Oshpark Projects
Tom just an FYI, if you don’t want to use a limit resistor on that version of 15dd you must use a jumper otherwise the FET’s source pin has no connection to ground.
Personally I find the newer 15’s to be much better overall, I “limit” them by setting lower PWM levels, never liked the idea of the limit (sense) resistor.
Well, PWM's have their issues - so I'd rather keep 100% usable. I'm having a really tough time programming this board. The resistors to the right of the MCU are too close. Finally got one programmed by filing down the sides of the clip, but the other just won't program no matter what I do, and even the clip looks perfectly seated. Boy these are a PIA... I think I read others struggling with programming because of clearances - not sure if it was the BLF15DD or not. I'll have to remove the resistors and see if it will work then. Might as well try something because the board will be useless with no firmware anyway...
PWM only limits the average current, not the peak current that occurs with each PWM pulse. If the pulse currents are too high, you could fry an LED.
Hi Tom, you might want to pick up a Nanjg programming board and preflash the driver before you solder it in. The smaller drivers were too crammed for space to allow for clip clearance. The board will save wear and tear on your clip making it last longer for the drivers it will fit.
Thanx Scott! Actually I got the BLF15DD boards working! I did end up removing the 2 resistors, then I could program it. The other board I build up and could program. Think for me, I'd be ok with doing the parts reflow in 2 steps - seems to work ok for me. Actually I think I got those OSHPark boards - but didn't get a setup to use them.
My $3.xx "slim" mini CREE AA zoomie is sure zoom'n with a BLF15DD and a XP-L V6 on a 16mm Noctigon (sanded down)! Smile
I have a separate thread with oscilloscope images of the gate signal on the FET drivers, here: https://budgetlightforum.com/t/-/27485
With 130ohm gate resistor (PWM = 12) :
Gate resistor bypassed:
I'm a complete 'scope n00b, so any tips/suggestions are welcome, including hardware combos to test and what to measure.
CC, I checked out your thread. Good stuff and hopefully we can all learn more about these drivers. Would you like me to put a link in the FET board header? You might want it linked in the various FET discussion threads as well. Be nice to verify that the signal bounce is the cause of the erratic behavior and not something intrinsic to each different FET.
I am only able to guess right now about the weird bounce being the cause of erratic behavior, still have lots more configurations to look at before the fog will begin to clear. Specifically, what does the waveform look like on the SRK-DD boards, which have never had issues running correctly without the extra resistors. The overall trace length on the V2-up 17/20DD is longer than the SRK even when the 17/20's resistor is replaced with a jumper. I also have some of the first version 17DDs with the super-short trace and without the resistor pads, that would be an interesting comparison too. And then there's all the hardware variations and how they work with different firmware versions... like does the waveform look the same for fast-PWM luxdrv and fast-PWM STAR clicky and fast-PWM STAR momentary?
Your nanjg “east 92” should also be on that list.
Isn’t that what the BLF 17DD is, a re-do of the Nanjg “manual” build?
A purpose build nanjg east92
Yes but his original mod didn’t need the gate resistor.
List of things to look at with the scope, not list of Oshpark projects.
DOH!
See post #1045 for current status - new version that no longer requires an additional capacitor, but instead just relocates the single original cap
ATTENTION
Gate/pulldown resistors no longer needed on the 15/17/20DD drivers (and though the SRK-DD technically works as-is without the resistors, it likely has this same voltage spike issue, it just happens to not be as severe, so this same fix needs to be applied on that one as well).
In the normal build of these drivers, there's a HUGE voltage spike at the MCU's Vcc pin #8 when the FET turns off. Up to 6v or higher... and if it goes too high, the MCU's overvoltage protection kicks in and it shuts down until power is removed. It also puts 6v onto the FET's gate, but that's a result of the voltage spike issue, not the cause. This is what it looks like on a driver with the gate resistor bypassed with a piece of wire (blue trace is the signal at the FET's gate, yellow is the battery voltage (the signal looks the same when measured either before the diode at B+, or after the diode at MCU's Vcc):
This is what happens if you place another 10uF/16v capacitor in parallel with the polarity protection diode, no other changes:
That's not perfect but I wouldn't expect it to be, and as long as it stays in the less-than-6v safe range it doesn't matter. Problem solved.
