4.2A, where are you getting these numbers? Maybe stock but these are great FET’s. I have built several of these exact drivers by piggybacking a ATTiny13A and they run ~18A of a set of 25R’s.
Maybe your talking about that’s the max from a resistor mod but these exact FET’s are capable of of nearly 5 times that when properly controlled, it’s the stock MCU that’s the problem.
Can you please take a pic of your driver, I will try to take a pic of mine and show you which component I am talking about? I will be very happy if I am wrong…
Sorry for lousy pics, used my tablet.
Q2 is the fet I am talking about, I believe it can deliver around 4.5A, it is marked 9926, are you saying this driver will deliver 15-20A with that fet?
I am not sure of the component that should be placed on Q1, I think that is the fet that delivers high current….
Quick update, hopefully good news, seller sent me an email asking why I felt this “Aluminum slice heatsink” wasnt enough, it pretty much proves my case, I’m giving him 24 hours to make an offer to fix this or I will be going to paypal, he pretty much provided me the only evidence I will need.
Flitsmal I t looks like you got a different board revision, Q1 is a different FET (N-channel). I have no idea about that 8 leg FET you have, on mine a normal (2 legs plus tab) FET is at Q1.
If you got that then you got what you paid for, as long as the stock light works as intended. If they have a returns policy, use it. Otherwise, you didn't bargain for a light that was good for modding, and the light you received isn't defective. That's just my opinion.
New update (also paypal case opened but seller is still responding at this point so not escalating it yet)
5 of the lights have heatsinks! Not the normal screw in shelves like I’m used to, these are just drop-in pieces and the I.D. threads on the body have been removed on those 5 lights. This means even if he supplies me with 5 of this style HS I would have to turn them down or turn the threads off the body for them to fit.
Man I’m so glad I opened one of the no-HS ones first and found out, it would of been terrible the other way around.
Right now my plans are to either return them for a refund and buy from somewhere else (and risk getting ones with XM-L’s therefore costing me nearly $100 more buying emitters) or get a partial refund of ~$100 and either buy HS’s from bucket or have my guy make something better to fit.
If the end result is me having my buddy make something to fit I’ll probably have him go as far as to turn the I.D. threads off the 5 and make 10 press-fit, solid emitter shelves, with a tight press fit it should be better than any stock configuration anyway.
fyi, the TMART $39 listed 5 LED Tangpower-TP-Fing-5-CREE-XM-L-U2 also has no pill top. Just got one when they were on special, so between the discount, coupon, and points, I only paid $24. The good thing is it came with XM-L2's and not XML's as listed, it's got good amps and is pretty bright, but drops quick as expected...
IMO, I don’t think you can return it as “incomplete” lights… if anything you can return it as you’re unhappy about the products.
He sold you what seems to be working lights just not as modable as you want it… it is completely different story.
The seller never want to know what will you do to the light… he just knows that his lights is working perfectly just fine, maybe not as bright as you want it to be. (we got spoiled didn’t we? )
I wanted to say pretty much the same….
I paid $40 for basically the same light as he got… ( But I did only order one….)
I can’t complain, the way I see it, it is a working light with xml2 LEDs, not driven very hard…
But that’s just my view….
For interest, can one actually order these ‘heatsinks’ separately anywhere? Apart from a custom made job, as I believe Bucket does…
With 4 x 18650 and 3 x XM-L you would expect it to have some performance. IMHO its deceptive and possibly defective.
If the quality Supfire M6 can be produced & sold for a profit at $40 ($38 on sale) then $40 for a piece of junk with no heatsink is a rip off. They could have made it proper but there is more profit in junk clones of what originally were good lights.
Some of the sales of these junk clones come from reviews of quality SRKs. It looks the same on the outside for exactly that reason. The original sold well… because of its design inside & out. If they wanted to create a different light then don’t clone the outside of a SRK.
Honestly, it hard to fully understand why people defend it. When you’re use to the market being flooded with junk clones of clones we might forget that its done to be deceptive. Some copy a design but without the same name on it. Thats acceptable at least. Clone the name too & can’t tell it apart from the real, quality one. Deception to piggyback on the sales of the real ones. Why should we tolerate it?
It may not be the sellers fault but we can’t directly hold the manufacturer accountable. Only recourse is through the seller.
Wow…the star doesn’t even contact anything…it would be one thing if it sat on a shelf, at least a little heat would wick away…that doesn’t touch anything…all the heat buildup would just keep building up and building up…daggum!
