I ask because I still need a dropin for one of my SolarForce L2m's. I really like the Thrunite XPG 3 Mode 4.0-13V Dropin so I can use the 18650 extension tube and use 2 - 18650's. Thanks guys!
Someone tested the older Thrunite's XP-G R5 (2.7-9V Input) over at CPF. But I think they are too expensive, I wish they sold the dropin of the SKYRAY S-R5 separately. It's been one of the best budget dropins so far.
$11.05. He had them on sale for 30% off. Then yesterday they were at regular price. Today they are 20% off (still a pretty good deal). If he goes 30% off again, I might pick up a black one, but I have more hosts than drop-ins right now so I don't need it at all.
Ok I just bought one from him. Now what's the best drop in for this thing? Thinking of getting 501B on DX with MC-E. Is that hole in your beam still there?
Cool. What color did you pick? You got the L2 for 18650?
I put a different reflector with the MC-E and it is a little better (not a distracting black dot anymore), but it is still there. An XP-G R5 is probably the best bet: bright, decent throw, good beam quality, and efficient. With the MC-E, it is bright and floody enough that you get a lot of light bouncing off things that are close to you (the ground, overhanging trees, etc.) that those objects blind you from seeing stuff in the distance that isn't lit up as brightly. At least for me.
The XP-G has enough spill, but puts most of the light where you want it. If you don't mind 1 mode, the XP-G R5 is good and seems reliable based on reviews and my experience. The 5-mode seems more iffy. I was happy getting the 1-mode and swapping the driver out for a 3-mode. But if you don't want to install your own driver and still want multi modes, you probably need to get the 5-mode.
I was debating between the black and gray L2 18650. I decided to get the gray one just like yours :) Thanks for the advice for the XPG R5 one mode. In Don's review he said his MCE's + sign can't be seen after 4 feet. In your pictures, there's a dark spot on your fence lol.
They could all probably use a few aluminum strips to get a tighter fit. I haven't done any duration tests on the 501B or the Solarforces yet, but I know the 504B tends to get hotter than the 502B which is a good thing. Part of that is because the inner diameter of the 502B is bigger plus the throat separates from the body tube whereas the 504B/Solarforces have one-piece body tubes and throat which will transfer heat better from the head. I'd expect similar peformance on the Solarforces, with maybe a little better performance on the real Solarforce because it feels heavier.
Here are measurements I took of the inner diameter of the heads of the lights. The drop-ins vary in diameter a little so the number of strips needed will vary from maybe 3 to 8 (for the 502B).
I've chatted directly with a Solarforce rep and apparently there are Solarforce fakes out there, but he basically told me that it can't be helped in China. Although the irony here is that a Surefire 6P clone gets cloned...while the Ultrafires are 6P clones to a certain extent too, but of course they're acknowledged to be made by Ultrafire. As far as Daniel from Lightake saying they're genuine (despite his bad english), he is probably being honest with as far as he knows. Afterall, he is a Lightake salesman and not their purchasing manager and so he only knows the information given to him. With that said, since we all know the only Solarforce L2 that comes stock being able to tailstand is the L2P, the ones sold at Lightake are most likely are fakes...still for the price, you can't really complain.
Makes sense. Besides, I was just having a pedantic moment and you beat me as you remembered the L2i which I didn't. Never liked 3xAAA lights much which is probably why the L2i slipped my mind.
I'd doubt it. If I read this CPF review correctly, the body tube is 25mm in external diameter. However, his dimensions don't make sense to me. I think he may have mixed up the L2i and r dimensions.
It would appear to have a 32mm outside diameter. It probably has thick walls so a C may, or may not fit. If you reckon that the OD is 25mm for the L2r which takes 14mm diameter cells, I suspect that the inside diameter of the L2i will not be big enough.
But i don't own one and I've been wrong before and undoubtedly will be again. If I liked 3AAA lights I'd be prepared to drop $13 on it just to try it out. But I don't and I don't own any C lithium cells either. It would be quite expensive to find out.
Is that measured? I can't find my callipers but I'd have thought it was nearer 15mm inside diameter.
Found them. 14.9 or 15.0mm inside diameter - 21.8mm outside diameter.
On the basis of that and assuming the L2i has the same wall thickness I'd expect it to have an inside diameter of around 25mm which is likely to be too tight for a C.
