New Peak Eiger Ultra high CRI emitter
I guess if it’s possible it could be useful for a diver, but seems a little odd considering most batteries don’t respond well to getting wet.
Maybe they just mean that they have a really outstanding warranty, and did not imply that changing batteries under water was safe for the light. :stuck_out_tongue:
I’m in the process of getting an Olight i3.
I am curious why you like it so much.
I still don’t know why.
Maybe you import them or you sell them because you are stuck with a big shipment of them.
Are you using a 10440 li-ion in it?
To me, all the AAA flashlights are similar.
They all put out light.
Some brighter, some less bright.
Some use QTC, some using switching for dimming or modes.
Some are physically longer, some shorter.
There are cheap ones and costly ones.
I know you like it.
But I don’t know why you like.
The question is why I would like it.
That is the concept you don’t seem to grasp.
Thanks for posting your thoughts satow, and my apologies for seeing your thread get trashed. We’re not all like that!
The twisty feature is not odd. It is how it is implemented.
People have different needs, thus there are different types of implementations.
My Preon P1 has 3 main modes, L-M-H with two hidden modes flash and S.O.S.
Before I put the clicky tail cap switch you had to twist the head back and forth to cycle through the modes.
To make it easier to switch modes I put on a clicky tailcap.
Some people think that a clicky tailcap is a cheap gimmick to cycle through light modes.
I think it is a handy feature to cycle through the modes quickly.
It’s much faster than twisting it on and off to get to the mode you want.
Some people prefer the QTC twisty feature.
This allows the light from being full off then gradually going from dim to full bright as you twist the head tighter.
My Veleno Quantum D2 and my Peak Eiger Ultra uses QTC.
It is silent and you can vary the light intensity with one hand.
This is great while camping or doing surveillance.
Especially when you don’t want to flash the light cycling through modes or make noises with a clicker tailcap switch.
The tailcap for the Peak Eiger Ultra is a momentary spring pressure switch.
As you depress the tailcap it gets brighter, when you release the pressure it gets dimmer.
It is silent.
Some people don’t want any modes, just off on.
Some people only want two modes, L and H.
Some people only want three modes, L, M, and H.
Some people like multiple modes and memory, L, M, H, memory, S.O.S., flashy
Some people want an infinitely variable light output so they choose QTC.
Some people what an variable light output but no clicky noise or flashing so they choose QTC.
I don’t think the Olight i3 is going to be any better than my Preon P1.
But I am looking forward to seeing how it compares to my other lights.
I have a bag full of AAA lights, including the I3 and I3S. Personally I would go with the I3S, which has a long list of improvements over the original I3, including a much better constant current driver, superior build quality and machining, not to mention an XP-G2 and moonlight mode, just to name a few. There’s really no comparison in my mind. The I3 was a nice light but the low frequency PWM made me nauseous. Both versions will take a 10440 with the caveat that you’ll melt something if you leave it on high too long.
The Peaks all look like great lights and certainly have a loyal following. Not really my thing, but it’s hard to go wrong with a flashlight made by hand from people who understand flashlights better than most. If you value build quality and overall craftsmanship above all else, then they are worth taking a look at.
the sarcasm on your post is so damn high :smiley:
Just make sure to follow the warrior code of Bushido, which does not allow you to shine a light in your enemy’s eyes, because the eyes behold the rising sun.
Thanks Racer.
This is the link I am looking at:
http://www.ebay.com/itm/Olight-i3S-EOS-Pocket-Keychain-Cree-XP-G2-LED-Flashlight-80-lumens-BLACK-/141225590553?pt=US_Flashlights&hash=item20e1b37f19
That’s the one you want :slight_smile:
Thanks Racer for the verification.
I want to know why that light is so popular with good natured people.
I also want to know why it attracts some idiots too.
LoL!
I did a review of it here, including a comparison to the original I3 which you might find useful.
The only gripe I have the I3S that I live in a really cold climate, and sometimes when it’s cold, the light can get stuck on medium until it warms up in my hand.
Thanks Racer! That is very helpful!
Lots of rude ignorant posts in the thread, this might be a budget forum, but there are lights that as with most products are superior in there construction and function, one member decides to venture outside cheap Chines clones and buy something of quality and he is pounced on for making an excellent choice, are you all sheep? Friendly forum what a joke. Some members here should be ashamed of their troll like behaviour, not to say there aren’t plenty of intelligent members here who don’t find it necessary to follow the trolls.
I merely mentioned the under water capabilities, because peak heads are themselves a sealed unit and a small leak passed an O ring isn’t compromise the operation of your light, just another barrier against water ingress.
Instead of treating satow as a fool who is easily parted from his hard earned, you should be congratulating him on his excellent taste in flashlights.
I think it is fine to joke around and have favorite lights, but being disrespectful is another issue.
Yes, the Peak Eiger Ultra is a fine light. It’s very well made, a little costly, but has features such as QTC and the option to add a plunger style tailcap switch. No one else has that.
Being quiet and not attracting attention with a flashing light as you twist through modes, or making a clicking sound as you click through the modes is very important to avoid if you do security and patrol work.
That is why some military and security personnel love this light.
Most people don’t know what QTC is. It is a material when compressed, allows more electricity to pass through. When it expands, less electricity passes through.
So on a QTC light, as you twist the head tighter, the light gradually gets brighter.
When you loosen the head the light gets dimmer and eventually goes off.
  1. The beauty of the Peak Eiger lights is that is it a QTC light that has customizable features.
  2. You don’t have to twist the head off and on to switch modes to get the light to the right brightness.
  3. You have the option of adding a tailcap switch.
  4. As you gradually press in the tailcap switch the brighter it gets.
  5. When you back the pressure off the tailcap switch it dims.
  6. No other QTC light or any other light, has an optional tailcap switch that works like this one - that I am aware of.
  7. It is completely silent so when you are on patrol, you don’t draw attention.
  8. You don’t have to cycle through modes, which causes flashing which also draws attention.
  9. It is built very, very well and is extremely lightweight.
And these are some of the reasons why people like the Peak Eiger series of lights.
I don’t think the Olight i3s has those features. It doesn’t need to.
It is for the everyday man to carry around.
I think comparing the Olight i3s with a Preon P1 or a Streamlight Microstream C4 is a more appropriate comparison.
Some people think that twisting the head on and off to get to modes is gimmicky.
pseudo-intellect may be preferably to the lack of any sort of intellect shown by yourself, you seem intent on justifying your pointless troll posts, people here don’t need to justify their purchases to you, haven’t checked the calender is it school holidays again? Nor should you feel compelled to show of your boundless knowledge.
Or isn’t free choice an option here any longer?
As a great American once said. “It’s better to keep your mouth shut and appear stupid than open it and remove all doubt”
Which seems very applicable to B25364
I got EXCITED about that offer until I saw it was a ‘bid.’ Shame on you.
Here are some Buy It Now Olight i3's:
http://www.ebay.com/sch/i.html?_sacat=0&_from=R40&_sop=15&_nkw=Olight+i3&rt=nc&LH_BIN=1
Don’t leave us in the dark now, no1 here has ever seen how you can swap batteries underwater, i think we would all like to, and when i get the confirmation that is possible(video prefered) then i’m sure buying a whole lot of these lights!!!
I forgot the golden rule,
Do your own research if your so keen to see the evidence.
which I know you aren’t
There’s nothing wrong with bidding. I think I picked up one of my Preon P1’s a while back for under $20 too. No one bid after my bid.
