The NW 5A3 is great, same as your regular Osram/Philips 840 tubes, a wee bit warmth in it. 5000k is also ok, i wouldn't mind both. But I am an easy person with tints, CW, WW, NW all suit me. But CW and WW greenies are out. (I have a 335 emitter based LED strip which is pretty green, skin tones all look wierd under that strip)
Ian, you can use 1 x 18650, 2 x 18650 or 3 x 18650, no issue. The cells are parallel in the holder. It fits 32650 6000mAh as well. But do note 3 x 18650 matched cells is cool as well as pretty safe, as that'd be 9.3Ah.
petebaby, you asked about the spacing of the 4-mode 3A neutral white. With 3 full charged XTAR 2600s, it is 2.06A, 0.78A and 0.17A. Reflected ceiling lux is 150 for this NW, compare this to the 130 of the Trustfire 3T6 CW and 160 of SkyRay SR3800 CW. The CCT difference of NW already gives it an approx 15% disadvantage as compared to CW (you do know about this right, WW is even less efficient). But seriously with such bright lights, the difference close-up is very difficult to differentiate due to how your pupils react by constricting.
In high - and in my tropical country where the nights are still a warm 30 deg C now, @ 2.0A 3 minutes run is somewhat warm, you can push further by trying to withstand the heat but i'd not try. This is to be on the extremely safe side. 0.78A @ 12V still gives you a heck lot of light.....as much as a fully driven single XM-L. You can run at this level for very long periods due to the heat mass as well as some 2X surface area compared to a single XM-L single 18650 light, 20 mins no issue. The single 18650 XM-L 40mm light like C8, it might get quite toasty.
If you really want bright, you'd have to go the DD 4A. But seriously this turns into a pocket rocket, ie very short runs only. If you are well below zero during winter, i supposed multi-minute runs are a piece of cake. BTW, 2A and 4A is not twice as bright, it does not scale linearly, unless i guess if you live in Antartica - 60 deg C with high winds.
DasFriek, this is my first warm-tinted light, and probably the last. :) I am learning to appreciate the benefits of neutral (and warm) white in a woodland setting, but am a cool white guy, at heart.
A mildly off topic question, but there are some knowledgable people here on the DRY light. Does the 4-mode CW come with the 3A driver or are all of the CW's coming with the 4A driver?
Thanks very much, 2100. Your information is very helpful to me and others. I'm disappointed though in the performance of the NW 4-mode Dry light. I like the medium and low mode currents, but I had assumed that the high mode current would be around 3 A. Now I'm not sure if I want this light after all. The Dry uses 3 batteries while the Trustfire and Skyray use two, yet the Dry (4-mode) is about the same output as those. The Dry WW 3-mode produces the max. output I want, but lacks a low mode. :(
Yes I do know that NW is less efficient than CW, so I was expecting 3 A current on High, with a resulting small reduction in output compared to the CW because of the lower efficiency. I wasn't expecting lower drive current as well.
Well after a lot of thinking i thought NW would suit me best, although i have never owned a NW light but the nice color rendering combined with high lumen output would be great. But if it isn't 3A and the 2200 lumen i was hoping for i might consider the skyray. But i'll see what ric has to say.
The SkyRay looks really bluish to me, even more so than the Trustfire 3T6 (i have them side by side). This NW is 4000, maybe 4250k. IF you look at Cree's XM-L chart, the difference from 3700k to 8300k is 240-280 lumens. That is a whole 16.7% range. So 15% is quite belivable. I have a Xeno E03 WW and NW. With the same battery and tailcap, it is 38 and 44 lux reflected respectively. 15.8% difference. And do remember, lux meters are calibrated to have peak sensitivity at 2583k warm white, so that 38 lux for WW has the advantage. This is a real-world measurement.
If one really needs the lumens/lux, you can't go wrong with the CW 4A with short bursts, switching to medium for long use. If you live in the tropics and is hot whole year round, you'd need very high mass to soak up the heat, seriously even those 8 fins on the TF-3T6 does nothing much to cool over here unless you have a very strong breeze.
Well, i'll ask Ric if he can send me the so-called 3 mode 4A direct-drive drivers. I'll probably get the CW direct-drive 4A light as well to complete the collection. Remember, Chicago-X has the WW 3-mode direct drive and he gets 3A while I get 2.8A.
Trust me, if you own a lux meter, you'd see that the higher you drive, the faster the lux drops, it does not look what it seems. The difference in form factor between the regular 2 or 3 batteries "longish" Sky Ray/Trustfire/SZBOM vs this Dry is well worth the price, operated in medium/low mode this light is another version of the extreme runtime (actually this has higher lumens efficacy).
I can tell you, NW at 2A drive level, 150 reflected lux (vs 130 for TF and 160 for SR, both cold whites), are all around in the same ballpark.
And if you dig neutral white CCT, seriously there are no other options.
You can get the Sky Ray, but mine is sitting here direct drive on either a SLA / 3S3P pack because the driver blew and many others also. I thought Vin posted shots of this and his Dry CW with the 3-mode 4A driver.
