the - where'd you get that zoomie? Look'n for better quality zoomies, but still budget. You got a link? More specs?
Yes, also the blinky modes are memorized. You are fine as long as you use it more than 1s at a time.
Seller (or manufacturer) flashes the drivers.
See your PM. :)
Half time results:
Judging by the answers so far, it seems like the three settings which can be modified with stars would be:
1. Mode order
2. Mode memory
3. Turbo timer
..which would leave the lowlow mode enabled and hidden modes available. At least I would be ok with those settings. Any objections?
I have to add that turbo timer is a requirement by the manufacturer. They say that 6x7135 is the maximum they are willing to do, or warranty will be void. 8x7135 + turbo timer should be ok for them. That would leave the buyer the option to disable the turbo timer and thus void the warranty. ;)
Disable turbo timeout: 2.8 amps is not that much for a large light with good heat management, say direct thick copper star, well fitted to a solid pill screwed into a finned hard anodized head. Also, as mentioned at the top, air flow such as on a bicycle improves cooling.
Change mode order.
Disable mode memory.
For example, if you use it in a place that is very dark you would want it to start very low, not to lose night vision, or if you use it indoors a lot to supplement room lighting you would want it always to start on turbo.
Like the looks of the zoomie the. Could you pm the link too, thanks.
Linh
Please be patient. We are still negotiating with the reseller and the manufacturer. Group buy will be announced as soon as we get into agreement.. :)
I am interested!
and not very patient…
How will they prove you've disabled the timer, voiding the warranty? Couldn't they just deny most claims saying you must have disabled it?
If you get a good price I am in for this
same here
I might be in, depending mostly on price.
I like having a strobe, but not part of the selections. I’d make it where it comes on whenever you hold the button down for more than 5sec or something regardless of what mode you’re in. Then just turn off and back on to reset.
Disable mode memory, change mode order either ascending or descending. If capable of getting a host that can have a momentary button I would like that so that I can use the double tap for strobe.
Honestly i would love to see dip switches used instead of soldering stars although im not sure there a sets of 3 available or how that would work, but i can dream.
Double tap for strobe would also be good. I think for most people, strobe is either a novelty or to be used in an emergency type situation. To be able to get into strobe quickly without cycling through modes and to be able to bypass strobe when you just want to cycle through modes is ideal.
This is way out there, but it would be cool if you could have a flashlight that could be set up for the first mode to be red light, rather than moonlight mode. More light without causing your eyes to adjust.
A feature i would greatly enjoy is an indicator that the light is running out of regulation, when the battery voltage under load falls to about 3.6V the current to the LED starts falling (105C 2.8 or 3.04A) because the battery voltage is below what the LED needs, so the brightness starts falling (the current starts falling till battery is depleted), a flash once a minute or some key press that turns on and off the one flash a minute when out of regulation would be a great feature.
Thanks for your input so far! Highly appreciated! Please keep on commenting.. :)
Couple of further questions:
1. Turbo timer
I have been thinking of the turbo timer thing.. Some testers have been indicating that the subtle ramp down from turbo is hardly noticeable. Maybe it would be ok to leave it as is and have an extra hidden mode: "Turbo (no timer)", so it could be selected if really needed.
That would leave one star for possibly more important things like "Single mode Turbo (with hidden goodies)" or "Tactical config" (= Strobe, Turbo - no memory + hidden goodies like lowlow).
Would that be ok for most of you?
2. Number of modes
I use the lowlow so much that I really like the current four mode config. Some people use it only seldom (or never) and would like to disable it..
Choices here are:
- 4 modes: LL->L->M->T (+ hidden modes) -- easy to select LL, bothers some people
- 3 modes: L->M->T (+ hidden modes, including LL) -- LL doesn't bother, harder to select if needed
3. Type of the hidden strobe
What is the strobe preference of BLF?
Should it be a:
- tactical disorienting strobe (10-20Hz)
- slower signalling strobe (2-5Hz)?
- or something else?
Of course "Make both" would be ideal, but I'm not sure if I can fit those in the ATtiny13 memory. :(
4. SOS & Beacons
I have received requests to put in a hidden SOS mode too -> that can fit in the memory, but replaces one of the beacons.
Options:
- Keep the 1s beacon
- Keep the 10s beacon
- or maybe a 2.5s beacon would do?
Thanks in advance for your opinions!
Too many choices, overload!
No, I'm simple, this will be good whatever the outcome. That said: I use LL often so if memory can be switched off and I can choose to start with LL I'm happy!
(there was a thread about random strobe, can't find it just now, someone wrote some lines for it, that would be neat )
Turbo timer: I think no timer is more risk, so should not be default, but selectable.
Number of modes: for me, I like moonlight mode also. Everyday tasks like helping to put my key in the lock, this is much better.
Type of strobe: I think that if it is bright enough, even a slower rate can be disorienting. (still strobe rate, not beacon)
SOS / beacon: I would be happy if I never saw the SOS feature again. I think the odds of ever needing this is extremely small. If this was for a dedicated survival type light then this might be more important but there would be a lot of other features that would be equally important. Also, if I’m ever in a survival scenario, I wouldn’t want to sacrifice my battery for a beacon. I would much rather have a very small waterproof dedicated beacon.
Maybe a better solution is to come up with more than one solution? It’s kind of like we are trying to build a tank that can transport people to work every day while still being very agile and has a high fuel economy.
I agree with O-L - same as him with priorities. I've rarely heard of any use for SOS - think just for biking, but I thought they used SOS just because there isn't any nice beacon frequency available?? Beacons do make some sense.
Questions:
- mode switching is based on ON time, not OFF time? Why not if so?
- with mode memory enabled, does mode changing continue to the next mode, or resets back to mode #1, like luxdrv?
