My Ganzo G-710 performs brilliantly, with a very robust lock that never disappointed.
I think judging a model (let alone a whole brand!!) basing on one’s single experience is not a reliable way to determine wether a product is good or bad.
I do not say that you must hit a spine whack with all your force, but a low hit and bad lock ups show its weakness. I have seen that in fake knives. A low hit do not hurt the knife, and if with a low hit the lock fails almost sure you can with the force of your hands desengage the lock system (lock fail). And a lock that you can with your hands close the knife with the lock engaged is a weak lock and unsecure. I think that. Al least a knife would must resist a low hit. If you pierce a hard material (a simple hard plastic bottle of soap of washing machine) and do not pierce it and lock fail and… fingers…
Yes, we can say use a fixed knife but that tactical heavy duty folders must be useless for something!!.
I bought at the start of collecting knives a beast of knife, 250 gr weight, tanto blade, 4 mm wide blade, the most beast you can imagine, and the liner lock thin like a paper (no literally). A low low low hit veeeery low, almost only drop the weight of the knife and the knife is close, the lock fails. I do not want anymore, never, something like that. Always i see if a knife have good lock for that. A like a lot the ganzo g711 but seeing that videos i will not buy it, and even difficult i will buy more ganzos having three yet.
I’ll post my review about the SRM 7076 soon.
I’m also interested in the SRM 7071 but I’m still waiting for a different handle color.
I’m not sure about the 7078 because my knife budget is also limited and I prefer locking folders.
Anyway I’m waiting for your thoughts about the 7078 when you receive it.
I don’t care for the Axis lock, but I don’t see how some folks might be using a folding knife that light reverse pressure on the locking system would be an issue. There is good technique and bad technique. When I use any knife I tend to be careful and let the sharpness of the blade do the cutting, but generally, I cut things with the sharp edge and that doesn’t put any pressure on the locking mechanism at all…but I don’t expect any light pocket folder to be as rugged as a fixed blade.
So a $20 Chinese knife might not be a top-quality unit…that’s hardly surprising…but these knives seem fine to me for $20.
Flipper styles have the blade guard, as does the Spyderco design, but Just for curiosity, check out a Hinderer sometime…it’s a frame lock that’s built like a tank…(they do cost slightly more than $20 though.)
For a very secure but simple lock-up, look at the Cold Steel system…their knives are good quality overall and not expensive.
Cold steel will be cheap in EEUU, not here in EU. For example, a cold steel spartan costs 109€ (148:money_mouth_face: in my country, Spain. And if i buy in EEUU online i must pay taxes and the price can be similar.
However an enlan el01 costs 15$ and no more from China.
I think high quality chinese brand are very good but exactly ganzo with some models… it’s unacceptable (and i like ganzo a lot for other things).
About locking fail: well, if you pierce (stap) on hard thing (hard plastic, wood… i don’t know) with 90º (or more) between the knife and the thing perhaps the force could be that the lock fails. If it’s less than 90º can be more secure yes.
I understand what you’re saying, I am just naturally careful with cutting tools.
I prefer the EL-01 to the Axis models. For the money it’s a usable utility knife, but the blade could use more taper. All of these knives will benefit from re-profiling the edge for better cutting performance…no big deal.
Very good, everything lines up perfectly, the H joints where backspring meets blade are spot on. Better quality than the Rough Riders, although some of them can be excellent some can be just adequate.
I wish FastTech did more of the “traditional” style slip-joints. Going on the quality of this one I’d buy more.
The blades are not fingernail breakers either, the blades are secure in place when open but easy to open and close, at 45, 47 and 65mm the blades aren’t very long and some I have of the same length are difficult to open but not this, it’s a lovely small EDC.
The blades are Krupp 4116 steel and the scales look like deep coloured rosewood.
If you want a larger Rough Rider Folder then the Granddaddy Barlow has a 95mm blade and a saw-cut pattern on the bone handle scales.
On the subject of why can’t Ganzo make a secure Axis lock then I think the answer is possibly that they think they are fine as they are, as long as people keep buying them then there’s no need to change them. I bought one to check out the action on a full sized blade with Axis locking. I bought the G-712, the Benchmade 860 Bedlam clone, I liked it a lot but I don’t think that the cheapest Benchmade, the Griptillian, is not to my liking - far too plasticy for the £81 or $150 price. It is the price/value that puts me off. I like the Axis lock fine and believe that Benchmade make them better, the one I handled had the lock bar about half way along the tang and still a few mm to go before the lock bar hit the liners.
