Although website says they dont ship to Australia but I did receive my 2X and DX21 direct from Maxtoch/EST.
One MI2 NW thanks.
One MI2 NW thanks.
Beam distance figures quoted for the upgraded 2X at 700m, and the M12 at 616m would suggest stock output figures of 123kcd and 95kcd respectively.
With straight dedoming alone you’re looking at about 260k for the 2X, and 200+k for the M12. That’s around 1020m and 900m ANSI - serious throw.
Very interesting….could be very powerful lights once resistor and other mods done.
Yes! Exactly! That's what I like bout it. HD2010 all tweaked up stock - best LED on copper star, AR lens - that's like $10 in parts alone. Not as much to mod. The MaxToch finish, threading, over quality I've been very impressed with. So, this is a HD2010 as it should be -- not the total disaster dealing with TMART with pot luck driver, lottery on how many dings it comes with stock - and now they even changed the pill threading so it breaks the copper pill compatibility. Unfortunately the driver modes is the std 5 mode mess, but probably has a good mode memory and can be resistor modded -- but for me, the driver had got to go...
The 26700 5000 mAh battery is intriguing - need details.
I believe its just this light that they wont ship SN6X-2X. I have had emails with the guy here and it comes with batteries and a charger which I don't want but makes the light a lot more expensive.
I was in the first gb of the SN6X-2X and this brand is top-notch quality. Just as good, if not better, than the other main players. I even had it Vinh (ed).
What kcd did Vinh get out of the modded 2X?
I think a few guys had them running round 330-360k. Beinteresting to see what the new one would pull with its upgrades - could crack 400.
26700 battery but in pic just 26650?
I just let him do his thing. What I know is that he de-domed it, and now it runs on one cell with a dummy cell together. Although I have not tested it, he says it draws 5.8A. We both don’t have a lux meter, so I don’t know.
Why not SN6X-2X use 2x26650s battery tube?
2x18650s maybe I’m in.
2x26650s I will order for sure.
Here’s the link on the new Mission M12:
SN6X-2X
252mm x 68 mm x 25.4 mm
Mission M12
172mm x 63 mm x 33 mm
1 SN6X-2X
#‘s I got on the modified 2X, resistor modded driver so still uses two cells:
fresh Pana PF’s, 2.22A (4.45A effective at tail), lumens: 1,615 @start, 1,540 @30 secs, throw: 358 kcd, measured at 5 m
So the M12's head dimension does appear to match an HD 2010 - if reflector inside diameter is about the same, than it should be close to a HD2010 in throw.
I’m intrested in 1 SN6X-2X.
Wife’s gonna murderize me
put me down for 1 SN6X-2X and is it possible to order extra AR lens?
me too!
I’m kind of interested for Maxtoch SN6X-2X Um… wait the minute… group buy for Maxtoch SN6X-2X is more expensive than the one on the website?
http://www.aliexpress.com/store/product/MAXTOCH-SN6X-2S-usd59-50-free-shipping-S-for-Superb-Upgrade-SN6X-2-CREE-XM-L2/314381_955206794.html
or is there any different between Maxtoch SN6X-2S and Maxtoch SN6X-2X? ( beside the 2S is cheaper by $4 than the group buy price ) :~
2S was designed for outdoors/hunting - now more focussed on law enforcement etc I think since the lightweight M24 hunting light has come out. 2S really nice light.
The 2S with upgrades likely to be about 83k lux standard with 63mm head. Upgraded 2X likely to be more like 120K lux stock with 68mm head.
I would be interested in the M24, i got 2x in the last group buy. I only build gun mounted hunting lights so the M12 does me no good.
