I just checked for parasitic drain on the 1, 6316 that I have.
With a fresh cell (4.15V) the drain is 17 uA
But a with a damaged cell (1.92V) the drain is 111 uA.
I also confirmed that the 6316 will attempt to give more than it should . An iPad received over a 1.7A (they need 2.0 ) and a GPS unit for my car got 1.7A. Both are too much for this little unit. Chips started to get hot very quickly.
It could be OK if it was a newer cell and you caught it quick. The older and the longer at very low voltage the more the damage. Damage will first show up as higher resting drain and lower performance under high draw.
That’s what I don’t understand…per a translation of website pertaining to the FM6316CE
If it was working as designed these chips “should” thermal/current limit to 1A and charge the li ion with the correct CC/CV…but alas…it appears that either a bad design or bad components on the board…unknown at this time till someone with ALOT better test equipment can see just what these boards are doing…hmmmm
So far all 4 of my other FM6316CE driven boards are doing what they are supposed to do on charge…all of them give blue on full charge, using one of those .36” voltmeter I get 4.2 on the readout, and on power out they run whatever device just fine and don’t get warm, the one black one however smoked after a few hours (I need to get a USB doctor module)
I have a similar type unit, but it is a cree flashlight, with the USB input and output on the tail, where a metal plate rotates.
I’ve used mine to top up various android and windows phones, and it works, but if I were relying on it for charging, I’d probably skip the flashlight, and go for one of the 4 pack cases, that are < $10. Also, makes a great storage bin for charged batteries.
Now if those 3-4 emitter x 4, (Skyway, etc.), had USB chargers on them, those would be very interesting, but the on/off switch makes those lights useless for my needs, and rather large diameter wise.
I bought one of these http://www.ebay.com/itm/350919777680?ssPageName=STRK:MEWNX:IT&\_trksid=p3984.m1497.l2649 and probably paid too much. First I was hating on it. It was totally dead until I found a momentary micro switch inside and pushed it. That brought it to life. It came with no instructions. I filled it with laptop pulls and it seems to work great. I don’t know if it’s the full 2A, but it charges my Galaxy S4 fast and that uses a 2A charger. A 1A charger on the S4 is takes forever to charge it so I’d say 1.5A-2.0A at least. It also charges up ok off a PC USB port or any good MINI USB charger connection. I don’t remember if I used USB 2.0 or 3.0 port. This is just a FYI. I could review it, but I imagine there are better out there. Heck, this same one is probably on other sites for $3.99
It is a brand new Samsung ICR18650-28A and it should have stayed at 0.96 volts for not more than 4 days because I charged it 4 days prior to checking my powerbanks.
I’ve finished charging it to 4.18 volts and I’ll just place it aside for a while. If it looses its charge on its own after a day or two then I’m throwing it away.
If you want to check a cell for leakage, try watching it when it is around 3V. The discharge curve is MUCH steeper there and you will be able to notice the leakage more readily.
(Remember when that cell originally discharged to 0.96V? It didn’t take much to get it up to 2.25. That’s why it is best to check for leakage when the cell is discharged.)
I’m saying that 4 of the 5 I got with the 6316’s are working fine…one of em smoked in a day
All of mine have the 6316’s (I ordered mine from a different company that buyincoins
Could be just crappy China QC or bad chips…who knows
I did put the .36” voltage meter on one of my black ones that was working after I drained it down to where it would quit charging…stopped at 3.3, charging stops at 4.2 [it is also one of the ones I put a RTV blob over the IC…but who knows if that is the reason…might just cause it to smoke too]
The reason I asked is because my 6316, the one that will discharge all the way to zero stops at about 2.8V when charging an iPhone 3GS. That is the iPhone refusing any more current. So I suppose one could get a false sense of security by testing the discharge characteristics with a device like the iPhone. That would be a “gotcha” just waiting to happen.
To test the discharge characteristics of the 6316 and 9635 I used an 82 ohm resistor spliced into a USB cable. The 9635 stops at about 2.75V, the 6316 goes right on down to 0.
Spent too much time on this already but wanted to reiterate what myself, dchomak & others have found w/our FM6316CE implementations of this thing.
Although fabricated/resistor-based tests like dchomak’s are important & objective, our FM6316CE-based units fail to behave properly in common usage (e.g. my IPad 2 tests). Like dchomak related these devices must not rely on the thing being charged to limit draw or stop drawing when voltage falls.
So of the THREE tasks the device must perform to serve its function; charge battery safely, cease draw when battery gets low (e.g. 2.7v) and charge things attached to it while limiting current to component maximums (e.g. 1A per FM6316CE datasheet) - it may do ONE of them correctly (charge battery).
And based on dchomak’s parasitic drain test, lack of low voltage cut-off further punished the discharged cell - fully discharging it when left unused/idle. We know this irrevocably damages the cell & elevates risk in recharge - something the target users will know nothing about, they’ll just keep charging it.
Yes, better testing ala HKJ would be nice (stop pestering him WarHawk ), I don’t need this to know not to use my FM6316CE-based units. And who knows which implementation HKJ has & will eventually test.
I’ve placed my order for the “ENB USB Power Bank 2×18650”/battery box, that HKJ did review, for this task. But to each his own.
Have you measured how far it drains the cells? I just ordered one of those $5 meters from dx, and would like to get a 2 or 4x pack like this one, if they don’t drain the cells too low (or charge too high).
That’s odd about the micro switch. If I found them for $4, I’d probably buy them for the shells, but at ~$10, I’ll wait, as I have several other USB chargers already, and for most devices, spare batteries.
Please don't feel that way about taking our time. You provided very important safety information to us which I, and I'm sure many others, are very grateful.
Thank you also to the OP for for posting a notice at the top of the OP. This is a very good thread.
I'm going to convert my "bad units" to dedicated chargers.
… and it wasn’t too much time as I’ve spent some more:)
Reviewing the FM6316CE datasheet & PCB think I’ve isolated its problems root causes; no Output Current limit resistor from chip pin #2 to ground (UPDATE: useless as it doesn’t t lower draw to 1A rated max, so another chip flaw), and FM6316CE itself does not implement the battery undervoltage protection it says it does (no external components control this - it appears an unimplemented chip function).
IF I’m correct, low battery cutoff function is absent/faulty in the chip itself & so is not fixable… Other than (the silly notion of) replacing it with a different/working pin-compatible one.
My/our FM6316CE versions look like reference implementations (less the useless OutputCurrent limit resistor - not respected by chip), so IF I’m right any/all devices using this (version of the) chip lack essential/advertised low battery cutoff / undervoltage protection. Hard to imagine but perhaps representative/indicative of lower-tier chip design/development/production houses.
