Thanks HKJ.
2 diodes, 1 transistor, and I guess the fourth component is an oscillator to drive the transistor?
Maybe that you could put capacitors at the input/output to be able to measure the efficiency? Because thatās one important data that we donāt have here.
I know that you said that you were testing with an XP-G2, but I was wondering what the maximum emitter voltage this driver can output? Iāve noticed that boost driver specs donāt usually specify thatā¦ is that because thereās an implicit assumption that youāre trying to drive a certain type of emitter?
A boost driver wont have any problem driving different LEDs with different Vf. Heck, you could probably even run 2 LEDs in series and that would still work! But with this kind of unregulated driver, the higher the Vf, the lower the (average) current will be.
A perfect boost driver would supply a constant current no matter the input or output voltage (There are always limits though), but thatās too much to ask for a driver that small I guess.
Probably this sentence: This driver is always pulsing the led, spoiling any power and efficiency calculations.
Adding capacitors would change the working condition. I could do the calculations with my oscilloscope, but that would require a lot of manual work.
Depending on how the driver is made, there might not even be a limit on the maximum voltage, except when the driver destroys itself (Notice how some drivers says they may not be run without load).
To keep my testing time reasonable I only test at the specified parameters for the driver.
To get power you need "average(voltage*current)", not "average(voltage)*average(current)".
As long as voltage and current are fairly stable, either of the two works, but when both voltage and current bounces up and down, they must be multiplied, before doing the average.
Except if you had an analogue power meter, like electric companies use or did use, it would do the multiplication in analogue before the analogue averaging. I think the one I saw used two coils attracting each other, one with the current in it and one with a current that depended on the voltage (resister limited maybe). The mass and damping of the rotating part did the averaging.
I got a couple of theseā¦tied one into a XT-E I got on a whim as a test on my benchā¦whoah bright with a AA (but arenāt they all when you are staring right at the emitter when you fire em up )
Different components, but also a small booster driver (I don't have a NANJG 102): I hooked an old sk68 driver on a AA-NiMh battery to a MT-G2, it only delivers 2mA to the led:
Yes the electric company ones must have used iron core magnets. If you use only wire coils with no core, like the one we used in a college physics class probably had, it will work up into the microwave range.
