I have this light as well and have been impressed by it. I have the F35 also and am even more impressed by that light. The blinky modes are a little annoying on the X6 but it has reliable mode memory so I'm OK with it.
I too just got the X6 and really love it. The design is exceptionally pleasing, very easy in the hand. And the clip impresses me as well, mine is also still on the light…one of only 3 that rate that.
I removed the R200 sense resistors and tried it bypassed. The small twin FET’s drove it at 5.5A from a slightly used Efest 35A. BUT, I lost the lower modes…it had 3 highs and the blinkies. So I put 2 R10 sense resistors in and it now does 4.45A from the same cell, very nice. Also put a 16mm Noctigon with XM-L2 U2 2C in using Arctic Alumina Thermal Adhesive. With a piece of Kapton cut from a battery pull I’m guaranteed there won’t be a short with this smaller star.
All in all, regardless of price, this is a very nice light and ranks high in my favorites right off the top.
A side note…got an Eagle Tac TX25C2 a week or so ago. Also a very nice light and I like it. Coming home from a week vacation where I used the ET quite a bit I found this X6 had come in. In the first day, with the above mods, I am wondering why I spent the chunk of change it took to get the ET. I’ll probably use the X6 more. Just sayin…
Thanks for sharing the review, appreciate it. FWIW, no glue on mine whatsoever.
And it’s worth mentioning that the reflector is aluminum, exquisitely finished, with a lip around the top edge that holds a very robust red O-ring that presses against the lens directly. Nice touch. The brass driver retaining ring is thick and way overkill, also a nice touch to pull heat away from the driver. Brass retaining ring in the tailcap as well. Big spring on the driver, thick diameter wire and again, nice touch. This light had some serious thought put into it and it shows everywhere. The driver compartment is, I think, for a 17mm driver, they angle cut into the area of the shelf such that every possible bit of mass was retained in the head. Thick star shelf as well. Smooth, no recess or dimple. All the little details are there and I for one greatly appreciate it.
Mode memory is in off time (there’s probably a better word for this that I can’t think of)
So whatever mode it is turned off in is the mode it will turn on in as long as approximately 3 seconds pass. I will check on the driver measurements.
Packages from BG typically arrive here (Central US) in about 17 days (weekend/holidays included), about 30 days for Li-ion packages. I’ll double check my spreadsheets to confirm. Doubled checked and edited.
Thanks for the nice review. Wow, great light and look at that clip and lanyard too. They look high quality for such a low price. Does this light accept 17mm driver? I plan to get a moonlight mode using qlite.
The stock driver is 16.86mm (measured on the rough tabs, widest part). The ledge the stock driver sits on is 18.12mm at the widest and 16.09mm at the thinnest, so a qlite driver with it's components on both sides will sit flush on the ledge with good contact; however, the spring side would need modification in order to utilize the 21.38mm x 13.00mm x 3.99mm brass retaining ring (Outer Diameter x Inner Diameter x Thickness).
The driver cavity is approximately 8.2mm deep. The shelf the star sits on is about 3mm thick (it has been machined down flat for the star to sit on), and unmachined area surrounding the star is 5.4mm thick.
The lens is some very nice glass 2mm thick with a nicely finished edge. As noted above the reflector does have a lip around the diameter of the reflector that allows the thick O-ring to sit against and the glass to sit upon the O-ring. It is indeed a truly well thought out design.
With the resistors replaced, I’m getting 4.51A and 1370 OTF start lumens. Thats a simple change of the 2 R180 sense resistors to 2 R10, and an XM-L2 U2 2C on a Noctigon.
I love mine, I’m waiting on my XML color sinkpad’s to get here, I’ll be putting an XML color and a custom RGBW driver in my first one but I’ll definitely be watching for a GB, for the right price I’ll pick up one for sure, maybe more.
If I want to drive it at 3~3.5A range, will 2x R100 do the job? Do I replace the R180 resistors or just stack over them? Sorry, I have yet to try resistor mod before.
Stacking an R500 on one and trying it should be pretty close. I don’t know how this driver reacts to only one stacked resistor. If it acts funny you might try stacking 2 of an R500 (one on each R180) or closest you can find. I think if you come in higher than your’e looking for you could limit overall output by cell selection. Using something like a Panasonic 3400mAh cell would give good run time and not allow the major current, so it’d be a good choice to control top end output while keeping run time high.
Wight or Richard could probably elaborate more on this than I can.
Use an online parallel resistor calculator to get close then see what you can find that matches up. Take it from there.
I really do not want to do the flame thing, but may have to try.
Put it in a vise with wood on the sides and a rubber strap wrench and it did not budge.
I really like the light as is, but would like a little more punch, so I hope to get it apart with out damage.
Really like the flashlight as is, great for the money.
later,
Keith
Banggood, this is a sweet light with an excellent build. If you were to put a driver in it that gave 3.5-4A with no blinkies and a moon mode you’d have it just about right. The vast majority of users do not use strobe or SOS, it might be nice for them to be there but hidden so they wouldn’t have to be scrolled through on the way to off.
A very low moon in the 2% range, then 15, 30 and 100% would be very nice. If it’d came that way I wouldn’t have changed a thing.
I’ve only had the light in my possession a few days, but I liked it from the beginning and it grows on me more every day.
I just de-domed mine and it’s quite impressive! I have a welders lens for viewing solar eclipses. I used it to look at the emitter while on High at 4.5A, and with a scalpel I precut around the edge of the dome then applied light pressure lifting from the negative side until it released. Came off pretty clean and the tint looks nice. This is an U2 2C. Puts quite a lot of light at 100 yds, easily reaching out 200 yds and more.
Yes, the head was warming up pretty good at that power, but it didn’t get hot in the few minutes I was just using it…I’m thinking the fins are doing a good job dispersing that heat and the quality build contributes throughout.
Liking this light more all the time!
Poor TX25C2 is gonna get left at home, there’s a new high power EDC in town.
