Sirius9
I think I recognize that....."not even asking"
Yeah there isn’t much interest. That’s ok though because it gives more time to spend making other projects. I have a few p60 builds for myself as well. This offer is simply so others can have a customized dropin. (except modes, the qlite and nanjg are decent for a p60 though)
I spend the majority of the build on the heatsink. Copper under the led inside of the driver cavity. It takes some time to get it perfect and it feels great when it finally is press fit and soldered or adhesive fixed.
I agree that ceramic2 and silver are expensive, I have them so I use them. I do find putting ceramic2 on the reflector threads does help though.
I’m not a fan of dedomed emitters, I have a couple that throw well but the tint is ugly.
For the money there are a lot of dropins that do the job for a fraction of the price, it’s all about how they are made. Like anything in our hobby attention to detail is all the difference.
These are two dropins that I’ve recently finished.
The left is a nichia 219b on noctigon, soldered to pill with a 1.52amp qlite 4 mode driver and orange peel reflector. The reflector outside base has been sanded smooth and a brass ring added in the reflector groove.
The right is a xpg2 r4 5a on noctigon, soldered to pill with a 3.04amp qlite 4 mode driver and smooth reflector. Reflector outside sanded smooth and has a band of copper braid in the groove.
Both have spring caps, braided springs and reflectors adhesived in place. These are both going to the same owner.
Thanks for looking
Bushwhacked
Nice little project bushwhacked. Is that copper braid wrapped around one of those P60s? Projects like this start slowly, then word of mouth builds.
Do you cut your own copper rounds for the underside of the pill?
Thanks Ouchy.
It is copper braid 2mm wide pulled tight so it encompasses the majority of the gap. The hardest part was getting it soldered together without the braid sucking all the solder. Since I use tin/silver solder and high temperature I was able to kind of drop a bead to join it. Doesn’t look perfect at the joint but it did turn out well.
The copper rounds are actually pennies that I file down and then sand and polish until they fit perfectly. This makes a mess when I use Arctic alumina expoy on the sides because the heatsink has to go in straight down. I would use copper but I’ve got a pretty good method with pennies and they turn out awesome I usually use 3, some dates are thicker though.
The worst part about using ordered parts is making the pill flat, the machine that makes them always leaves a dip and uneven shelf. I have a 16mm c clamp and some old MCPCBs that I use to straighten and level them out.
I started my flashaholism on p60’s and love them. Building them is fun and enjoyable for me.
Sounds like you enjoy paying attention to detail.
I mentioned the copper, because I’ve found that those sanding drums for Dremels grind down copper fast and evenly. Who’d of have thunk it? I always ignored them thinking they were only good for wood.
I use the sanding drums on my dremel 4000. Lately I’ve tried with the cutoff discs. Just to chew off the lip of the penny. It works pretty good.
Until I got my dremel drill press (it works ok, not for drilling metal though) I had pennies flying all over the place. Those drums chew copper up, sometimes a little too aggressive.
This is one I’m working on right now. It almost fits. When it’s at this stage I use 600 grit paper until it just fits then I polish the edge until it slides to the bottom, force it out, then adhesive it in place.
If I’m going to change emitters in a pill for the future I’d solder the heatsink in.
Really, go Canadian. 1996 and older are 98% Copper, older U.S. are 94%.
I have around 200 1996 and earlier Canadian pennies and 50 or so American pre 1982. That America one is 1964 and was thick so I used it. I usually leave the driver side of the penny face intact, it’s usually a maple leaf, this time it’s Lincoln or whoever that guy is.
…and hey guys, yeah i finally got these two and they are both top notch and really kicking ass!
I can only say: Get them while they last!
Greetings from Germany and very kind regards to bushwhacked, really damn good work!
Hi Jeremy, i’m really so deeply satisfied with the dropins you made for me, i would like to shout this out to the whole community!
Oh damn’d, how could i convince the P60-loving-people to get a dropin hand-crafted by you? :~
Hey gals and guys, the dropins i received from Jeremy are really top notch - really! They are heat-managed the best, i could think of and are cranking out a full sh*tload of f*cking awesome blinding bright light, it is really delightful! :party:
You’ll love it!
PS: Sorry Jeremy, for being so enthusiastic, cause i just impressed some fellow flashie-guys with the dropins, you made for me. I think, they’ll contact you for getting their own precious jewels made for them by you.
Thanks Uli. The ones I’ve made for you are better than any I have made for myself.
I’m glad they impressed some others, they are some very nice dropins. That nichia is especially nice, I’m surprised how cool yet not cool the tint is. Creamy white with no blue is very nice.
Hope you have fun with them and thanks for the words of encouragement and the bump to the post.
bushwhacked Aka Jeremy
Hi again,
i’m sorry to sound like a fanboy, but sorry, i am a fanboy of his productions and you would be too, if you would have a chance to get a dropin like i already have from bushwhacked. The ones, he made for me, you would die for - really - i would bet on that!!
…long story short: Contact bushwhacked and get your own dropins, you won’t regret it - promised!
Oh lol.
Mid summer bump with the op edited.
Do you build any triples or quads? Looking for a nice mule drop in but if not a single LED might work for me
I would like a UV drop in.
I have a 502b to send you.
I’ll need more details and have to order parts. Pm sent.
The latest build.
This is an xml2 U2 1A running 3.5 amps on high and 1.7 on low from a nanjg with 10x 350 7135 chips. It has been fully potted with a copper heatsink, the reflector polished and groove filled with a brass band.
The owner doesn’t have it yet so I can’t say if it’s a winner yet but I’m sure he’ll be happy.
Thanks for looking.
Bushwhacked
Sent you a PM with questions. Thanks.
