I bought about 24 of them in 2009 to use in my camera's flash as well, but now I use them in everything! I haven't kept good track of them at all but I'm guessing that many of them only have around 10 cycles on them, there are a few that have 40+ cycles that I use in my AA headlamp. At first I was using the 4 bay Eneloop charger, lately I've been using my Nitecore i4 which seems to do a pretty good job even though I've heard of some running the cells hot mine doesn't seem to.
All of them hold a good charge, I can leave them in a device for years and it still works! These were a revelation to me when I found them because all the previous NiMH cells I'd used were no good because of the fast self-discharge rate. Even if these aren't quite as high capacity as some of the others they are worth it to me because they work without babysitting and are a true replacement for alkalines.
I’ve had to rein in that habit, i now offer to sell or buy people an item i have that they like because i buy plenty for myself and end up with nothing left
All my Eneloops seem to behave more or less like new. I have a few dozen, but none are more than ~2.5 years old, and they don’t get cycled very quickly. Even in lights I use daily, they last at least a month per charge, so that’s a maximum of 20 or 30 charges in the time I’ve had them.
At this rate, it looks like I won’t need to buy NiMH batteries for a long, long time.
I’ve been using a La Crosse BC-700 charger, and I try to run the Eneloops down all the way before charging them, to avoid any potential memory effect. I also keep the charger unplugged while not in use.
I’ve also got a few Energizer LSD cells (bought before I discovered Eneloops), and have no complaints. I mostly only use them in devices where I don’t care much about battery performance though.
Before this, I had a bunch of PowerEX cells and a MH-C401FS charger. They were nice at first (at least for high-drain devices), but they self-discharged in a month or two and none of them still have enough capacity to be useful. The batteries ranged from about 3 to 10 years old when I finally dumped them, but I had mostly stopped using them by then. The charger lost its “magic smoke” about 2 or 3 years ago, after being plugged in 24/7 and used occasionally for about a decade.
I am surprised that no one has replied with more then 1000 cycles on their batteries, i have some duracells (that coincidentally appear to be duraloops from about 4 years ago, well before i heard of duraloops) with maybe 300 cycles and are doing fine, but are used in a camera and GPS so not high draw.
I would enjoy seeing some testing on eneloops with 1000 discharges at 1-2C and testing their voltage sag, capacity and self discharge rate.
Given that they've only been available for around seven years trying to get 1000 cycles on them by now would be pretty ambitious. Rough napkin maths tells me that would require they'd been through a full cycle approximately every 2 1/2 days since purchase, and that is assuming they were first generation Eneloops.
I think there is a tendency for enthusiast groups such as ours to get caught up in the specifications and sometimes not face the reality that we really don't need the life cycles that are claimed. In all likelihood my Eneloop cells will outlive me as long as I keep using them at the current rate, don't insanely abuse them and keep charging them with a decent charger.
I bought a half dozen 8-packs of Eneloops on sale at Radio Shack in 2006 when they decided to stop stocking them. I’ve only opened about 3 of those packs, but they don’t seem to perform any different today than when I first charged them. They’re white, I have no idea what ‘generation’ they might be.
I do keep them in matched sets (I’ve numbered them with indelible marker to keep them sorted), and I usually run them till they quit before recharging, but I don’t keep track of the number of cycles. They all still hold about 1900 mAh, and so far none have failed or gone measurably ‘out of synch’ with their mates. Mine are used in flashlights, radios, and digital cameras. None are in toys.
You have a point on the time required to get 1000 cycles, however when i travel for work i am half draining them each day, i must have over 200 days of use on my duraloops since i got them.
Also i am more concerned about longevity, if they last 10 years that is great, my rayovacs are not fairing well and they came out about the same time as the eneloops and have maybe 200 cycles on them (abused because of the dumb charger that came with them though, not intentionally)
All of my 18 AA and 16 AAA eneloops and the eight AA duraloops (all of which I acquired in 2011) are still working fine.
In fact, no rechargeable cell has died on me ever since I tortured those 18650s to death, almost three years ago (drained down to 0.1V, then let it sit for months before a recharge… aye, that’s really bright, innit? Be aware, noobs… Li-Ions don’t like being treated like that. Don’t be as much of a fool as I had been ((probably still are)), never run down a Li-Ion completely, and never let it sit depleted for a longer period. LSD-NiMH Eneloops, however, actually seem to appreciate being tortured. No matter what I do to them, they still continue to work as advertised!)
I have 16 Eneloops AA (first! generation) from ~2008 and all where used and abused by Pentax DSLRs and flashlights and believe it or not, they all still kick a$$ and are measured around +/-1950 mAh !
I have one cell that might be in the 800-1000 charge ballpark. The 2nd gen eneloop. I have no proper equipment to test it and it is still being recharged daily. That alone makes it 800+ recharges. I will get a BC700 clone soon (ordered from nkon.nl).
Is there any test/readings that might be useful to you guys? I can post pic of the battered eneloop
do a capacity test first, that will charge it, and drain it and tell you the number. The refresh repeatedly drains and recharges it until maximum capacity is reached, it can take take days.
Upto now it has been used in a budget $5 ebay ‘smart’ charger with independent bays and indicator. Its a cheap charger that sb reviewed.
Usage has been very varied. From being used in toys for kids, to being used in my camera (sx130is) and most of the usage was on a Quark X AA2 Tactical as bedside lamp on medium running at least 8 hours day. The cells were either being charged on a daily or on each 2 day basis (on the 2nd day the cell would be completely depleted before charging). Had its use on turbo too while using bike at night.
Presently, it is being charged on a daily basis. Once I get the charger, I’ll post up some numbers in a thread