Would a resistor in series help? That capacitor sure does smooth out the pulse to the capacitor, would a larger capacitor smooth it further (or were you staying with the off time cap for commonality)
The off-time cap is 1uF, the 10uF is the same part as used as the main cap at C1. I don't think any value cap will totally eliminate the oscillation even if big enough to no longer fit inside a flashlight - and as long as it isn't a spike high enough to trip the attiny's overvoltage protection I really don't care. There are lots of hardware combos that work fine with less-than-perfect waveforms on various parts of the circuit. It just has to work, not look perfect.
I love what is happening here, improving the BLF-boards!
However (sorry for bringing it up again, I repeat myself I think ), I think it is also a service to enthousiastic end-users of the boards that they have access to these boards without having to dive into the electronics side. Tom already did an attempt by starting a thread about the 17mmDD board, and that thread showed directly how complicated it is for non-electronics expert flashlight hobbyists to understand how to just make one of those drivers without knowing all kinds of electronics stuff (for me, I can place the parts and reflow anything and live happy ever after with these great boards, but would not know exactly what is going on)
So I hope that all these great improvements to the BLF-boards are followed every now and then by a clear manual for dummies, like a picture of the current best led board with the right parts soldered in the right places (and cleaning up of old pictures of versions that did not work wel). Personally I would like to see scavenge information on the parts lists (like: 'also from 105C' , or: 'from old sk68 driver' , ) because there's no Digikey-like seller in the EU, every order of new parts comes with 25 dollar shipping.
Everything from a 105C, except the 7135s of course, is the same as on the BLF-15/17/20DDs. The 17 & 20 use a big TO-252 (also called 'DPAK') FET, the 15DD uses a tiny little SOT-23 FET. These were all designed to use the same components as the 105C in the same circuit design, on purpose. Same resistors for the voltage divider (4.7K & 19.1K), same capacitor (10uF/16v), same polarity protection diode, same MCU.
To fix the voltage spike thing you'll need a second 10uF capacitor, but it's the same part with the same specs as the main capacitor used on the 105C.
To add the off-time function, you'll need to flash the off-time firmware and a different capacitor, a 1uF/16v, placed between MCU pin #2 and ground (here, cheaper than retail even with price breaks, worldwide shipping): http://www.ebay.com/itm/181283883536
There are plenty of threads already showing the traces underneath a 105C to figure out what connects where. The circuit is the same on the BLF drivers, the components are just in different locations. But the same parts connect to the same places.
Updated shared-cart links for BLF drivers:
BLF-15DD: http://www.digikey.com/short/dcdj7
BLF 17DD & 20DD: http://www.digikey.com/short/dcndn
BLF-SRK-DD: http://www.digikey.com/short/dcdtq (last two items, the inductor & big schottky diode are optional - but if you want to use the inductor, you must also use the diode - either both parts together, or neither) (*note: this 5A/40V diode is a different part than used in earlier lists but is interchangeable, the old one is currently out of stock)
Those are parts lists for ONE driver. Adjust quantities to suit.
Please hold off on ordering these boards from Oshpark, they all need a new revision to add a dedicated spot for the second capacitor and to eliminate the gate & pulldown resistors. The parts lists will not change from what's shown here though. If you already have older revisions they can be used safely, just put the second capacitor where the diode goes, piggyback the diode onto the side of the capacitor, and replace the gate resistor with a jumper wire and skip the pulldown resistor.
I have not built or even looked closely at any of the recent updated Oshpark boards (like, the dedicated zener/resistor versions) so parts lists for those other boards will have to come from whoever has actually built (or designed) them.
edit: This is the capacitor for off-time memory builds, if you'd prefer to make a single order instead of some from here and some from over there, etc.: http://www.digikey.com/product-detail/en/C0805C105J4RACTU/399-8001-1-ND/3471724
Thanks comfy, that is is the kind of 'my level information' that I need to hear every now and then :-)
