Paranoid? Don't think so, we just need to be careful with this things. Better safe than sorry. :bigsmile:
I finally got my charger. The only question is, real or fake? Question: For some reason I can't get images to display in this forum. I have no problem in other forums I belong to. What am I doing wrong?
I'm charging ultrafire 3200 mAh's I have on hand right now. I know they're not great batteries, but they're all I have right now and they do just fine in my Fenix TK35. I do have Xtar 2600's and Panasonic 2900's on order. Hopefully they will arrive soon. I'll measure voltage when charging is complete.
Keep us informed ;)
Here's my findings so far. The charge current pulses on and off at a fast rate according to my Fluke 189 multimeter. Isn't it supposed to be constant current? It does read a little over 600 ma on peaks. Again I'm using cheap Ultrafire 3200mAh cells. Also the end charge voltage is around 4.09. Is this due to the fact I'm using sub standard cells? Or do I have a fake charger? (I only paid $13 for it)
That Fluke is awesome :P Check this review, glenn. WP2 tends to terminate early (not a bad thing, actually. will extend cell life). And yes, it depends on cell also. If you need to charge it further, charge it again. I think (for a 18650 cell) you will need half an hour more, just wait till it turns green again ;)
So, if you can make graph like that (in the review I mean), you'll see if it's a good WP2 or a fake one. I think it's a good one, they (Xtar) just chaged it a bit.
SashiX, I discharged my cells in my TK35 to the point that the turbo mode no longer worked (even after powering off, then on again) Unfortunately I didn't measure the discharged voltage. I recharged and then measured the voltage
First pair: Battery 1: 4.0606 volts Battery 2: 4.1065 volts
Second pair: 1: 4.0474 2: 4.0615
About 5 minutes ago, I got a pair of each Xtar 2600mAh and Panasonic 2900mAh in the mail. I'm charging the Xtar's right now. Will update later
P.S I originally purchased the Fluke for my job 9 years ago, but I decided I didn't want to wreck it's appearance with the kind of work I do, so I kept it at home where I can baby it :) I use a Wavetek HD160 industrial VOM at work
Mine looks exactly like the WP2 II, minus the USB port. One thing I forgot to mention, mine didn't come with the car charger adapter. I'm not complaining since I only paid $13 with free shipping. Plus I don't need one.
So, this 20$ Xtar comes with car charging cable but not USB-output cable?
Would be a bit of "multitool", if you could use it from car socket and for sudden need to top up your Cell phone.
Anyway atbglenn, I suppose there´s no problem in charging these longer Xtar 18700´s with this since you are on to it right now?
I know they won´t fit in my WF-139 since TF Flames barely do.
Hi there CheapThrills! The 18700's fit just fine in the WP2. They just finished charging. I'm going to leave them in for another 30 minutes, take voltage measurements and report back.
Glenn
Sounds good Glenn, looking forward to hear how they do!
okay! Here are the results of my new Xtar WR2 charging my new Xtar 2600mAh 18700's
Battery 1: 4.1325 volts
Battery 2: 4.1392 volts
WOW! Very well matched! It pays to buy quality batteries. The charger and Xtar batteries get a thumbs up! I now have my Panasonic's charging. Will report back later!
Seems to be a good match indeed!
As I said before, WP2 tends to terminate early. Better for cells, IMO.
Ah, btw, Glenn, try to charge them again. And, as I said before, in half an hour you should have them at 4,19-4,20V ;)
UPDATE: I bought mine from kelesecurity, if I remember well, for 15 or 16 bucks. Came w/o car charger also, but no complaints, I don't have a car :bigsmile:
I've got them on the charger again. Will report back soon...
Edit:
Before
After reinserting for 30 minutes
Battery 1: 4.1409 volts
Battery 2: 4.1416 volts
Not much difference, but at least there is a difference.
Hm, no difference for me :|
Happened to me once, with my TF black/flame cell (don't remember if it was 14500 or 18650). In fact I think it was the first time I charged them. After that, 4.17-4.20V every time.
And again, it will depend on cell (and DMM too, I think, lol :bigsmile: I have an UNI-T UT33A multimeter). In real life, that 0.05-0.07V will be 2-3 min on MAX.
BTW, after 30 min or after you have seen green leds (=cells fully charged)?
I did 30 minutes from the time I reinserted the cells. The charge light stayed red for a couple of minutes before turning green
I'll try a discharge-charge cycle next and see what happens
There is no sense waiting more after it turned green.
Yes, try to discharge first. Could be the same thing happened to me: first charge - 4.14V or so, then >4.18V ;)
Anyway, it's a good charger for that price :) The only thing I dislike it's the body: the flat part where the cells are placed. That part should be rounded (sorry, don't know how to explain it better. Example here). No prob for 18650/18700 cells, but smaller cells aren't secured as well.
I thought it might trickle charge, or top off after the green light can on. Anyway I've partially discharged my cells down to 3.7 volts, and now I have them on charge again. We'll see what happens.
I see what you're saying about the charger body not cradling smaller cells. It's not currently a problem for me since I'm only charging 18650-700's at the moment. I do have a Tenergy 01269-01 charger that's better at cradling smaller cells..
Getting back to an earlier question I had about posting images from my photobucket account. It's weird because I post pictures to my ebay, macrumors, head-fi, candlepower, etc, etc accounts with no issues. I tried every way possible including the insert/edit image function at the top of this page with no luck. Any help would be appreciated.
Glenn
