Yeah I’ve been asking myself that same question too. :~
So I think I’ll do the same thing to aluminum MCPCBs what I’ll be doing to my copper MCPCBs - drill a 2.5 mm hole at the dielectric area then fill the hole with copper from an AWG 10 wire which is about 2.58 mm thick. That should do the trick (I hope).
About the same. From our members’ tests, pretty sure we can establish now that the limiting factor is almost always the dielectric layer. Once that factor is taken out, even aluminium base gives performance not too far from Noctigon/Sinkpad.
There is a new MCPCB with a Diamond like dielectric structure. The dielectric functions like graphite which is used by high end fixtures manufacturers as a thermal pad, in that it spreads heat both vertically and horizontally and can provide performance of copper PCB, in a ALU PCB (cheaper)
Interesting results, thanks for the detailed tests.
I think where this is most valuable is in modifying those oddball size stars that Sinkpad and Noctigon don't have, 25mm in the Aleto 26650, 32mm in (I forget what). Maybe even triplet/quad boards?
Looks useful. I hope you'll send samples to one of our members for review. Relic38 has done some nice reviews. Hopefully he'll be up for testing this too.
A couple questions though.
How can I tell from your webpage if a mcpcb is using DLC? Will a triple XM-L board be made?
Looks very promising but, as usual in marketing, the 'old' type board is drawn to perform worse than in reality; the heat when entering the aluminium core of the board will go circular in all directions, not just downward, as the drawing suggests.
In any case, I think the major bottleneck was already overcome by the direct-bond-to-copper-boards, I do not expect a performance improvement as high as when Sinkpad boards entered the market. But the electrical insulation between thermal pad and core is a really useful feature!
