components:
No clue about how far it charges/discharges, I don’t have a volt meter. I would assume that a dedicated charger would always give better and consistent results than a screw-on head that’s an accesoire to a flashlight. Can’t tell you much about the max output either, because I don’t own any ipads or other apple products. My phones (android/wp8) and my PS Vita charge with 1.1amp max.
Specification on the head says:
IN: 5V1A
OUT: 5V1A
But then, it charges the Vita, which is a feat in itself, as that device is very picky and won’t charge on my good quality USB wallcharger for example.
I’m not sure what you want to do with it. You can’t get the tube without the flashlight head as far as I know, so you’re always short of 30-40USD for a 3400mah (max) power bank. Dedicated power banks with that capacity are way cheaper than that. So is a Lipo guard storage bag. Using/storing USB plugs in wet condidtions isn’t a great idea either.
Well I knew about the specification quoted for input/output, figuered about the ‘not buying it without flashlight head’.
I did not know about the weight, thanks a bunch for that information.
Yeah, it’s too much cost for what I want to use it for I suppose, mainly I don’t want to carry 80 grams of enclosure to carry another 40 grams of battery, this would go into our backpacks for the semi-long hike. ounces = pounds and pounds = PAIN, it’s cliche but it is so true.
Nice scale btw, like the pretty blue backlite, it takes pictures well
I got the scale from fasttech: https://www.fasttech.com/p/1095103
I don’t use it regulary, but wanted to have a halfway exact scale for these kind of questions (I’m a bit into RC flying, where weighting your payload is useful).
Not that I can see. Maybe they use it for QC purposes at the factory. I thought maybe it was a magnet but it’s not. Did you get yours from BG? I wonder if there’s any difference between the F6 from the two sellers. The one I got is fantastic.
The tail of the light already has a tripod mount. I tried to take that out of the tail to save weight but ended up scratching it and figured I’d just leave it there.
Perfect condition, I suspect he received it that way.
No complaints about the light aside from that, although the charger head LEDs could be aligned better with the holes (you have to look at an angle to see the light. pretty minor…
Sorry if i missed it in this thread, but could someone post a pic comparing the F6 size to one of the convoy tube lights S2-S8 ? Thanks
Edit:
I found this one in another thread, but others would be nice too. Especially looking for one showing the “head-on” or “Top-down” comparison of head diameters
Really love the form factor of the F6. It would have been my favorite EDC if I had faith it was really waterproof. But after taking out the bottom slug to bypass the spring, I don’t think it is.
Yeah the screw-on ones are my favorite also, but it’s super sturdy…much more than the ones like on the Eagle-Eye X6 or ZeusRay (or similar)
From left to right: Convoy M1, Convoy S2, Roche F6, ZeusRay, Supfire S5. I took the Sk98 out of the line up because mine doesn’t tail stand. Also I replaced the reflector on the F6 and Supfire S5 to 10 degree TIR reflectors, so they look a bit different.
