Im having posting/editing posts issues tonight…
I’ll try it and see what happens (also try the posting thing). I have some of the cap’s on the way. So you use off-time with no mem and it works perfect? not as I described?
thx
thx
I don’t use it, but it should fix the issue you described. I’d be happy to test it out for you and make sure it works as expected, but it probably wouldn’t fit the timeline you want to work on this project on (eg it wouldn’t be tonight).
The 0x21 to 0x23 switch will change PWM modes which happens to double the freq which should help/fix the whine.
The preflash is a mystery to me. Can you give a blow-by-blow account of an example where the preflash happens and an example where it doesn’t happen?
better yet a couple videos. It's much more pronounced IRL.
*EDIT* went all out, have a 10mm XP sinkPAD, an XP-G2 R5 3C and a LEDLink 40* TIR incoming, going to lengthen the turbo timer when I'm making the rest of the changes while I'm at it.
yup yup
// phase corrected PWM is 0×21 for PB1, fast-PWM is 0×23
going from PWM to Fast = 9~Khz to 19~Khz…alot higher whine noise, older folks the whine might just be drowned out by our tinnitus
Possible solution would be to change
#define WDT_TIMEOUT 2 // Number of WTD ticks before mode is saved (.5 sec each)
To 0, (1 for ,25 seconds) but not sure if that would throw off the mode changes or not
The video moves pretty quickly for me (I understand it’s because of the ontime no-memory setup), but I think I see what we are talking about here. I’m still lost as to why it’s happening.
I wonder if the pre flash has anything to do with the code modifications you made.
A fair point.
@Cereal_killer - when did the preflash show up?
I suggest switching the “Input Format” on your post to Advanced Post Editor before you start, then copy/paste into that. You might want to put it in a “quote” too.
I guess this wasn’t such a great suggestion! Instead I’ll recommend using pastebin, if you can’t get that to work you’re really doing something wrong
Once you post a pastebin link we can easily use a diff tool to compare the original code with your modified code to look for errors.
I wrote the code before ever firing the light up for the first time so it's always done it. This is the only tiny10 I've built so far but I have flashed this code to a 17DD to mess with on the bench and it doesn't preflash but I had to edit moonlight to 3, my test XM-L wouldn't light at 1, other than tha it's exactly the same code (plus the 17DD V2 has a 130ohm resistor at R3 and of course a 70N02 FET as hardware differences).
I will get the code posted in a legible format in a couple hours, I'm away from my computer right now.
OK lets try this *again* (I think my phone is fighting my computer, now I'm having quotes not showing up in other threads)
/* * NANJG 105C Diagram * --- * -| |- VCC * Star 4 -| |- Voltage ADC * Star 3 -| |- PWM * GND -| |- Star 2 * ---
- CPU speed is 4.8Mhz without the 8x divider when low fuse is 0x75
- define F_CPU 4800000 CPU: 4.8MHz PWM: 9.4kHz ####### use low fuse: 0x75 #######
/8 PWM: 1.176kHz ####### use low fuse: 0x65 #######
- define F_CPU 9600000 CPU: 9.6MHz PWM: 19kHz ####### use low fuse: 0x7a #######
/8 PWM: 2.4kHz ####### use low fuse: 0x6a #######
- Above PWM speeds are for phase-correct PWM. This program uses Fast-PWM, which when the CPU is 4.8MHz will be 18.75 kHz
- FUSES
I use these fuse settings
