I'd doubt it. If I read this CPF review correctly, the body tube is 25mm in external diameter. However, his dimensions don't make sense to me. I think he may have mixed up the L2i and r dimensions.
It would appear to have a 32mm outside diameter. It probably has thick walls so a C may, or may not fit. If you reckon that the OD is 25mm for the L2r which takes 14mm diameter cells, I suspect that the inside diameter of the L2i will not be big enough.
But i don't own one and I've been wrong before and undoubtedly will be again. If I liked 3AAA lights I'd be prepared to drop $13 on it just to try it out. But I don't and I don't own any C lithium cells either. It would be quite expensive to find out.
Is that measured? I can't find my callipers but I'd have thought it was nearer 15mm inside diameter.
Found them. 14.9 or 15.0mm inside diameter - 21.8mm outside diameter.
On the basis of that and assuming the L2i has the same wall thickness I'd expect it to have an inside diameter of around 25mm which is likely to be too tight for a C.
Did some caliper measurements on my L2r: body tube ID 14.51mm OD 22.13mm, head ID 28.67mm OD 32.00mm
Post #19 in that CPF thread says that the OD of the tailcap threads is 63/64*1" (or 25-ish mm), ID should be roughly the same so it seems that 26500's are out of the question then...
Since my calipers have rust on them, yours are certainly more accurate than mine. 14.51mm sounds tight for some of the fatter NiMH cells. It is close to airtight with my junk 2700mAh cells. But the nice thing about P60 lights is you can pull the dropin out and use a stick to extract cells.
I have been playing with the cheap SF bodies from ITC and the Sand L2 is for two cr123s or one 17670 battery.The 18650s will not fit.I have the black and the gray bodies also and 18650s fit fine.They advertise the Sand on EBAY as 18650 compatible,but it is like the Surefire 6P in battery compatibility.It also came with a stainless steel assault crown unlike the the EBAY photo.I am pleased with it despite the drilling.I also am very impressed with the single mode SF R5 XPG 3-18v drop-in they are selling for $12.90.Really impressive in the L2 two 18650 config.or the L2r two 14500 config.There you have it--my first post!
The SF R5 XPG single mode drop-in is also outstanding with a single 18650.It has a smooth reflector and therefore has more throw than the DX single mode R5 with the OP reflector.I am staying away from the 5 mode R5 drop- ins as I had one burn out after only about one hour of use-the only P60 I have had die.When you use an extension tube and two 18650s it seems to boost the output significantly,but it is still great with just the single 18650.
Yeah so far all of my Solarforce single and 5-mode XP-G dropins have worked great without any problems. Just like everything else they make and sell, fantastic value for the quality of product that you get.
To be clear,the R5 5 mode that stopped working on me with a probable burnt driver was not a SF,it was from a Suterfire G2 from Kaidomain.Also with the SF R5 as you get more throw with a brighter hotspot you get less spill/flood than the DX R5 with the OP reflector.
I got the XPG-R5 5-mode. I was also thinking of getting the MC-E but the donut hole or plus sign showing in the center of the beam wasn't very attractive.
This is the link: http://www.kaidomain.com/ProductDetails.aspx?ProductId=10068
Yeah, I'm just going to take the drop-in and put it in the Solarforce. The drop-in, if bought separately costs more than the whole thing, unless I'm not searching correctly: http://www.dealextreme.com/details.dx/sku.32954 I'll have an extra body for other uses.
FWIW, I've had no problem with my 5 mode dropin from LT that came with my fake Solarforce body. It appears to be the same dropin as the Skyray on DX from the pictures (I thought this before buying it) and does have a smooth reflector. I think the XPG dropin DX sell seperately is the same (it looks it) The current draw is a little les then I hoped, seems to be about 1A on single 18650 or similar with 3xNiMH. Of course current draw drops as the voltage goes down. Current draw on 2x18650 is about 0.45A or so IIRC. I've added aluminium foil and while the head gets warmish, heat seems okay, even after say 2 hours the pill is just warm, and not too hot to touch. I did try connecting it to the 5V of a computer PSU for a while without the body or head and it does get too hot to touch so I didn't try that again :-P (Later connected it to the body & head and it was fine.)
I must have run it for at least 12 hours by now in various testing as well as some cycling.
I did find the body is a bit too long particularly with 1x18650 (black/red flame) so the battery rattles, back and forth (also side to side but this is easily solvable). This may seem annoying but harmless enough, it did to me at first except it means it keeps switching mode when I'm cycling and go over bumps (primarily when the back wheel comes off a bump). Mind you, from what I gathered in my research, quite a few genuine Solarforces have a similar issue. There's a slightly possibility I damaged my spring somewhat causing the issue (long story, will explain in more detailed review) but I think it's just the body is too long or the springs aren't long enough. With 2x18650 while I can change mode by shaking the light, when I went cycling with this combo once it didn't seem to switch by itself. With 2x18650 you can just put a spacer like aluminium foil between the batteries and then tape them together, they get a bit sticky but the foil won't short. With 1x18650 I stuck a piece of foil in the spring and it seemed to work. One or more of those rear earth magnets people often use as magnets is probably the best solution.
I received my 501B R5 drop in from KD yesterday. The quality of the 501B host is way lower than quality of the real Solarforce. I tested the 501B for fun but it had contact problems. When everything is screwed down tight, the flashlight wouldn't turn on. I had to loosen the head and it turned on. It also seems like the big spring of the pill is being compressed too much. When I tightened down the head, I could hear crunching down of the spring.
After trying the 501B body, I transferred the drop-in to the Solarforce body. Fights perfectly and no spring crunching noise when I tightened the head. There is sort of a rattle if I shake the light violently but the modes do not change.
It's a pretty bright light. Pulling 1.3A at the tailcap on a 4.10V 18650 battery. The beam profile looks very similar to my Hugsby P31, but it's about 2.5x brighter and has more of a cooler/whiter tint. It doesn't throw as well as my KD MXDL 18650 but that light is zoomable Overall I'm happy with the DX R5 drop-in/ITC Solarforce combo. Now I want something brighter Any suggestions?
