The one marked 4 1 correct? I haven’t but I can tonight when I’m working if no one else has the data.
Thank you C_k, I want to parallel RMM’s efforts on the voltage ladder for the Zener mod but it hinges on correct data for this diode and the existing Qlite diode(if different). The Qlite specs quoted from Mtnelectronics are 2.9-3v step down and 2.8v imminent shut off and I assume this is the voltage under load and accounting for the diode drop pin 7 should see less than that. I’ve heard .25v thrown around but the 41 shows to be more like .3~~.4v so pin 7 might trigger when Vcc is as low as 2.4v or as high as 2.55. The actual voltage pin 7 sees is determined by R1&R2 and is somewhere around .47~~.5v depending on the diode. If we keep the 4.7k R2 and just replace R1 then knowing the diode drop allows us to choose the correct value for R1. I’d like to order some 0805’s ASAP.
Will it matter if I measure on a 105c or a 17DD? Either would have stock resistor values.
None of my 105’s have one of those diodes, they all have stock S4’s but if that’s important I could swap one out to get a measurement on a 105.
Go ahead and measure the S4, please. I have some of the digikey cart diodes at home.
I compiled a list of different values for R1 keeping R2 the same at 4.7k ohms using different forward voltage drops on D1. This is for a Zener mod of drivers and firmware that use 19.1k and 4.7k for R1 and R2.
Assuming that the battery voltage under load trips lvp at 2.8v and that R/(R1+R2) = .1975 for those two values then when the voltage drop across D1 is:
Case #1, .25V pin 7 sees .1975 x (2.8-.25)=.50V
Case #2, .3V pin 7 sees .1975 x (2.8-3)=.494V
Case #3,.35V pin 7 sees .1975 x (2.8-.35)=.484V
Case#4, .4V pin 7 sees .1975 x (2.8-4)=.474V
I went to the mouser catalog and looked up replacement resistors for R1 that would give these same voltages when the battery voltage was 5.6V or (2 x 2.8V).
For D1= .25V, R1= 47.5k ohm
For D1= .3V, R1= 48.7k ohm
For D1=.35V, R1= 49.9k ohm
For D1= .4V, R1= 51K ohm
Mouser has these values in 0805 1% for ~ $.10 each so as soon as I get some decent values for VD1 I’ll order some to try out.
Even at a full charge of 8.4V pin 7 will still see less than 1.1V so I don’t expect to blow any mcu’s however…
I realize that this is somewhat different than what RMM did so I expect this will be all wrong and I’m not encouraging anyone else to try this but just posting what my plans are.
Why is the voltage divider placed after the protection diode anyway? Seems to me that we’d be just as well off not having the diode in the mix other than providing VCC to the MCU.
I thought they avoid to modify the Nanjg board. It should work to place the voltage divider after the protection diode.
Microa - yes, after the diode does work. Results change when the diode is swapped for a different value. If we put the voltage divider before the diode (only use the diode for VCC) then we would have no need to worry about diode value.
Sorry my typo. I meant the voltage divider directly connected to VCC is OK.
Gotcha!
The protection diode isn’t in this part of the circuit for the Zener mod but to calculate the correct voltage that pin 7 sees normally it no needs to be accounted for. If you were to remove it from a normal 105c then the protection wouldn’t register until the battery was dangerously low.
My point is that you are setting yourself up for a job that will end up needing to be done again in the future. Why bother when we can eliminate the task you asked about (measuring vDrop on the protection diode and changing formulas in the firmware)?
You didn’t start the conversation about a normal 105c, it was about Oshpark boards. If we modify the design to supply the divider with BAT+ instead of hooking the divider up to the protection diode then we’ll simply need to adjust resistor values to achieve the appropriate ratio for the divider. That’s a one time job, changing brands or models of resistor in the future will not have an effect on the voltage supplied to the ADC (unlike changing brand/model of diode). VREF will be constant, unaffected by the diode or absence thereof. Hopefully you see my point now?
