Just wanted to say a big thank you to BLF member wight for taking the time to help me develop a MCU mod for this driver. His (assuming he's a he) guidance not only helped me figure out this mod, but he also noticed a mistake that I made at an earlier time when I swapped out what I thought was 2 FETs, but were actually a FET and a diode. The mistake didn't seem to hurt the MT-G2 and it made the driver run cooler, but it would have most likely been problematic to less hardy diodes like XM-L's.
I think I’m starting to see. You say “Full power is going to the bottom left Pin in the below pic.” I read that as “the bottom left pin” - a pin which does not have anything hooked up to it. That’s why I assumed you meant the bottom right. Now I see you meant the pin above the bottom left pin. When you said “full power” I was also confused since I wasn’t sure what you meant by that. Looking back at post #29 I’m sure you meant ~4-5v, not battery voltage. (remember, as far as I know this is a mystery MCU. So I don’t rule out putting battery voltage on it). Anyway I think I’m clear now, thanks.
There are 5 pins hooked up though, so I’m still curious what that final connection is on the bottom right. Looks like it’s not hooked up to anything but a bunch of unpopulated stuff. I still wonder what it was for…
I have only been using the driver with MT-G2 using 2S and 3S cells. Based on the way it behaves, I think it will have no problem with 4S cells. I will try soon to find out. I will also try 1S cell with an XML.
wight:
You're absolutely right on all counts. So sorry for the confusion. The second Pin/Pad from the bottom on the left is receiving a little over 3 volts. I'm not sure why the there is a difference between what I measure now at that Pad (without the MCU in place) and what I measured then with the MCU in place.
I will be modding another driver soon. I will take voltage readings again both with the MCU on and off the board and report back more clearly.
I think Werner is wishing it was a Boost/Buck driver (or maybe it is? - unlikely ).
It’s partly just the way I read things. One possible reason for the different voltages you observed would be “potential”. If you did not use the same ground point with your DMM you could get different readings. I look forward to your measurements with the next one. That should be telling!
Modded one that had 2xR068 stock. With similar (combined) values as my other one, output was a bit different. So, maybe its wise for people do test these things on their own drivers.
ImA4wheelr, the way you connected it in post 52. Does it whine in any of the modes that way too? What PWM frequency are you using?
Anyone who is able to incorporate low voltage warning and cut off for 2 cells in series?
Glad to hear you got the right driver finely. Did you get the "B1" version?
I'm assuming you are meaning using a 105C driver board as opposed to just an unmounted Attiny chip. The PWM feed should only be wired one way as the first way I did it basically takes you into direct drive. I didn't notice any whining, but I have to tell you that I'm pretty deaf to high frequencies.
I think the whining was amplified by having the driver hanging in the air and not having the heavy brass ring on the driver (like I did with the Post 52 pictures). I think just mounting the MCU properly and also mounting the driver in a light would eliminate most of the whining. I bet my potting recipe would absorb the rest of whining as it is a clay like substance.
I want to solve the whining issue too. Hope to get back to the driver this week. I need it for a couple lights. I'll ask my wife to listen and report back.
EDIT: Opps, forgot about your frequency question. 9kHz. Here are the lines from DrJones' MiniMo FW:
Hooked PWM to the 30,000 ohm resistor on the MCU side of the resistor, got ground from the ground ring and power in to the ATiny13A from the pad at the lower right side of the board.
Once I figured out the wiring to the e-switches in the TK61 (&@#~!!) it pulls 7.15A to the de-domed XM-L2.
That would be cool if someone knew the answer to CC's question.
DBCstm wrote:
Hooked PWM to the 30,000 ohm resistor on the MCU side of the resistor, . . .
For some reason, I couldn't get the driver to work when I tied in down stream from the point I tied into in Post 52. I was tying VCC in at a different point though when I did that. I will have to try that again. Do you know if there is any benefit to feeding the PWM through the resistor? Where I tied, PWM of 1 works. How low can you go tying in through the resistor?
From the Qlite, the wires were connected here: (picture from my other HX1175B, looks extra dirty due to light)
Found my error when looking over this post. You can see it in the first picture. Two of the legs where the HX-1175B MCU stood were connected. Problem solved.
There is some high frequent whine on "medium" with the qlite too. Mode spacing with regular Qlite firmware is really strange.
Low - 0,4A
Medium - 0,87A
High - 7,9A
Im glad it works. Thanks a lot ImA4Wheelr! :)
When I learn to program and flash these drivers I should be able to get nice mode spacing.. Please let me know if someone is able to find a solution for the whining.
Here is a close up picture if you need it.
Edit after a little tweak:
0,05A
0,99A
8,12
Well regulated down to about 5,6V. High sinks down towards 8A.
AFAIK they have definitely not been ID’d. The 10-pin is almost certainly an MCU of some type though…
RaceR86’s “other” board shows an “A” on the 6-pin chip. The 10-pin MCU is really well ground, looks like they built a machine to do that.
Racer86’s 10-pin chip does show an important marking though. There’s the dimple for pin-1 but there’s also a little dot beside that. It seems that the dot must be part of the manufacturer’s marking or logo, it almost certainly does not indicate a pin or anything. I don’t know who. Maybe someone wants to pour over sites like this one.
Where is the whining coming from, can you tell? Consider potting the driver, as suggested by ImA4Wheelr. I assume that epoxy potting will be much better at quieting it down than his clay-like recipe, but also way less reversible ;-).
I can tell you that my analog meter on my power supply says about 7,8V and 5,6A input. Or 43,68W
Emitter current at about 8,1A (XM-L2) then voltage should be about 4,2 according to graphs. 34,02W at the emitter
None of those numbers are precise. But that gives me a bit below 80% efficiency and more than 9W of heat in the driver with the combo above.
Long before this thread was started I had some numbers that said about 85% efficiency, but those numbers were not super accurate either, and emitter amps were lower.
Either way. 9W is a lot of heat for a driver circuit, so better make sure its able to get rid of that heat.
