Tom, this my first battery pack. My question is are the batteries connected together with welded tabs? If so, are they easily removed without damage. Do you dremel them off, or just leave them on cutting away as much as possible?
Just trim them if you want more height, a la mini-button, or grab the tab with needle-nose pliers and roll it off like opening a can of sardines with a key. (Do they still make those?) Then gently file down any sharp bits.
I usually just twist back and carefully with a pair of needle nose pliers. Then I clean up the leftover weld with my dremel very carefully. You can also use a file to smooth but takes longer
My pack came in today in nice ASUS retail box & padded envelope w/April 2011 sticker. All good.
I happen to be using the cells for a project that I’ll be making a 3S2P pack for & these will be perfect & are of course a great deal.
Quite the feeding frenzy & probably not limited to BLFers. I need the one pack I bought but maybe someone else here has a spare they could sell to you.