Low: 0x75
High: 0xff
- STARS
Star 2 = Moon if connected
Star 3 = H-L if connected, L-H if not
Star 4 = Memory if not connected
- VOLTAGE
Resistor values for voltage divider (reference BLF-VLD README for more info)
Reference voltage can be anywhere from 1.0 to 1.2, so this cannot be all that accurate
VCC
Vd (~.25 v drop from protection diode)
1912 (R1 19,100 ohms)
|---- PB2 from MCU
4701 (R2 4,700 ohms)
GND
ADC = ((V_bat - V_diode) * R2 * 255) / ((R1 + R2 ) * V_ref)
125 = ((3.0 - .25 ) * 4700 * 255) / ((19100 + 4700) * 1.1 )
121 = ((2.9 - .25 ) * 4700 * 255) / ((19100 + 4700) * 1.1 )
Well 125 and 121 were too close, so it shut off right after lowering to low mode, so I went with
130 and 120
To find out what value to use, plug in the target voltage (V) to this equation
value = (V * 4700 * 255) / (23800 * 1.1)
#define F_CPU 4800000UL/*
- Settings to modify per driver
*/#define VOLTAGE_MON // Comment out to disable
#define MODE_MOON 1 // Can comment out to remove mode, but should be set through soldering stars
#define MODE_1 8 // Can comment out to remove mode
#define MODE_2 75 // Can comment out to remove mode
#define MODE_TURBO 255 // Can comment out to remove mode
#define TURBO_TIMEOUT 37 // How many WTD ticks before before dropping down (.5 sec each)#define WDT_TIMEOUT 2 // Number of WTD ticks before mode is saved (.5 sec each)
#define ADC_LOW 130 // When do we start ramping
#define ADC_CRIT 120 // When do we shut the light off/*
*/#ifdef MODE_TURBO
#undef MODE_HIGH
#define MODE_HIGH MODE_HIGH_W_TURBO
#endif//#include <avr/pgmspace.h>
#include <avr/io.h>
#include <util/delay.h>
#include <avr/interrupt.h>
#include <avr/wdt.h>
#include <avr/eeprom.h>
#include <avr/sleep.h>
//#include <avr/power.h>#define STAR2_PIN PB0
#define STAR3_PIN PB4
#define STAR4_PIN PB3
#define PWM_PIN PB1
#define VOLTAGE_PIN PB2
#define ADC_CHANNEL 0x01 // MUX 01 corresponds with PB2
#define ADC_DIDR ADC1D // Digital input disable bit corresponding with PB2
#define ADC_PRSCL 0x06 // clk/64#define PWM_LVL OCR0B // OCR0B is the output compare register for PB1
- global variables
*/// Mode storage
uint8_t eepos = 0;
uint8_t eep[32];
uint8_t memory = 0;// Modes (gets set when the light starts up based on stars)
static uint8_t modes[10]; // Don't need 10, but keeping it high enough to handle all
volatile uint8_t mode_idx = 0;
int mode_dir = 0; // 1 or -1. Determined when checking stars. Do we increase or decrease the idx when moving up to a higher mode.
uint8_t mode_cnt = 0;uint8_t lowbatt_cnt = 0;
void store_mode_idx(uint8_t lvl) { //central method for writing (with wear leveling)
uint8_t oldpos=eepos;
eepos=(eepos+1)&31; //wear leveling, use next cell
// Write the current mode
EEARL=eepos; EEDR=lvl; EECR=32+4; EECR=32+4+2; //WRITE //32:write only (no erase) 4:enable 2:go
while(EECR & 2); //wait for completion
// Erase the last mode
EEARL=oldpos; EECR=16+4; EECR=16+4+2; //ERASE //16:erase only (no write) 4:enable 2:go
inline void read_mode_idx() {
eeprom_read_block(&eep, 0, 32);
while((eep[eepos] == 0xff) && (eepos < 32)) eepos++;
if (eepos < 32) mode_idx = eep[eepos];//&0x10; What the?
else eepos=0;
}inline void next_mode() {
if (mode_idx == 0 && mode_dir == -1) {
// Wrap around
mode_idx = mode_cnt - 1;
} else {
mode_idx += mode_dir;
if (mode_idx > (mode_cnt - 1)) {
// Wrap around
mode_idx = 0;
}inline void WDT_on() {
// Setup watchdog timer to only interrupt, not reset, every 500ms.
