My condolences. Hope your time together was filled with nice memories and ear to ear smiles.
On the bright side, you got a nice looking $50 paperweight/nutcracker/doorstop. =)
Man that sux! My condolences.
What you think killed it? I just got my Panasonic 2900's from HKE today and put them in my 3800 even tho they are unprotected. Think i should switch to the HiMax 2600 protected cells?
BTW check out the stickied 3800 review at the top of the page in the 18650 cell section, I think you will find my last post most interesting.
If you weren't so far away and not a modder id be trying to buy that paper weight from you as im just looking for a good excuse to mod something and i cant decide where to start yet.
(Edit) I guess my post in the 3800 review isnt the big news i thought it was, But i ended up being lucky none the less.
Dasfriek.....well, actually with this turn of events that mitro's and my drivers went toast suddenly, I think better change to protected batteries. What happens is that within 0.1s of the driver failing, the PCB would cut the current and prevent a thermal runaway in the cell. No problem, not really heartpain, in fact it is good that I had the Xtar 2600 inside.
You can still use the NCR18650s, they are very safe. Just that you need to be aware that when a light suddenly cuts, you need to immediately cut the power at the tailcap. Also do not use magnets with them as they might shift and cause a short. A blob of solder and filed down flat is much safer.
Dang, What a bummer as i bought those cells just for that light.
BTW which revision was yours? Solid head, drop-in, or screw in pill?
But the protected cells didn't protect your light??? I still don't think you necessarily fried the xml's. To kill them in para requries >15 amps, surely some trace on the driver would go short before the emitters do.
Yeah this light was sure fun and it is easily the longest running and best tested in my whole range..
And the best thing is, Agenthex is right, it is run in series. I am able to get the head to light again with 2 x 18650. So I'll just ask MF's Audrey for a replacement driver, well at least i did testing and advertising for them. LOL!
:bigsmile:
Id look for a SST 5A driver and see if that dont push the emitters to their maximum power output.
12.6V @ 1.9A DD, that's 24w. The crocodile clips and 22awg wires are my driver.
I'll try my 3S3P Li-Co batt pack from my HID and see what it can do in DD. And measure the lux at my 8.17m test distance. If it fries, it fries...
Brave man. I would run them off a bit first, though.
You should be fine. During testing, I pushed 8 amps through 3 xm-l's in series from 4 26650 LifeP04's DD. Granted, it was only for a second until my fingers could react to what my eyes just saw, but all the emitters lived.
Ok no issue then. Thinking of leaving this "as it is" to play and getting the Trustfire 3xT6. Lots of threads + lots of external fins, 7 of them vs 3 on Sky Ray/Hi-Max/Fandyfire.
Actually I am using SLA to play now, no issue. 4S1P is definitely too high. I guess in stock form, it is not a matter of LEDs surviving but rather the driver electronics surviving. From what we can see only the lower PCB is somewhat heatsinked.
Direct drive with a fully charged SLA measured 2.2A to the emitters in series, i am getting 324 lux @ 8.17m. 21626 lux @ 1m, or candlepower.
Using slightly larger diameter wires on one of the them i could do 2.8A, giving me 360 lux @ 8.17m. 24029 lux @ 1m. This thing comfortably outthrows stock C8/UF-980L/U80.
Update, i pushed 3.3A and got 380 lux, that's the max. Head gets hot really fast.
Stock SR3800 is 260 lux @ 8.17m.
Engrotelis measured 1580 OTF lumens in his lightbox (he said his is pretty accurate). If that's the case 380 lux / 260 lux = 2309 lumens OTF.
Sorry to hear yours is dead too, 2100. I took mine all apart and the LEDs appear to be fine. I guess I need to find a suitable driver but I'm not sure I want to bother.
Run it in DD with a SLA, quite fun. 3S would drive it to approx 1.9-2.2A depending on charge level (12.4V-12.6V unloaded).
How about a taskLED.com H6flex or H6CC? Both are capable of 6.6 or 6.7A delivered and would provide a driver circuit designed for series wired Xmls. Granted at $30-40 you have almost as much in the driver as you do the light, but I'm betting you have a much harder time hurting one of those drivers.
Both of my skyray 1x14500 lights failed as a dead short too. TF Flames instantly shut off. I don't know why anyone insists it's OK to use unprotected cells, but people still do...
I'll give you $5 for your broken one. :)
--Bushytails
$5, no way.....I am getting comfortably above 2000 lumens OTF from the broken Sky Ray, form a good basis for comparison with say the TK70. Probably will order the Trustfire as replacement since it has so many threads. Sheesh why do I need 4 x 3xT6 for? (actually supposed to spend on HIDs but plans foiled again and again)
I’ve always wanted to try one of their drivers but that a big investment for this thing. But from the looks of it (and I’m an idiot when it comes to electronics), they need a higher Vin than Vout and with two cells that’s not going to work with the LEDs in series.
based on the tech info from the TaskLed site, I dont think that is a as big a problem as you might suspect.
From the site: H6CC is capable of running from 8V up to 22V as shipped (guaranteed operating range). H6CC may operate as low as 5V, but operation between 5V and 8V is not guaranteed at the full 6.7A output current over the full operating temperature range (0C to 70C).