As long as people buy them they will still have dodgy quality control, there are a lot more of their range that I would like to try but I’m not risking getting a bad one.
than you can close its engaged axis lock with a finger!! and they don’t do nothing i will think it very much before to buy a new ganzo. I don’t know if the failures are most in G711 model or if only a group of the same model are bad. But it’s a shame that. It can be very dangerous that you confide in you have a lock system and really you haven’t.
I got curious about this “lock failure mass hysteria” and I dug out my G711 from my knife box. In spite of the short travel of the axis bar it passed the spine-whack test flawlessly. I used the same old wooden chair for the test.
My conclusions:
Is the travel of axis bar short? Yes.
Has it passed the dreaded spine-whack test? Yes.
Am I worried about the lock? No.
Is the axis lock of g711 bad designed? Yes.
All g711 are equals: no, the control quality is not good and some can be worst than others, but all are bad designed (the bar does not engage like it must be).
Can a axis lock that it does not engage well resist a spine whack? Can resist, but, it will be a bad designed lock system and weaker than a well designed.
It is at limit and on some that has a even more limit engage (no QC) then you can close with one finger, in the last video before we can see an enlan el02 engaging well and i can confirm that my el04 engages well too and ALL the lock bar is on the blade, nothing is out of the top blade.
My G712 works perfectly as well, enough of the lockbar on the blade tang for me not to be concerned about using it for anything that I might need to do with it. I can see that the lock is good, no blade play in any direction and the Ω have been adjusted so the lock bar is easier to disengage.
Both of the pivot screws were thread locked but loosened easily.
I will add a side note about the G620’s that I bought, I bought the set of six and one of them had one of the pivot screws so tightly stuck with permanence in mind that I broke a good quality Torx bit on it, this told me two things, some Ganzo pivot screws will not move and the hardware Ganzo uses is hardened.
The knife that I stripped down (to see the type of A/O mechanism) had the tendency to not lock with the A/O spring pressure alone, if it was to engage it had to be flicked as well, after re-assembly (luckily the side that was unstuck was the spring side) it works perfectly. The system is very Kershaw like but looks stronger, the spring was well lubricated and there was no rust anywhere, maybe the liners being coated helps this.
The G620’s are A/O linerlocks. 88mm 440 blade @55HRC so quite soft but easy to sharpen, ABS scales and definitely not a hard use knife but well up to household tasks.
I have recently bought a “tradidional” style Ganzo G725-M three bladed Stockman Pattern slip joint.
65mm, 47mm and 45mm blades in Krupp 4116 steel and it is excellent in fit and finish so Ganzo quality control could be said to be hit and miss.
It won’t stop me buying Ganzo in the future but I will have to really want the knife to buy it.
I think ganzo have a problem with axis lock but specially in some especific models, after to see some videos of g711 all showing the problem with lock my conclusion is that, the same way that you have yours. I have 3 ganzos and i can see the differences with the axis lock of enlan. Other video i think was the g715 and the guy can close it with a finger (locked) and hurt him.
I do not understand the joke about politician. And i do not get money from any brands for speaking well or bad (sorry if it is bad publicity to your blog), it is only my opinion and you can see the videos, they are more than a opinion from myself. Simply see my links and each one can think that they want.
Based solely on your comments and links someone could think that the whole Ganzo line consists of piece of junks only. Although there are plenty of positive oppinions too you seem to ignore them deliberately only to justify your preconceptions.
I think it’s necessary to show every side of the story to have a clear picture. Unfortunately you can’t expect the same level of QC at <$20 (international shipping included) folders as in the ~$100 category but suggesting that the whole line has major problems is nonsense too.
So please don’t be offended if someone has a different experience.
I’m writing “experience” and not “oppinion” because I own and use the specific modells which I mentioned in this thread.
I have some ganzos too, and enlans, srm, harnds, tekut, inron, fakes…
I have not knives like you for sure, but i have enough for seeing that the axis lock of ganzo do not engage like enlan and srm. I speak of my own ganzos, everybody can see that simply looking at lock pivot, but the problem is with other models like the g711 and g715, especially bad the g711 because there are various videos all with the same problem. I do not see videos of enlan or srm or other with the same model and all failing like that of the g711.
I am not saying that ganzo are horrible, i say that a brand can not put in market a knife than it can be dangerous because the force of a finger can do the lock fails. Simply that.
