LUMENSTEINS LUX MONSTER
Vinz has a new system to dedome the LED (only he knows how to do it…)
The LEDs are on cooperstars
Then a cooper ronde (125 mm* 3mm)
Then a really big Alu CPU behind.
The heat does not come out … But it is not a problem…
I bought them from an Olight distributor.
You said that there’s a special finish - is he spraying something onto the LED after de-doming to mitigate the colour shift?
I don´t know…
Either way, this torch you’ve made is extremely awesome. It’s innovation! I love the idea of putting 3 SR90 reflectors together and driving XP-G2s @ 5A each. 2 MILLION lux. What the damn hell? Isn’t this Maxabeam territory? Very nice work Xandre, Fritz15 and Andi.
+1
The beam and the light itself are total bad ass. Thank you again for sharing.
+2
Thanks . :slight_smile:
Now, we are trying to get more LUX …
More Amp and so on…
Without pictures, I don't think folks understand what kind of a beast you have built. I hope you don't mind if I post a couple from you album that is linked to above. If you do not want them here, I will remove them from this post.
I don't know the exact dimensions of those 3 reflectors, but they are for the Olight SR 90 which has a 100mm head.
Sorry but we don't play that shit around here. This isn't CPF.
Thanks !!!
The diameter is 88mm per reflector.
Super beam you got there, congratulations. Is it right if i say the diameter of the flashlight is around 250 mm? What host is that ?
Hi
look at Post 1…
It is not my game :wink:
I don't even doubt that Vinz has cooked something new. He really does thing on high level.
But you could put pictures of de domed emitters so we can try to guess ?
You are right men !
Vinz is a speciallist and he does his job with love.
No fucking money intress like ….
You do not see anything, when you look at the emitters.
I like to know self, how he do that… But this is Vinz secret.
I only have the luck,he did it for me.
When you want to see what is possible with XM-L2
look at his new creation: post 7
Beamshot Mjölnir:
http://www.andis3d.de/beams-04.htm
The beam in natural is pure white.
The beamshots were made at a flashaholic party .
So this should be XM L2 U2 1A driven at 7A. Normally by de doming it should have nice upper neutral white color(some says ugly greenish but I don't notice that in fields, in fact I see better than with cool white) and with this de dome method it remains cool white even cooler than original. Very interesting...
It looks like 400-500KCD light to me because by judging my aspheric(500KCD) at same distance mine would look more hotspot intense but this is of course bigger hotspot size. Can't judge the picture.
He could use some kind of fluid on phosphor... Maybe there are some fluids that phosphor absorbs without any harm to layer.
Yeah, it is 500 KLUX
but the spot is huge.
There is a lens direkt on the dedomed emitter.
No Lumen less.
I don't have luck with condenser lenses. Each I tried so far decreased my throw. But Vinz managed to dig something good.
Nicely done. Your light looks dangerous with the amount of throw it has.
With this much throw NASA could use it to throw satellites into orbit man!