cli(); // Disable interrupts
wdt_reset(); // Reset the WDT
WDTCR |= (1<<WDCE) | (1<<WDE); // Start timed sequence
WDTCR = (1<<WDTIE) | (1<<WDP2) | (1<<WDP0); // Enable interrupt every 500ms
sei(); // Enable interrupts
}inline void WDT_off()
MCUSR &= ~(1<<WDRF); // Clear Watchdog reset flag
WDTCR = 0x00; // Disable WDT
}inline void ADC_on() {
ADMUX = (1 << REFS0) | (1 << ADLAR) | ADC_CHANNEL; // 1.1v reference, left-adjust, ADC1/PB2
DIDR0 |= (1 << ADC_DIDR); // disable digital input on ADC pin to reduce power consumption
ADCSRA = (1 << ADEN ) | (1 << ADSC ) | ADC_PRSCL; // enable, start, prescale
}inline void ADC_off() {
ADCSRA &= ~(1<<7); //ADC off
}#ifdef VOLTAGE_MON
uint8_t low_voltage(uint8_t voltage_val) {
// Start conversion
ADCSRA |= (1 << ADSC);
// Wait for completion
while (ADCSRA & (1 << ADSC));
// See if voltage is lower than what we were looking for
if (ADCH < voltage_val) {
// See if it's been low for a while
if (++lowbatt_cnt > 8) {
lowbatt_cnt = 0;
return 1;
} else {
lowbatt_cnt = 0;
return 0;
#endifISR(WDT_vect) {
static uint8_t ticks = 0;
if (ticks < 255) ticks++;if (ticks == WDT_TIMEOUT) { if (memory) { store_mode_idx(mode_idx); } else { // Reset the mode to the start for next time store_mode_idx((mode_dir == 1) ? 0 : (mode_cnt - 1)); }
#ifdef MODE_TURBO
//} else if (ticks == TURBO_TIMEOUT && modes[mode_idx] == MODE_TURBO) { // Doesn't make any sense why this doesn't work
} else if (ticks == TURBO_TIMEOUT && mode_idx == (mode_cnt - 1)) {
// Turbo mode is always at end
PWM_LVL =185;
#endif
int main(void)
// All ports default to input, but turn pull-up resistors on for the stars (not the ADC input! Made that mistake already)
PORTB = (1 << STAR2_PIN) | (1 << STAR3_PIN) | (1 << STAR4_PIN);// Set PWM pin to output DDRB = (1 << PWM_PIN); // Set timer to do PWM for correct output pin and set prescaler timing TCCR0A = 0x21; // phase corrected PWM is 0x21 for PB1, fast-PWM is 0x23 TCCR0B = 0x01; // pre-scaler for timer (1 => 1, 2 => 8, 3 => 64...) // Turn features on or off as needed #ifdef VOLTAGE_MON
ADC_on();
#else
ADC_off();
#endif
ACSR |= (1<<7); //AC off// Load up the modes based on stars
// Always load up the modes array in order of lowest to highest mode
// 0 being low for soldered, 1 for pulled-up for not soldered
// Moon (stock is 1 then 0)
#ifdef MODE_MOON
if ((PINB & (1 << STAR2_PIN))> 0) { // Stock is ==, ( > for moon default to on, soldering star will disable moon)
modes[mode_cnt++] = MODE_MOON;
#endif
#ifdef MODE_1
modes[mode_cnt++] = MODE_1;
#endif
#ifdef MODE_2
modes[mode_cnt++] = MODE_2;
#endif
#ifdef MODE_TURBO
modes[mode_cnt++] = MODE_TURBO;
#endif
if ((PINB & (1 << STAR3_PIN)) == 0) {
// High to Low
mode_dir = -1;
} else {
mode_dir = 1;
// Not soldered (1) should disable memory
memory = ((PINB & (1 << STAR4_PIN)) > 0 ) ? 0 : 1; //to disable momory without soldering star use ? 0: 1; (stock is ? 1 : 0;)// Enable sleep mode set to Idle that will be triggered by the sleep_mode() command. // Will allow us to go idle between WDT interrupts
set_sleep_mode(SLEEP_MODE_IDLE);
// Determine what mode we should fire up // Read the last mode that was saved read_mode_idx(); if (mode_idx&0x10) { // Indicates we did a short press last time, go to the next mode // Remove short press indicator first mode_idx &= 0x0f; next_mode(); // Will handle wrap arounds } else { // Didn't have a short press, keep the same mode }
// Store mode with short press indicator
store_mode_idx(mode_idx|0x10);WDT_on(); // Now just fire up the mode PWM_LVL = modes[mode_idx]; uint8_t i = 0;
uint8_t hold_pwm;
while(1) {
#ifdef VOLTAGE_MON
if (low_voltage(ADC_LOW)) {
// We need to go to a lower level
if (mode_idx == 0 && PWM_LVL <= modes[mode_idx]) {
// Can't go any lower than the lowest mode
// Wait until we hit the critical level before flashing 10 times and turning off
while (!low_voltage(ADC_CRIT));
i = 0;
while (i++<10) {
PWM_LVL = 0;
_delay_ms(250);
PWM_LVL = modes[0];
_delay_ms(500);
// Turn off the light
PWM_LVL = 0;
// Disable WDT so it doesn't wake us up
WDT_off();
// Power down as many components as possible
set_sleep_mode(SLEEP_MODE_PWR_DOWN);
sleep_mode();
} else {
// Flash 3 times before lowering
hold_pwm = PWM_LVL;
i = 0;
while (i++<3) {
PWM_LVL = 0;
_delay_ms(250);
PWM_LVL = hold_pwm;
_delay_ms(500);
// Lower the mode by half, but don't go below lowest level
if ((PWM_LVL >> 1) < modes[0]) {
PWM_LVL = modes[0];
mode_idx = 0;
} else {
PWM_LVL = (PWM_LVL >> 1);
// See if we should change the current mode level if we've gone under the current mode.
if (PWM_LVL < modes[mode_idx]) {
// Lower our recorded mode
mode_idx–;
// Wait 3 seconds before lowering the level again
_delay_ms(3000);
#endif
sleep_mode();
}return 0; // Standard Return Code
I think you still didn’t get a good paste, the beginning is missing some stuff. Good enough to do a diff though, ignoring that stuff:
*Settings to modify per driver */ #define VOLTAGE_MON // Comment out to disable #define M
I’m not sure why you changed the variable names, but I don’t see a problem there.
