I'm not sure what method they ended up using, although I did talk with them a few times along the way as they were preparing for this changeover. The obvious difficulty is in getting the LED centered.
The bare host (XinTD MTN) will still be available for those who want to build their own or modify without having to break out the blowtorch!
When I get my first copies I am planning on building two identical lights up at around 5.0A, one with the soldered MCPCB another with my typical Arctic Silver job held down tight by the reflector. I will then measure what kind of gains the directly bonded MCPCB offers by comparing the amount of lumens lost due to heat sag.
Well I overlook that one, I was keep thinking that it must be an XM-L2 inside lol. I can imagine that with the XP-G2 version by simply dedoming the LED it may gives around 100kcd if not more.
As for the XM-L2 version 3A is just “within spec”.
I have a 2 mode V3 XM-L U3 I'm extremely happy with. As much as I'm tempted to get a V5 XM-L2 U2, I think I'll hold off for a while until someone reviews it.
I had to reflow 3 LEDs in my Shadow SL3. I ordered the warm emitter version, but Fasttech sent me the cool version. I had to remove the electronics and the rubber switch cover then heat the entire head using the pre-heater in this hot air station. Worked great.
At $170 this might be slightly out of budget, though. :bigsmile:
But it will certainly get the job done.
I’ll borrow some kitchen gas burner, read somewhere they get up to 800°C, but can be adjusted. XP-G2 flambé…
I used my toaster oven, set to 360 deg F to remove the old LEDs. Worked fine. I could have used it to reflow the new emitters, but I wanted to be able to see them as the solder melted.
I do a lot of electronic repair, so I decided to go ahead and upgrade my soldering station to the hot air rework unit I show above.
As far as I remember Match himself didn’t trust his Vf measurements (whereas his lumen recording seemed pretty accurate and I regularly rely to his charts).
When djozz did his “crash testing” he stated Vf as well and had 3.55V at 3A for an XP-G2. That sounded very reasonable - and is higher than XM-L2 with 3.4V at 3A and much higher than an XM-L, which seems to have a Vf of 3.15-3.20 at 3A. Here is the post of djozz with the graphs for XM-L2 and XP-G2.
My XinTD C8 V4 (XM-L2 T6 3C) gets about 33 kcd of lux (~360m); I wouldn’t be surprised if this XP-G2 version can get 60 kcd (~490m). It’s too bad they don’t sell a de-domed version; then we could probably have a stock C8 with 90+ kcd (~600m) of throw.
Does a XP-G (G2) really have that much more throw over a XM-L (L2)? Or since you are pushing the XP-G at 3A which is 2x times the 1500mA max current the reason? I know my XP-G at 1400mA gets CRAZY hot…at 3A…boy howdy!
The XP-G2 is roughly half the size of the XM-L2, or one quarter the surface area. However, it’s not one quarter as bright; at 1.5A it’s roughly half as bright as the XM-L2 would be at 3A. So, this means its surface brightness is twice as high as XM-L2. Run it at higher amps and it’s more like three quarters as bright as XM-L2, in one quarter the surface area. And if you de-dome it, the apparent size gets even smaller and more light goes sideways into the reflector instead of forward into the spill area.
It’s not because the XP-G2 is over-driven. It’s less efficient than XM-L2, putting out fewer lumens per watt. Instead, it’s because the XP-G2 has a higher surface brightness — more lumens per square millimeter.
So, long story short… XP-G2 will get you a smaller, more intense hot spot than XM-L2.
My numbers earlier were based on actual lights people have made with similar parts. My XinTD C8 V4 gets about 33 kcd lux with a XM-L2 at 3.04A. At the same power level, a cheaper C8 with de-domed XP-G2 gets 90 kcd lux. And some people have gotten 125 kcd.
This works for both reflector-based lights and aspherics. In my Ultrafire 838 zoomie, I just tried a XM-L at ~2A versus de-domed XP-G2 at ~2A, The XM-L got 14 kcd lux, and the de-domed XP-G2 got 60 kcd. The XP-G2 really does have that much more throw.
