I usually just buy it, receive it and only then think about whether I should have bought it. But by that stage it’s too late to decide not too. Haha
too funny Burgh.
just checked tracking and my $11 Convoy S2+ will be arriving in the next few days. Maybe that will satiate my thirst. Am I kidding? I think I am like a woman, I don’t need it, but if it’s on sale I’ll buy it!
Yes the FF4 has around 7000 lumens. However, you need a 4x increase in lumens to perceive a 2x increase in brightness. You’d definitely be able to see the brightness difference, but it wouldn’t be too much. Not to mention the MTG-2 is the most efficient emitter on the market right now. Also it doesn’t have warm up time so if you’re the type to turn on your light to check a noise outside HID is definitely not the way to go.
You’d see the difference easily but not because FF4 has more lumens but because it’s throwier. To human eyes focused beam appears brighter than the floody one.
Just got this light in. First impression is it’s very small. Installing the handle is a bit difficult because the integrated battery carrier blocks the allen wrench from fully spinning.
Also not sure if mines a defect but I have quite a bit of wobble on the handle. The screws bottom out before it tightens on the handle so there is a ton of wobble.
Not ideal but a few very small washers should fix that. Or you could grind down the screw and clean up the threads .
they started the thread on the 3rd, so if you ordered then, it only took 7 days to get here??? OK, it’s small and the handle is weird, I’m waiting for MORE, like those tandem MT-G2s! It took everything I had to resist purchasing this light. MORE please, thank you….
Shipping from hkequipment was very fast. I didn’t think it would be here so soon and I think I might have ordered a day or two after this thread was created too. Less than 7 days from HK to the west coast.
It is quite bright but I have not really tested it out much, still light out. The light gets warm very quickly on turbo. Heat coming out of the front end is also quite warm. The electronic switch is a bit mushy and doesn’t activate the light everytime its clicked. You need to push firmly for a connection. I wish the handle didn’t stick as far out, they should have kept it closer to the 2nd prototype but with just a little more room for fingers/gloves.
I personally think the second prototype had a good mount for the handle. It seemed sturdy and simple to take on and off. The way the handle is mounted now does not seem as sturdy and is a bit of a hassle with the included allen wrench. Here is a picture of some washers I found. I wanted to find something smaller to fit into the handle holes but didn’t have anything. With it installed the way I have it, the body tube tightens onto the handle and isn’t spinning closed as far it goes without the handle installed. Also a few pictures with a p60 light for comparison.
I can tell all that it is a real chore getting double-wrap protected batteries into the non-removable carrier. Yes, length was a chore, but doable. The width is more challenging.
I tore the black covers on two black EVVA 3400s.
Please someone answer.
1. Would Panasonic PF 2900 mah be better choice for this light compared to Panas green 3400 mah protected? (would both types fit?)
2. How much is the runtime before stepdown on turbo?
3. How is the heat management?
4. How much was the price when the light was in stock?
Thanks.
Yea I also tore the outside layer of a protected pana3400. The lip of the head where the battery slides across is a little sharp.
Anyone else have problems with the handle being loose? Am I doing something wrong? I’d prefer not to need the washers every time I take on and off the handle.
Can anyone please tell me coupon codes for general items on HKE? like one for all, i want to get some batteries and this light.
Bear in mind that this 5hr plus at 2000 OTF lumens is on only 2200mah cells as well and you get an idea of just how much of a game changing leap in efficiency this is.
Hey man, all i see is 400 lumen for 330 minutes. Where do you see 2000 lumen for 5h plus? the top of the graph is stating 800lm.
Relative overall light output. Not lumens.
Hey Guys!
in the german TLF some MM15 Owners had to smoothen the edges in the battery-Carrier with a file to prevent damaging them!
Just drop HKE and email asking for the bet price on light and batts combo, I’m sure they will see you right.
Doh! now its all clear
I was told today that they are out of stock until end of March and do not accept pre-orders right now…
The runtime is wrong!
On cpfitalia, we talked about it, if you already makes into the calculations is impossible!
2 people have carried out surveys, the duration of the 5th level with cells 3100mAh is about 2.30h
with a drop of constant brightness.
Yes, I finally got round to doing some calculations and current readings too. The readings give 1.05-1.15A on L5 (2000 lumens), whilst the original figures suggested impossible efficiency of over 300lm/w.
Selfbuilt has since acknowledged the mistake and updated his runtime graphs with accurate figures, as are now linked to in my original posts.
Having now got one myself I would like to point out that despite these mistakes in claimed runtime from earlier tests, the efficiency is still very good, especially for such a great and tightly binned tint. Output/size ratio is also still amazing (the 5200 OTF lumen figures were NOT mistaken!) and the overall quality is top class. I’m certainly still very happy with mine.
