Test/Review of Charger Xtar VP2
Very good charger of a very good review!!
Thank you! :Grade:
Your Lifepo cells must be in poor condition. After the 3.6V termination they don't hold the voltage.
I try to limit my wishes to functions that would fit the charger, anything with discharging or more bays is other charger models.
Like others said. Thanks for another great review..
Fingers crossed there will be a 4-bay version (with room for four 26650) and no MAP. 0:)
They never do and a charger that tries to keep the voltage up will get a lower rating.
great review, thanks as always!
50$ for 2 bays….hmm…
Thanks for the review btw, as always amazing HKJ!
0.20V drop "self-discharge" from 3.6V to 3.4V. within 15mins.
Yes, LiFePO4 does not work the same was a LiCoO2. When you start discharging them they will drop to about 3.2 volt very fast and stay at that voltage until they are empty.
Here is a full test of a LiFePO4 cell: http://lygte-info.dk/review/batteries2012/Unknown%20RCR123A%203.0V%20500mAh%20%28Blue%29%20UK.html
How are the sliders on the VP2. I stopped using my VP1 for 18650 because trying to pry back the slider and holding it in place while the cell is inserted became too much of a pain. I now mostly just use side by side SP2s.
“The slots have raised battery connections, i.e. flat top batteries can be used. The slider works very smooth and can take batteries from 30mm to 71.2mm”
Awesome review, thanks. I have been wondering about this one. I share the same idea as others in that I hope they make a 4 bay version soon.
’ken oath
Great review, thanks!
Can't wait to receive mine. :)
Daggum…look how flat those discharge volts are…wow!
:santa: “VP4 sample is still being tested now, we still need a couple of months for the development.” :santa:
Oh yes, I have one of this hot charger coming up at no cost at all. Thanks Xtar!
I imagine the VP4 will be the long anticipated replacement for my i4
But will it be good enough to replace the Opus?
We can’t compare the 2 chargers since the Opus is an analyzing charger/discharger, including facility for Nimh, while the other one (VP2) is a pure Li-ion charger only, (full list of functions not yet known) for the ‘VP4’.
I agree :slight_smile:
