Anyone know what cap value/size to use for off time memory? I've been post hunting, but just can't find it - not on Jonny's web site, not mentioned in the source code for STAR_off_time, not on Richard's website, can't find it here, can't find a thread for it, just can't find it, period... Help? I know it must be somewhere?? Is Jonny's STAR_off_time the only driver source code that uses it?
I believe it goes between an IO pin and ground, from a comfy pic somewhere...
1uF works well and is the specified value. It’s in the OP waaaay at the bottom. Other values work too though, HarleyQuin investigates this on page 5 of this thread.
In terms of other firmwares that use a cap, Tido’s firmware (BLF-VLD) supports offtime but I don’t remember if it worked with just a cap or a cap and a resistor or what.
Thanks all! I ordered those caps off of the eBay link. I missed mentioning of the cap value in the OP. My links to posts don't see to work - very frustrating... The comfychair link I could not find
I put the cap between star 4 and the ground ring on the 105c. For the AK-47A I want to keep the bottom free of components so I put the cap on two pads marked R4. It connects pin 2 and ground just like using the 4th star.
The 101-AK-A1 is a little more difficult, there is no straight forward location for the cap. I haven’t done one yet, I just stack 7135s on an AK-47 if I want more than 1 amp with a flat bottom driver.
You are not the only one - it seems different people are using a different number of posts per page, so a link to a specific post that works for one person is broken for somebody else. Site really shouldn't require the page number in links to specific posts, or something. Links in notification emails don't work either for the same reason I think.
I can only get to the post in that link by changing the '?page=7' to '?page=4' - https://budgetlightforum.com/t/-/25032?page=4#comment-573278
Oh -- found out more... I had my setting at 150/page while locusto03 must be using 30/page (experimented til I found one that worked). I set mine to 50/page, thinking that's the default?? Not sure...
I’ve been wondering about the specific post links too. I don’t have a solution, but I try to reduce the issue by using links compatible with the default page size. The default is 30, which I checked by viewing BLF in a browser with no login and no cookies.
I built one that has a pseudo-hidden strobe... modes are 255, 255, 255, 255, STROBE, with no memory. Turning on/off or accidentally bumping the switch it pretends to not change modes, but you can get to the strobe if you need it.
Thanks comfychair. Yes, it is logical to make approach that way, I will probably end up with something like that. But here is a new idea:
If the modes in one setup are called a group of modes, how hard is to implement two groups? So group 1 would be low-medium-high but if we click (not click but tap or momentarily activate light without click) certain number of times it would change the whole group. Maybe fast clicks and it’s not low-medium-high any more but group 2 which is strobe-high, for example. Fast clicking 10 times goes back to low-medium-high.
I’ve been playing around a lot lately with optimizing for size and have managed to do a slimed down version of STAR 1.1. Mine basically does everything that STAR 1.1 does except check for soldered stars. I removed all those checks and did those selections by using a bunch of #IFDEF and #ELSE sequences. I saved quite a few bytes doing this. Personally I have no use for soldering stars, if I want to change the things the stars changed I’ll just flash a driver with the changes.
I also made a new delay loop by stealing a small section of code from delay_basic.h. My time resolution is not good (77ms) but for my purposes I can get the delays I want, I don’t need pin point accuracy.
Then I edited the voltage monitoring sequence quite a lot, removed a bunch of while loops and delay loops, and saved a total 278 bytes on the original STAR 1.1… That leaves me with plenty of room for playing around
I’m no programmer though. I’ve tested the functionality with the help of a variable DC power supply, seems to be running fine but I guess I’ll see once it’s been built into a light.
Sounds like good work so far. Will you post your current code? If you don’t have hosting you can use http://pastebin.com (or any similar service) to share it with us.
Beautiful thing is…if you can trim in down with code tweaks, more functionality can be added on the back end
Maybe even put in hidden flashies or whatever