At a glance I’m not sure what this section is for or why you changed it.
PWM_LVL = modes[—mode_idx];
EDIT: also I should point out that I’m assuming your code does actually contain this line at the top although it did not appear in your paste:
I changed the names cause this is modified from my 5-static modes version (plus moonlight) from a different build, when I needed to have more levels than stock it was just easier for me to number them than to make a "med-high/med-low".
I'm having lots of posting issues, I think its cause I'm using the standard mobile editor from my phone and now the advanced editor here and logged in from both at the same time, I am also having issues with quotes not showing up or just showing up as empty boxes. Lets pretend I'm not computer illiterate for a minute lol.
Later today I'm going to build a second Tiny10 FET for testing and load it up with the same code, maybe try adding a gate resistor somewhere (not sure where I'll fit anything else)
You didn’t address what this change was for, do you know?
I wasnt aware that was changed, I'm visually comparing it (to the first link here http://www.jcapsolutions.com/flashlights/firmware/) and thought it was the same, I didnt mean to change it, what should it be?
this is what you’ll find on the stock version (first link on that page)
this is what you’ve got that’s different
PWM_LVL =185;
Are you talking about where I changed the turbo timer? I did it like this because I no longer have a definition for "MODE_HIGH_W_TURBO" so I have to physically assign the level I want instead of telling it to use a predefined definition.
#ifdef MODE_TURBO //} else if (ticks == TURBO_TIMEOUT && modes[mode_idx] == MODE_TURBO) { // Doesn't make any sense why this doesn't work } else if (ticks == TURBO_TIMEOUT && mode_idx == (mode_cnt - 1)) { // Turbo mode is always at end PWM_LVL =185; #endif }
I see now, good idea.
I don’t see any code problems in that case, assuming you’ve got F_CPU defined and it didn’t come through in your paste. To make matters a little easier on me I renamed your variables back to the stock names, there are very few changes and they all make sense: Saved diff hv94kqvv - Diff Checker
Mouser shipping costs always bothers me too. The white sides you see in pictures is just a holder. You need to remove it from the holder to fit 15mm. TIR itself is 15mm, holder is 17mm. “Product page.”:http://www.ledlink-optics.com/ProductsDefault.aspx?ID=F7251BB9B00F4358B2B580AAC3D3A1A6 “Datasheet”:http://www.ledlink-optics.com/Images/Mockup/F7251BB9B00F4358B2B580AAC3D3A1A6/LL01CR-OTxxL-Mx%20DATA%20SHEET%20FOR%20CREE%20XP-G.pdf !http://www.ledlink-optics.com/Images/Mockup/F7251BB9B00F4358B2B580AAC3D3A1A6/2D/LL01CR-OTxxL-M2.jpg! Better diagrams are in the datasheet.
My TIR came today, the lens seems to be glued into the holder :( I'll get the dremil out later and see what can be done, hopefully I can get it cause I was really excited about the new flood beam pattern.
Alright finished up FINALLY!
The TIR came out, not just popped out like I thought but I got it (actually had to melt the holder with a soldering iron). The neutral white 40* beam is very even, no hot spot at all which is about perfect for me in the role this light will fill. I also really like the look of the TIR better than a smooth one, still I’d prefer a reflector but this is more than adequate. Also swapped the XP-E2 for a XP-G2 on a 10mm sinkpad so I could increase the turbo timer up to 60sec, step down was changed to 204 (~80%).
Beam shots coming tonight. The only thing else I’m considering changing is adding one additional mode but i’m not sure, I usually dont like more than 4 modes so I’ll probably just leave it as is, all in all I’m very happy with this whole build, much much better than stock.
Back on the earlier topic of memory: I have now used both on-time and off-time with “no memory” setup. Off-time with no memory is what you want, it behaves exactly as you would expect a light with no memory to act: half presses while the light is on do advance modes, but leaving the light off for a few moments causes it to start in the first mode when turned back on.
Sorry for the delay in checking this out, it ended up not happening until I had a need for it. Go figure right? 0:)