EDIT: adding pic for clarity, see below.
I saw your point before and it is my intention to bypass the diode for Zener mods but to correctly figure out what resistors to use I need to be able to account for any diodes being used now. Doing a Zener mod and keeping low voltage detection with any driver that has the diode in front of the divider requires knowing the voltage drop of the diode. Obviously if the diode doesn’t precede the divider then the correct values can be anticipated.
I have not measured the diodes directly, but, when using the DrJ firmwares that blink out the battery voltage, it gives the same number of blinks as the original Nanjg S4 diode. That's only a resolution of 0.1v but it doesn't have to be that close. It's not like a cutoff of 2.8v/cell vs. 2.7v/cell will make a significant difference in actual use. I think nearly all cells get their factory capacity ratings from being run down to 2.75v anyway (some even cheat and run them all the way down to 2.5v).
Sorry, I couldn’t see where you were coming from there. Now it makes sense to me!
I confuse myself sometimes. I should not have mentioned the digicart diode since the S4 is likely the only one I need to worry about but I wanted to solve the general equation before moving to specific examples. CC is quite right about the resolution here but since margin of error is additive I’d like to do what I can to not make it worse. Mainly I’m just stumbling along trying to figure this stuff out and posting my ignorance for all to see. Usually Texaspyro will come and save the day with dry wisdom. I was never shy about asking the stupid question in class.
I think the error factor might be more of an issue using two cells as slight cell imbalance combined with .1v or more error might be an issue. I guess it depends on how far apart the cells are when the combined voltage hits 5.6V.
Do you mind restating, in it’s entirety:
- what you are trying to achieve right now
- what you need in order to accomplish it
In other words “get organized”(thank you Wallace&Grommit)
I will be using a 105C board with the 7135’s removed and the mcu replaced with one flashed for me by Dale.
It will have an Lfpak56 FET since I have some(rated for 100A) and fits the board with no overlap of ground ring. The pins don’t match the 70N02 so I won’t be using an Oshpark board.
Existing 4.7k R2 and new value for R1(somewhere between 47k and 51k).
The 7135 position closest too output traces cut, D1 as the jumper for Vin, a jumper wire from Vout to Vcc.
Voltage divider disconnected from Vcc and jumpered to Vin using current L+ pad or somewhere on the pwm trace after D1.
After all the work on the Oshpark boards by others I must be just a glutton for punishment. Here’s a pic of the board I’ll be modifying. Q3 is where I’ll put the voltage regulator and I’m thinking of drilling through the pwm trace for a direct path for L+.
Getting back to the main topic of the thread, if I connect the divider to B+ before the diode I need to know the voltage drop of the diode but if I’m using the same diode and connect the divider after the diode I just use 2.8v per cell to recalculate R1? This doesn’t seem right to me. I think you still need to know the voltage drop across D1 to get the correct value for R1 but wth do I know? Maybe you’re right in that not knowing VD1 won’t give you the exact value of the actual voltage read by pin 7 but will still give you the correct resistance value if you match that offset value. I think I need an Ervin translation.
Cool. Yeah, you are clearly in it for the pain. With your simple changes I’m sure someone here would be willing to generate a PCB if you had a change of heart.
- You need to keep D1 because LD2981 does not have reverse polarity protection, right?
- I think you’ll need a second fly wire to get from the protected side of the diode (towards the outside of the PCB) back to Vin on the LD2981.
- You’ll need the support caps for LD2981 I suppose, so you’ll either need to keep C1 in place and add an input cap for the LD2981 somewhere or you’ll need to strip C1 and place both input and output caps somewhere for the LD2981.
- In order to use C1 you’ll need to cut both of the other traces leading away from the via - the one that goes to D1 and the on that goes to R1.
- Once you consider your cap needs it seems easiest to me to cut the trace that feeds the divider and use a fly wire to attach the divider to BAT+.
So that looks like 3 fly wires to me, several cut traces, and stacking 1 cap (the input cap) on top of the pins for the LD2981.
